Watchman and Apollo Oil sensor in HA - working setup
For anyone that may be interested:
I have a RTL -SDR V4 Blog dongle attached to my NUC running HAOS.
I installed rtl_433 and rtl_433 Autodiscovery (both “next” versions but don’t think that matters).
Mosquitto Mqtt Broker intergration installed and I have MQTT Explorer also installed (in order to see the entities picked up and their refresh times)
I did not do any setup of the above, it simply worked out of the box (I will have to fiddle as I also want to pick up some 868mhz signal, in addition to the 433mhz for the oil sensors)
MQTT provides me with devides (oilSonicstd-16915 for te Apollo) and oilSonicadv-xxx for teh watchman) with various entities including Airgap and Timestamp (showing last update received) and some others whcih I have not identified yet.
In configuration.yaml I have added the following code which provides me with the following which I display on my dashboard:
-Oil Depth
Oil Volume (as i have a horizontal cylindrical tank - i use depth/volume numbers givenm by teh manufacturer) (see mapping section)
-Oil needed when ordering
-Oil percentage left
I will later use something like this Liquid level display to display a bit nicer than the standard stats card i use now.
You will need to replace the mapping numbers with whatever you have, as well as teh tank_height value in cm (mine is 150), the full_tank_capacity (mine 3500) in litres (in several places)
and change the unique_ids.
All working nicely. here is the code:
    sensors:
      oil_depthft:
        unique_id: 35bc8083-a6ce-4406-b005-513c36f7c1b6
        friendly_name: "Oil Depth Farm Tank"
        unit_of_measurement: "cm"
        value_template: >-
          {% set total_tank_height = 150 %}
          {% set airgap = states('sensor.oil_sonicstd_16915_depth') | float %}
          {{ total_tank_height - airgap }}
      oil_volumeft:
        unique_id: 713a91a4-6f76-412a-adf2-0d626add6a7d
        friendly_name: "Oil Volume Farm Tank"
        unit_of_measurement: "L"
        value_template: >-
          {% set depth_volume_map = {
            10: 130,
            20: 305,
            30: 515,
            40: 745,
            50: 1010,
            60: 1285,
            70: 1575,
            80: 1875,
            90: 2170,
            100: 2450,
            110: 2710,
            120: 2950,
            130: 3155,
            140: 3315,
            150: 3420
          {% set oil_depth = states('sensor.oil_depthft') | float %}
          {% set depths = depth_volume_map.keys() | map('float') | sort | list %}
          {% set lower_depth = depths | select('le', oil_depth) | list | last %}
          {% set upper_depth = depths | select('ge', oil_depth) | list | first %}
          {% if lower_depth == upper_depth %}
            {% set volume = depth_volume_map.get(lower_depth, 0) %}
          {% else %}
            {% set lower_volume = depth_volume_map.get(lower_depth, 0) %}
            {% set upper_volume = depth_volume_map.get(upper_depth, 0) %}
            {% set volume = lower_volume + (upper_volume - lower_volume) * (oil_depth - lower_depth) / (upper_depth - lower_depth) %}
          {% endif %}
          {{ volume | round(2) }}
      oil_neededft:
        unique_id: 0f56ed92-2edc-4f12-82f4-b871710ade5b
        friendly_name: "Oil Needed to Fill Farm Tank"
        value_template: >-
          {% set full_tank_capacity = 3500 %}
            10: 130,
            20: 305,
            30: 515,
            40: 745,
            50: 1010,
            60: 1285,
            70: 1575,
            80: 1875,
            90: 2170,
            100: 2450,
            110: 2710,
            120: 2950,
            130: 3155,
            140: 3315,
            150: 3420
            {% set current_volume = depth_volume_map.get(lower_depth, 0) %}
          {% else %}
            {% set current_volume = lower_volume + (upper_volume - lower_volume) * (oil_depth - lower_depth) / (upper_depth - lower_depth) %}
          {% endif %}
          {{ full_tank_capacity - current_volume | round(2) }}
      farm_oil_percentage_leftft:
        unique_id: 48287b52-1bc6-4390-83b3-cf9764bccdc5
        friendly_name: "Farm Oil Percentage Left"
        unit_of_measurement: "%"
        value_template: >-
          {% set current_volume = states('sensor.oil_volumeft') | float %}
          {{ ((current_volume / full_tank_capacity) * 100) | round(2) }}
Good to know someone has managed to do this successfully!
I’ve also got an Apollo sensor and am trying to do the same, albeit using a different receiving unit (a LilyGo). I know the receiver is working but I can’t discover the Apollo signal and I suspect it’s because I’m listening on the wrong frequency. What frequency do you have your receiver / dongle set to listen for?
i am now playing with 433 and 868, but for me the watchman and apollo worked before that without adding any frequency setting, simply on default (which was 433).
To clarify: i simply installed rtl_433 and rtl_433 MQTT auto discovery add ins. (actually in my case the (next) versions, but I will change that to the normal (stable) versions soon)
entered the required details in teh config tab of teh autodiscovery add on (only not the rtl_433 one).
Ran both. installed MQTT Explorer and saw them pop up.
you can also have a look at this thread where DeviantIntergral gives me some explanations:
https://community.home-assistant.io/t/issues-with-setting-up-rtl-433-next-and-rtl-433-auto-discovery-next/857926/13
Hi @TheRagingFury ,
Thanks so much for sharing, I’m definitely copying this :slight_smile:
I’ve made some progress, but I’m a bit stuck, and MQTT is definitely not my strong point, so I thought I’d reply here in the hope someone sees it who could help.
I’m getting the signal into rtl_433 logs no problems, with a correct value.
e.g.
time      : 2026-01-09 09:30:10
model     : Oil-SonicStd
flags     : 50
alarm     : 0
binding_countdown: 0
depth_cm  : 17
Also, in MQTT Explorer, I can see an entry for Oil-SonicStd OK (but with a timestamp of a couple of days ago, so looks like it might only have worked once.)
  "time": "2026-01-07T18:59:21.658942Z",
  "model": "Oil-SonicStd",
  "id": 0,
  "flags": 0,
  "alarm": 0,
  "binding_countdown": 0,
  "depth_cm": 0
Wondered if anyone can help with debugging MQTT, as like I say, it’s definitely not my strong point, most of my stuff is zigbee or esphome.
Thanks again for your efforts.
Cheers,
Dunc
Me again.
Not sure what I did wrong before (maybe I installed stuff in the wrong order?), but I just tried removing all 3 add-ons, then installing Mosquitto, rtl_433 and rtl_433-auto-discovery (All -next versions), and all is working fine now.
Cheers,
Dunc
