Water meter
Good Evening all,
I am creating a water meter as per this link:
https://www.pieterbrinkman.com/2022/02/02/build-a-cheap-water-usage-sensor-using-esphome-home-assistant-and-a-proximity-sensor
I have copied the code and
- platform: pulse_counter
    pin: GPIO12
    update_interval : 6s
- platform: pulse_meter
    pin: GPIO12
    name: "Water Pulse Meter"
    unit_of_measurement: "liter/min"
    icon: "mdi:water"
    total:
      unit_of_measurement: "liter"
    name: "Water Usage Liter"
    accuracy_decimals: 1
    unit_of_measurement: "l/min"
    icon: "mdi:water"
    lambda: return (id(water_pulse).state * 10);
    update_interval: 6s
ESP doesn’t seem to like the code and giving me the following error:
ERROR Error while reading config: Invalid YAML syntax:
mapping values are not allowed here
  in "/config/esphome/water-meter.yaml", line 27, column 8:
        pin: GPIO12
Does anyone have any ideas where I am going wrong?
Kindly appreciated
I think your indentation is wrong
whats that? / What do you mean?
It should be like this
    pin: GPIO12
Thats worked thank you :slight_smile:
i’m have the same problem , and the solution supposed here , creates new errors
what is the solution of this cascade of errors?
SEE image with my error below
#https://www.pieterbrinkman.com/2022/02/02/build-a-cheap-water-usage-sensor-using-esphome-home-assistant-and-a-proximity-sensor/
  pin: GPIO12
    pin: 6
    icon: "mdi:water"
    total:
    icon: "mdi:water"
    update_interval: 6s
found a working solution in this topic
and i used this code a user replied
  pin:
    number: GPIO4
    mode:
      input: true
      pullup: true
  update_interval : 5s
  pin:
    number: GPIO4
    mode:
      input: true
      pullup: true
  icon: "mdi:water"
  pin:
    number: GPIO4
    mode:
      input: true
      pullup: true
  name: "Water Liter Meter"
  icon: "mdi:water"
  total:
    name: "Water Meter Total"
    unit_of_measurement: "m³"
    accuracy_decimals: 3
    device_class: water
    state_class: total_increasing
    filters:
      - multiply: 0.001
  name: "Water Usage Total"
  accuracy_decimals: 0
  icon: "mdi:water"
  device_class: water
  lambda: return (id(water_meter_total_esp).state * 1000);
  update_interval: 10s
There are several issues with the instruction provided by Pieter. At least in my case. The indentation is incorrect. ESPhome does not allow to use Pins several times, anymore. On my NodeMCUv3 there is 3V on VIN but I could get 5V from VU. Anyhow, the sensor requires 6V minimum and does not work on 5V. I am now waiting for some step-up modules
Below the code I could at least flash:
  pin:
    number: GPIO12
    allow_other_uses: true
    mode:
      input: true
      pullup: true
  pin:
    number: GPIO12
    mode:
      input: true
      pullup: true
  icon: "mdi:water"
  total:
  pin:
    number: GPIO12
    mode:
      input: true
      pullup: true
  icon: "mdi:water"
  total:
    device_class: water
    filters:
      - multiply: 0.001
  icon: "mdi:water"
  update_interval: 6s
It works.
This is what I get in Home assistant:
Screenshot 2024-02-17 161420
The folowing sensors are not working:
-water pulse
-Water Total
-Water Usage Liter
