Water Tank Level and Water Volume with ESPHome
Thanks to @ walberjunior and everybody else that helped me to deal with this challenge.
History6– Home Assistant(1)
This is the result! I did some rectification into the formula (as 1 liter is equal to 10x10x10cm) and added one more sensor that is showing the percentage of the tank that is filled with water. Probably later, I’ll add one more sensor showing the percentage of the useful capacity, as there is a part of the tank that never is filled up and another that is never emptied due to precautions.
Here is my “sensors.yaml”, the “AJ_SR04M_Sensor.h” is unchanged as above post and I’m posting this hoping that somebody else will find it useful. I’ll come back in due time, when I’ll try to fit a LCD screen showing locally the measurements.
esphome:
  friendly_name: ESP32-sensors
  includes:
    - AJ_SR04M_Sensor.h
esp32:
  board: esp32dev
  framework:
    type: arduino
dallas:
  - pin: GPIO22
uart:
  tx_pin: GPIO32
  rx_pin: GPIO33
  baud_rate: 9600
  stop_bits: 1
  rx_buffer_size: 4
  - platform: custom
    lambda: |-
      auto my_sensor = new AJ_SR04M_Sensor(id(uart_bus));
      App.register_component(my_sensor);
      return {my_sensor};
    sensors:
     unit_of_measurement: cm
     accuracy_decimals: 1
#experiment
  - platform: custom
    lambda: |-
      return {my_sensor};
    sensors:
      unit_of_measurement: Ltrs
      name: "Tk Quantity"
      filters:
      - lambda: return ((235*143*(229 - x))/1000);
  - platform: custom
    lambda: |-
      return {my_sensor};
    sensors:
      unit_of_measurement: pct%
      name: "Tk space pct"
      filters:
      - lambda: return ((((235*143*(229 - x))/1000)/7695.5)*100);
#up to here
  - platform: dallas
    address: 0xea0722b0dcbabc28
  - platform: dallas
    address: 0xd30822b0f48ffd28
  - platform: dallas
    address: 0xa90722b0e5ac1328
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
  password: "xxxxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
  ssid: !secret wifi_ssid
captive_portal:
web_server:
  port: 80
globals:
  - id: last_state
    type: float
    restore_value: no
    initial_value: '0.0'
