Hi team, first post here. I have a few automations set up, using the ‘leak detection and notifier’ which works great for all my water sensors, but doesnt have the right config.
basically what im looking to do is start with that, but set up a loop that resends notification every X minutes if sensor is still wet, as well as a critical on iOS (so i can get notified thru sleep focus).
ill give that a shot. for testing purposes ill use a specific sensor, but is there a way to have a list of water sensors feed into it? i dont want to hard code every sensor into this or dupe this x number of times. thanks!
I think there is a way to do that if they all have a similar entity ID but I haven’t used it.
You don’t need to repeat the automation, you can add the entity_IDs to the trigger and final condition. Are you planning on enough leak sensors that a small list is an issue?
platform: state
entity_id:
- binary_sensor.one
- binary_sensor.two
- binary_ sensor.etc
to: "on"
until:
- condition: state
entity_id:
- binary_sensor.one
- binary_sensor.two
state: "off"
