My home assistant is restarted by watchdog and not found what the problem:
18-12-27 06:29:25 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-12-27 06:34:55 ERROR (MainThread) [hassio.homeassistant] Error on call http://172.30.32.1:8123/api/:
18-12-27 06:34:55 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home Assistant
18-12-27 06:39:55 ERROR (MainThread) [hassio.homeassistant] Error on call http://172.30.32.1:8123/api/:
18-12-27 06:39:55 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant API!
My version is 0.84.6, but on version 0.83.3, i’ve same problem.
I’ve add subnet on configuration.yaml but not resolve:
http:
api_password: !secret http_password
ip_ban_enabled: true
base_url: !secret ha_url
login_attempts_threshold: 3
trusted_networks:
- 127.0.0.1
- 172.16.1.0/24
- 10.10.10.0/24
- 172.30.32.0/24
- 172.30.33.0/24
I’ve search but not found as resolve this problem. You’ve an idea?
Normally always 8hrs before restart
Thank you for help.
