Hello everyone,
Did anyone ever integrated Home Assistant with the water meter HRF-C-G2? It works at 868 MHz. Would that be possible with the CC1101 for instance? I am not sure how often this water counter sends data and if we can pull the data as often as we want to. I also don’t know whether it’s a protected signal or if it is easy to read.
Thanks for your help!
Mgim, I am sorry not to be able to answer your question.
I have exactly the same question, but for Homerider Systems’ HRU-c-G2 model.
The model above is from the device sticker, but in Homerider Systems product catalog I can only find one device which is visually the same as mine with the description “G2 compact Sensus; CEMDGU203519 - 868Mhz; HR-G2-SENSUS-C-868”.
They are mentioning three protocols: walk by drive by, HR Net and HR Lora. I am wondering if one would be able to read that device via SDR.
Thanks in advance!
