Regarding: Water Heater - Home Assistant
I saw the new nice Tile Card, with the water heater possibility. So I wanted my water cooker to work with the tile card, but I had a hard time creating a water heater, so after this get this tilecard to work. But eventually I couldn’t get it to work.
I have 3 entites of my water cooker:
switch.waterkoker (it’s main switch - to turn it off at night)
sensor.waterkoker_actief (indicates if its self-heating or not)
sensor.waterkoker_power (the power it currently draws)
The device has no other controls, the settings are fixed.
I would like it to get 1 entity with the device class: water_heater. So I can use the tile card.
But the water heater integration below does not accept my code. Would be nice if it did
water_heater:
icon: mdi:kettle
heater: switch.waterkoker
target_sensor: sensor.waterkoker_actief
power_attribute: sensor.waterkoker_power
availability_template: "{{ is_state('switch.waterkoker', 'unavailable') or is_state('sensor.waterkoker_actief', 'unavailable') or is_state('sensor.waterkoker_power', 'unavailable') }}"
If I use - platform: demo
like in the example Water Heater - Home Assistant
HA goes weird with 43 demo integrations. Platform: switch does not seem to work, so I see no other way to use this integration. I tried it with - platform: template, but that is not documentated as a possibility either and it does not seem to work. The documentation is too limited.
A template entity, does not give me the device class water_heater either.
Also tried:
climate:
- platform: generic_thermostat
But then HA thinks it’s a thermostat from 7 till 35 degrees. Doesn’t look good either.
