Water Leak Alarm – mobile + HA UI notifications
:receipt: About
This blueprint provides a clean and reliable water-leak alarm of any binary leak sensor.
It sends both mobile push notifications and Home Assistant UI (persistent) notifications whenever a leak is detected or cleared.
:receipt: Get it now
Import Blueprint to My Home Assistant
:sparkles: Features
  • Dual notification toggles – choose between mobile push, HA UI persistent, or both.
  • Leak detected & cleared alerts – distinct notifications for both events.
  • Separate HA notification cards – “leak detected” and “leak cleared” never overwrite each other.
  • Simple setup – pick your sensor, notify service, and customize messages.
:gear: Inputs
Input Description
Leak sensor entity Any moisture sensor.
Notify service e.g. notify.mobile_app_your_phone or notify.notify.
Enable mobile push notifications Sends push notifications via your chosen notify service.
Enable HA UI notifications Creates persistent cards in HA (bell icon area).
Titles & messages Fully customizable for both leak and clear events.
:outbox_tray: Notifications Example
Leak detected:
🚨 Water leak detected
Leak detected by Bathroom Leak Sensor at 2025-10-10 08:23:45.
Leak cleared:
✅ Water leak cleared
Leak cleared for Bathroom Leak Sensor at 2025-10-10 08:31:22.
:test_tube: Tested With
  • IKEA BADRING (Zigbee moisture sensor)
  • Home Assistant 2025.10.x
  • Compatible with any binary_sensor or sensor that reports wet/dry states
:spiral_notepad: Changelog
v1.1 – Latest update
  • Removed “Auto-dismiss leak detected card on clear” toggle
  • Added new “Enable mobile push notifications” toggle
  • Independent selection between mobile and HA UI notifications
  • Cleaned inputs and simplified layout
v1.0 – Initial release
  • Leak + clear notifications
  • Separate persistent IDs for each event
  • No siren/switch dependencies
Hello schiberis,
This was all written with Legacy syntax, almost like an AI wrote it for you. But I’m sure you didn’t use an AI to help others, so I won’t ask.
While this will probably work for now, future changes might be a problem and it is confusing for new user software to be written in this form, I suggest changing it to the modern syntax to prevent problems. Or don’t, your choice.
I like this idea and plan to use it, so thanks for the effort. I will be tweaking my copy to the modern format, one way or the other.
Could you give support for critical alert and repeating after some time?
Nice, but I have an annoying issue. When my sensors have a minor disconnect, I get a notification when they reconnect “water leak cleared” this is quite a scary message to see especially if you don’t know the sensors disconnected. Or when I share HA with my family.
Hi @Sir_Goodenough, I just got my sensors and water valve actuator installed and running. Do you have a “modern” template you could share? This will be my first automation and haven’t programmed or developed shell scripts in 20 years so a little rusty. Thanks!
Sorry, not my blueprint…
