šŸ›” Watchman - keeps track of missing entities and actions in your config files
this is not working, you need border-width, but this is only for the outside but not the inside lines any tipps? padding not working in my tests
Why are we discussing CSS stuff here?
Any idea how one can align the table so it shows all columns (instead of just cutting the content)? I think itā€™s a classic styling or maybe a flex-table-card specific issue, isnā€™t it?
      - type: custom:fold-entity-row
        head:
          type: section
          label: Watchman Report
          style: |
            .divider {
              background-color: transparent !important;
        padding: 0
        open: false
        entities:
          - entity: script.system_watchman_report_generieren
            name: Watchman Report generieren
            icon: ''
          - type: weblink
            url: /db21ed7f_filebrowser/dashboard/
            name: Watchman Report ansehen (vollstƤndig)
            icon: mdi:note-edit
            new_tab: false
            card_mod:
              style: |
                a {
                  text-decoration: none;
          - type: custom:collapsable-cards
            title: šŸ”Ž Vorschau Report
            defaultOpen: false
            buttonStyle: 'font-size: medium; background-color: var(--divider-color);'
            cards:
              - type: custom:vertical-stack-in-card
                cards:
                  - type: entities
                    entities:
                      - entity: sensor.watchman_missing_services
                  - type: conditional
                    conditions:
                        state_not: '0'
                    card:
                      type: custom:flex-table-card
                      title: ''
                      entities:
                        include: sensor.watchman_missing_services
                      columns:
                        - name: Dienst
                          align: left
                          data: entities
                          modify: x.id
                        - id: id_state
                          align: left
                          data: entities
                          modify: x.state
                      sort_by:
                        - id_state
                      style: |
                        ha-card {
                          border-width: 0px;
                          margin-top: -23px;
                cards:
                  - type: entities
                    entities:
                      - entity: sensor.watchman_missing_entities
                        name: Fehlende EntitƤten
                  - type: conditional
                    conditions:
                        state_not: '0'
                    card:
                      title: ''
                      entities:
                        include: sensor.watchman_missing_entities
                      columns:
                        - name: EntitƤt
                          align: left
                          data: entities
                          modify: x.id
                        - id: id_state
                          align: left
                          data: entities
                          modify: x.state
                        - id: id_occurrences
                          align: left
                          data: entities
                          modify: x.occurrences.split(':')[0]
                        - name: Zeile(n)
                          data: entities
                          modify: x.occurrences.split(':')[1]
                      sort_by:
                        - id_state
                        - id_occurrences
                      style: |
                        ha-card {
                          border-width: 0px;
                          margin-top: -23px;
Is it possible to have the referenced file Located In:- "automations.yaml:2754,2789" linked to the actual file, pretty much a hyperlink to automations.yaml:2754,2789?
Need help with this error message which shows up every time I restart HA:
Logger: homeassistant.components.sensor.recorder
Source: components/sensor/recorder.py:239
integration: Sensor (documentation, issues)
First occurred: 11:10:18 PM (1 occurrences)
Last logged: 11:10:18 PM
The unit of sensor.watchman_missing_entities (items) cannot be converted to the unit of previously compiled statistics (None). Generation of long term statistics will be suppressed unless the unit changes back to None or a compatible unit. Go to https://my.home-assistant.io/redirect/developer_statistics to fix this.
Go to Developer Tools ā†’ Statistics. You may or may not be able to fix the issue.
Or exclude this from being kept in the statistics. Not sure why you would want this?
Ha. That just moves the issue. You then get this unfixable issue in Dev Tools Stats:
Untitled
You can just delete it now?
Nope. The entity still exists but is just not recording data.
You can disable the entities though. That clears the errors and stats issue.
Well, the ting is that this entity generaliy works very well. Despite this error, it correctly reported several incidents this morning, so deleting our disabling it seems like a bad idea.
It seems like itā€™s just in a special situation that this entity throws this error, but otherwise it works well.
How can i isolate the culprit and solve this without taking such drastic measures as killing the whole entity?
Set the UoM as entities (anything but none) via your customize.yaml, restart and click the fix button on the stats issue. Choose the recourse that works for you when prompted.
But, as said, do you really need this in the permanent longterm stats? Removing it from long term stats doesnā€™t mean you wonā€™t have any history. Youā€™ll still have the normal history as per your recorder settings. That said, Iā€™d even exclude the entity from there, because all you really need is the current state. Recording history will bloat your DB if you have a fair bit of missing entities, since all of those strings of entity IDs get stored in an attribute in your DB ā€” repeatedly.
Thatā€™s a very good point, Sir. So, now Iā€™ve added all three Watchman sensors to the exclude list of the recorder. However, that alone doesnā€™t solve the error, right? Itā€™s just prevents recording of the states of these sensors.
Iā€™m uncertain as to what UoM means and what it does. Could you explain a bit more? Perhaps a syntax sample?
Many thanks in advance.
Sorry, itā€™s unit of measurement.
Do you use YAML?
No, fixing the stats issue is separate. This was just a separate recommendation.
Do you mean; Do I know how to use YAML (Yes), or did I use YAML to implement the Watchman Inetgration (No)
I asked, because the link I posted requires you to edit YAML.
You can do some things via the UI too, but I donā€™t use the UI for this kind of thing:
Customizing entities - Home Assistant (home-assistant.io)
Ok, I think I can edit YAML fairly well, but only as far as I understand the objectives.
You wrote ā€œSet the UoM as entitiesā€. What does that mean?
First of all, thereā€™s no configurable variable named Units-of-Measurements in the core integration. The closest I can find is one named unit_system which is either Metric or US.
Secondly, how can a variable be ā€œset as entitiesā€ ?
last but not least, even if I did understand your proposal, what good would ā€œsetting it as entitiesā€ do in terms of solving my problem?
Please explain in more (accurate) detail.
This link is about setting it in YAML: Home Assistant Core Integration - Home Assistant
This one is about using the UI: Customizing entities - Home Assistant
Letā€™s go for YAML.
You need this in your configuration.yaml:
homeassistant:  # you'll have this already
  customize:  # you might have this section already
    sensor.watchman_missing_entities:
      unit_of_measurement: entities  # or items; see note below
I havenā€™t had to set a UoM for my sensor, so Iā€™m not sure what went wrong in your case. Mine has UoM items, but it doesnā€™t matter too much in this case whether you set it to entities or items. You just need to set it to something other than none in order to fix the stats issue.
Letā€™s continue this via DM or a separate post if youā€™re still stuck, since itā€™s not related to this topic anymore.
Like Watchman, but it gives me an error I canā€™t findā€¦
Hovering ā€˜lovelaceā€™ it gives me : storage/lovelace:328
I went to the Raw Configuration Editor, but canā€™t find it.
Any idea ?
Hy community,
I have one issue with a group of spots which are used in an automation. If a spot gets unavailable, I donā€™t get a notification from Watchman, because the state of the group isnā€™t ā€˜unavailableā€™. How are you working with Watchman and groups regardings this topic?
