Water flow sensor relay control and usage monitoring
Hello, I need help with a ESPHome config.
I cant code to save my life
I have a reverse osmosis system that makes potable water available in my house.
this system has a UV sterilizer light.
The light stays on 24/7 but the system only runs a few hrs a day, the UV bulbs have to be replaced every 6 months do to this 24/7 operation.
I have an ESP-12F_Relay_X2
and a water flow sensor Gredia GR-402b
I would like to have the ESP switch on relay1 when it detects a pulse from the sensor and keep it on for 5 minutes, it also needs to reset the timer back to 5min every time a pulse is detected.
additionally, it would be nice to have the usage reported to Home Assistant, so I can add monitor use etc.
I really would like the sensor relay logic to be on the ESP and not use a hass.io automation.
but I am truly clueless beyond the most basic configs
here is some starting code just to define what I do know
esphome:
esp8266:
  board: esp12e
# Use the blue LED in the device as a status LED, which will blink if there are warnings (slow) or errors (fast)
status_led:
  pin:
    number: GPIO2
    inverted: True
# x2 relay outputs, exposed as switches in Home Assistant
switch:
  - platform: gpio
    pin: GPIO5
  - platform: gpio
    pin: GPIO4
  # Blue LED on Board (not ESP board) as switch in Home Assistant
  - platform: gpio
    pin: GPIO16
    inverted: true
  - platform: pulse_counter
    pin: GPIO2
    unit_of_measurement: 'L/hr'
	update_interval: 60s
    filters:
       - lambda: return (x / 38.0) * 60.0;
    unit_of_measurement: "L/hr"
    total:
      unit_of_measurement: 'L'
      name: 'R-O Feed-Water'
      filters:
        - multiply: 0.38  # (1/38 pulses per L)
	#2280 pulses per liter or 8630 per gallon
	#F=(38*Q)±3%, Q=L/Min
is there a bounty system here? i need to get this going but its over my head,
add this on your pulse counter:
on_value_range:
     - above: 2.0 # sensor value  indicating flow
        then:
          - switch.turn_on: relay1
and on switch component:
  on_turn_on:
    - delay: 3000s
    - switch.turn_off: relay1
