I’m new to HA and have been looking into the possibility of a water shutoff solution in the event of a pipe burst. I know this is an event that doesn’t occur often if at all. However, it’s still one I think should be possible in 2022 IoT automation.
Looking around the forum I don’t see much talked about on this subject, maybe the terminology I use to describe the problem. Does anyone have any working solutions with hardware recommendations ?
Thanks guys. Hardware is step one. Then step two is working out how to integrate into HA.
Currently I use a zigbee gateway from coinbee. Also have sensors via aqura. So the idea would be to have hardware this is zigbee supported and to find an already build hA intergration
