Water Tank Level and Water Volume with ESPHome
That’s because you use pins you shouldn’t use :bulb:
(avoid any GPIO’s with red and yellow boxes and go for the double green :ok: instead)
It’s okay - no coding skills required as esphome has a “no code” approach :wink:
I have tried a lot of other couple of pins, results are the same on rebot.
If you have time and stamina, tell me which board, which gpios and wait for my feedback!
i have a ESP32-WROOM-32U, a ESP32-cam, a D1 ESP32 and few ESP8266
Did you check before that the lot of other pins you choose don’t (also) have limitations? I saw that that the link to the pinout reference also was posted in your other adventure thread 3 days ago (and today again).
Community guys helped a lot, somebody directed me to this guide for choosing GPIO. I have use even the same pins with them but with different results.
Tonight Im going to try tasmota on D1 and the one sensore in original mode.Really I dont know what eelse to try!
I also have the same problem did you get any solution of the fluctuations?
I used the hcsr04 and the jsn sr04t both have the same problem.
If you use the same pins (and yaml) you should be able to reproduce the setup from someone else.
Watch out because the D1 mini is a esp82xx which has other (and less) usable pins that the esp32 (‘classic’) you used before.
Sure? Any logs, yamls, wiring diagram etc.? :man_shrugging:
How to help us help you - or How to ask a good question
I did too and they work a treat with esphome :ok_hand:
Another point that I Have noticed for a responsive sensor is the grounding! ESP board and my particular sensor should have common source of power and grounding, not powering the sensor from the board or similar.
I have noticed that in oposited case the sensor is halting or freezing or delaying before updating measurements.
The issue of reset the pins tx/rx before giving measurements after reboot is there.
Now, D1 mini WROOM board, pins 22 and 21
uart:
  tx_pin: GPIO22
  rx_pin: GPIO21
  baud_rate: 9600
  stop_bits: 1
PS confusion is caused for my case, I’m posting as well to this thread which is related to my issues and some persons are posting both sides.
You can use 2 power sources, one for the esp and one for the sensor.
But you MUST wire all GNDs together.
You should send pics of your esp boards and wiring
This is the ESP32 cam that used to various tests, removed from a camera just for tests.
This is the ESP32-WROOM-32U that is intented to be used for my project (due to its external antena + dallas sensors)
This is the board of the sensor where is soldered 47KΩ resistor, activating low power serial mode as per this link
another clear view of the board with hook up cables Yellow=GND, Purple=5V, Green=Tx, Blue=Rx
Version of sensor is AJ-SR04M
This is how powering the boards, Im using this step down board only for the pins, no conversion of voltage. The pair green-brown on the left is 5v and the other pair coming from sensor board. Sensor Green/Tx==>GPIO21, Sensor Blue/Rx==>GPIO22, Ill post all config files on next post.
ESP32 wroom D1 mini in operation
Cables of 5v and sensor to the ESP32 wroom D1 mini
The sensor itself.
Next post my config files
Sensor is reporting every sec the measured distance although is not stable, I have seen more accurate, could be because of its position during the photo session.
/config/esphome/AJ_SR04M_Sensor.h
#include "esphome.h"
class AJ_SR04M_Sensor : public PollingComponent, public UARTDevice, public Sensor {
  public:
    AJ_SR04M_Sensor(UARTComponent *parent) : PollingComponent(1000), UARTDevice(parent) {}
    void update() override {
      byte frame[5];
      int pos = 0;
      float value = 0.0;
      //write(0x00); // Try this
      write(0x01); // Try this
      //write(0x01); // Try this
      while (available()) {
        frame[pos] = read();
        pos++;
        if (pos == 4) {
	  if ((frame[0] == 0xFF) && (frame[4] == 0x00) && (((frame[0] + frame[1] + frame[2]) & 0x00ff) == frame[3])){
            value = ((frame[1] << 8) + frame[2]) / 10.0;
            publish_state(value);
          break;
The page of the senor in previous post advising the use of
write(0x01);
write(0x0);
write(0x55);
have been tested with unstable and confusing results
esphome-web-a7f4a8.yaml
esphome:
  friendly_name: ESPHome Web a7f4a8
  includes:
    - AJ_SR04M_Sensor.h
uart:
  tx_pin: GPIO22
  rx_pin: GPIO21
  baud_rate: 9600
  stop_bits: 1
esp32:
  board: esp32dev
  framework:
    type: arduino
- platform: custom
  lambda: |-
    auto my_sensor = new AJ_SR04M_Sensor(id(uart_bus));
    App.register_component(my_sensor);
    return {my_sensor};
  sensors:
     unit_of_measurement: cm
     accuracy_decimals: 1
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
  password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "xxxxxxxxxxxx"
    password: "xxxxxxxxxxxxxxxxxxx"
captive_portal:
So this is my situation, its working but when the ESP board is rebooted I should removed one or both tx/rx pin before resuming reporting mesurements to ESPHome (not available is the message). In the logs is appearing nothing until the remove/re-insert the pins.
Then going back to measuring operation.
How are you powering this module?
Connect the esp32 via a USB cable and power the sensor using the pins on the esp32.
Use some program like Esp-Flaher to flash the firmware, wait until you get some readings, reset the esp32 using the button and post the log.
Measurements are taken in the shape of a cone. Then try to aim for a wall that doesn’t have any nearby obstacles.
My sensor is pretty constant, but for some reason it sends a measurement of approximately 2.xx meters, so I can only use it if the distance is less than 2 meters.
Log with some restart:
Using 'COM6' as serial port.
Connecting....
Detecting chip type... Unsupported detection protocol, switching and trying again...
Connecting......
Detecting chip type... ESP32
Connecting.........
Chip Info:
 - Chip Family: ESP32
 - Chip Model: ESP32-D0WDQ5 (revision 1)
 - Number of Cores: 2
 - Max CPU Frequency: 240MHz
 - Has Bluetooth: YES
 - Has Embedded Flash: NO
 - Has Factory-Calibrated ADC: YES
 - MAC Address: XX:XX:XX:XX:XX:XX
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
 - Flash Size: 4MB
 - Flash Mode: dio
 - Flash Frequency: 40MHz
Erasing flash (this may take a while)...
Chip erase completed successfully in 9.6s
Flash will be erased from 0x00001000 to 0x00005fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x0000e000 to 0x0000ffff...
Flash will be erased from 0x00010000 to 0x000f3fff...
Compressed 17088 bytes to 11848...
Writing at 0x00001000... (100 %)
Wrote 17088 bytes (11848 compressed) at 0x00001000 in 0.5 seconds (effective 271.6 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 129...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (129 compressed) at 0x00008000 in 0.0 seconds (effective 491.5 kbit/s)...
Compressed 8192 bytes to 47...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 787.0 kbit/s)...
Compressed 932304 bytes to 618748...
Writing at 0x00010000... (2 %)
Writing at 0x00019bc6... (5 %)
Writing at 0x00023075... (7 %)
Writing at 0x0002766a... (10 %)
Writing at 0x0002e744... (13 %)
Writing at 0x0003ab2a... (15 %)
Writing at 0x00040561... (18 %)
Writing at 0x000463ed... (21 %)
Writing at 0x0004bb5d... (23 %)
Writing at 0x00051555... (26 %)
Writing at 0x00056d34... (28 %)
Writing at 0x0005c4f6... (31 %)
Writing at 0x00061c9b... (34 %)
Writing at 0x0006738f... (36 %)
Writing at 0x0006cc6b... (39 %)
Writing at 0x000720bf... (42 %)
Writing at 0x000771c6... (44 %)
Writing at 0x0007c635... (47 %)
Writing at 0x000818a5... (50 %)
Writing at 0x00086975... (52 %)
Writing at 0x0008bac1... (55 %)
Writing at 0x00090c08... (57 %)
Writing at 0x00097401... (60 %)
Writing at 0x0009cf30... (63 %)
Writing at 0x000a269c... (65 %)
Writing at 0x000a79d4... (68 %)
Writing at 0x000accab... (71 %)
Writing at 0x000b200d... (73 %)
Writing at 0x000b767d... (76 %)
Writing at 0x000bcda4... (78 %)
Writing at 0x000c2715... (81 %)
Writing at 0x000c8370... (84 %)
Writing at 0x000cdcbb... (86 %)
Writing at 0x000d4caf... (89 %)
Writing at 0x000dee21... (92 %)
Writing at 0x000e45db... (94 %)
Writing at 0x000e9da4... (97 %)
Writing at 0x000ef2b6... (100 %)
Wrote 932304 bytes (618748 compressed) at 0x00010000 in 14.8 seconds (effective 502.4 kbit/s)...
Leaving...
Hard Resetting...
Hard resetting via RTS pin...
Done! Flashing is complete!
Showing logs:
[15:46:19][I][logger:262]: Log initialized
[15:46:19][C][ota:469]: There have been 0 suspected unsuccessful boot attempts.
[15:46:19][D][esp32.preferences:114]: Saving 1 preferences to flash...
[15:46:19][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[15:46:19][I][app:029]: Running through setup()...
[15:46:19][C][uart.arduino_esp32:077]: Setting up UART...
[15:46:19][    45][E][HardwareSerial.cpp:530] setRxBufferSize(): RX Buffer must be higher than 128.
[15:46:19]
[15:46:19][C][wifi:038]: Setting up WiFi...
[15:46:19][C][wifi:048]: Starting WiFi...
[15:46:19][C][wifi:049]:   Local MAC: XX:XX:XX:XX:XX:XX
[15:46:19][D][wifi:425]: Starting scan...
[15:46:19][D][sensor:094]: 'Distance': Sending state 32.30000 cm with 2 decimals of accuracy
[15:46:20][D][sensor:094]: 'Distance': Sending state 32.30000 cm with 2 decimals of accuracy
[15:46:20][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:21][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:22][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:23][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:23][D][sensor:094]: 'Distance': Sending state 226.20000 cm with 2 decimals of accuracy
[15:46:24][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:25][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:25][D][sensor:094]: 'Distance': Sending state 220.80000 cm with 2 decimals of accuracy
[15:46:26][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:26][D][wifi:440]: Found networks:
[15:46:26][D][wifi:485]:     Channel: 9
[15:46:26][D][wifi:486]:     RSSI: -50 dB
[15:46:26][D][wifi:485]:     Channel: 11
[15:46:26][D][wifi:486]:     RSSI: -74 dB
[15:46:26][D][sensor:094]: 'Distance': Sending state 230.70000 cm with 2 decimals of accuracy
[15:46:26][D][sensor:094]: 'Distance': Sending state 225.39999 cm with 2 decimals of accuracy
[15:46:27][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:27][C][wifi:379]:   Local MAC: XX:XX:XX:XX:XX:XX
[15:46:27][C][wifi:380]:   SSID: 'JUNIOR 2.4B'
[15:46:27][C][wifi:381]:   IP Address: 192.168.0.238
[15:46:27][C][wifi:383]:   BSSID: XX:XX:XX:XX:XX:XX
[15:46:27][C][wifi:384]:   Hostname: 'ultrasonic-sr04m'
[15:46:27][C][wifi:386]:   Signal strength: -52 dB ▂▄▆█
[15:46:27][C][wifi:390]:   Channel: 9
[15:46:27][C][wifi:391]:   Subnet: 255.255.255.0
[15:46:27][C][wifi:392]:   Gateway: 192.168.0.1
[15:46:27][C][wifi:393]:   DNS1: 192.168.0.6
[15:46:27][C][wifi:394]:   DNS2: 127.0.0.1
[15:46:27][D][wifi:566]: Disabling AP...
[15:46:27][C][web_server:116]: Setting up web server...
[15:46:27][C][ota:093]: Over-The-Air Updates:
[15:46:27][C][ota:094]:   Address: ultrasonic-sr04m.local:3232
[15:46:27][C][ota:097]:   Using Password.
[15:46:27][C][api:025]: Setting up Home Assistant API server...
[15:46:27][I][app:062]: setup() finished successfully!
[15:46:27][I][app:102]: ESPHome version 2023.6.3 compiled on Jul  3 2023, 15:37:57
[15:46:27][C][wifi:543]: WiFi:
[15:46:27][C][logger:301]: Logger:
[15:46:27][C][logger:302]:   Level: DEBUG
[15:46:27][C][logger:303]:   Log Baud Rate: 115200
[15:46:27][C][logger:305]:   Hardware UART: UART0
[15:46:27][C][uart.arduino_esp32:124]: UART Bus 1:
[15:46:27][C][uart.arduino_esp32:125]:   TX Pin: GPIO22
[15:46:27][C][uart.arduino_esp32:126]:   RX Pin: GPIO21
[15:46:27][C][uart.arduino_esp32:128]:   RX Buffer Size: 4
[15:46:27][C][uart.arduino_esp32:130]:   Baud Rate: 9600 baud
[15:46:27][C][uart.arduino_esp32:131]:   Data Bits: 8
[15:46:27][C][uart.arduino_esp32:132]:   Parity: NONE
[15:46:27][C][uart.arduino_esp32:133]:   Stop bits: 1
[15:46:27][C][captive_portal:088]: Captive Portal:
[15:46:27][C][web_server:161]: Web Server:
[15:46:27][C][web_server:162]:   Address: ultrasonic-sr04m.local:80
[15:46:27][C][mdns:108]: mDNS:
[15:46:27][C][mdns:109]:   Hostname: ultrasonic-sr04m
[15:46:27][C][api:138]: API Server:
[15:46:27][C][api:139]:   Address: ultrasonic-sr04m.local:6053
[15:46:27][C][api:141]:   Using noise encryption: YES
[15:46:27][D][sensor:094]: 'Distance': Sending state 31.80000 cm with 2 decimals of accuracy
[15:46:28][D][sensor:094]: 'Distance': Sending state 31.80000 cm with 2 decimals of accuracy
[15:46:29][D][sensor:094]: 'Distance': Sending state 31.80000 cm with 2 decimals of accuracy
[15:46:29][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:29][D][sensor:094]: 'Distance': Sending state 253.20000 cm with 2 decimals of accuracy
[15:46:30][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:31][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:32][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:32][D][sensor:094]: 'Distance': Sending state 238.89999 cm with 2 decimals of accuracy
[15:46:33][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:34][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:34][D][sensor:094]: 'Distance': Sending state 230.80000 cm with 2 decimals of accuracy
[15:46:35][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:35][D][sensor:094]: 'Distance': Sending state 225.39999 cm with 2 decimals of accuracy
[15:46:36][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:36][D][sensor:094]: 'Distance': Sending state 31.20000 cm with 2 decimals of accuracy
[15:46:37][D][sensor:094]: 'Distance': Sending state 31.20000 cm with 2 decimals of accuracy
[15:46:37][D][sensor:094]: 'Distance': Sending state 31.80000 cm with 2 decimals of accuracy
[15:46:38][D][sensor:094]: 'Distance': Sending state 31.80000 cm with 2 decimals of accuracy
[15:46:38][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:39][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:39][D][sensor:094]: 'Distance': Sending state 31.20000 cm with 2 decimals of accuracy
[15:46:40][D][sensor:094]: 'Distance': Sending state 31.20000 cm with 2 decimals of accuracy
[15:46:40][D][sensor:094]: 'Distance': Sending state 239.00000 cm with 2 decimals of accuracy
[15:46:41][D][sensor:094]: 'Distance': Sending state 31.20000 cm with 2 decimals of accuracy
[15:46:42][D][sensor:094]: 'Distance': Sending state 31.20000 cm with 2 decimals of accuracy
[15:46:43][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:43][D][sensor:094]: 'Distance': Sending state 31.20000 cm with 2 decimals of accuracy
[15:46:43][D][sensor:094]: 'Distance': Sending state 219.60001 cm with 2 decimals of accuracy
[15:46:44][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:45][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:46][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:47][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:47]ets Jun  8 2016 00:22:57
[15:46:47]
[15:46:47]rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[15:46:47]configsip: 0, SPIWP:0xee
[15:46:47]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[15:46:47]mode:DIO, clock div:2
[15:46:47]load:0x3fff0030,len:1184
[15:46:47]load:0x40078000,len:12784
[15:46:47]load:0x40080400,len:3032
[15:46:47]entry 0x400805e4
[15:46:47][I][logger:262]: Log initialized
[15:46:47][C][ota:469]: There have been 1 suspected unsuccessful boot attempts.
[15:46:47][D][esp32.preferences:114]: Saving 1 preferences to flash...
[15:46:47][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[15:46:47][I][app:029]: Running through setup()...
[15:46:47][C][uart.arduino_esp32:077]: Setting up UART...
[15:46:47][    55][E][HardwareSerial.cpp:530] setRxBufferSize(): RX Buffer must be higher than 128.
[15:46:47]
[15:46:47][C][wifi:038]: Setting up WiFi...
[15:46:47][C][wifi:048]: Starting WiFi...
[15:46:47][C][wifi:049]:   Local MAC: XX:XX:XX:XX:XX:XX
[15:46:48][D][wifi:425]: Starting scan...
[15:46:48][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:48][D][sensor:094]: 'Distance': Sending state 253.80000 cm with 2 decimals of accuracy
[15:46:49][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:50][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:51][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:52][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:53][D][sensor:094]: 'Distance': Sending state 31.00000 cm with 2 decimals of accuracy
[15:46:53][D][sensor:094]: 'Distance': Sending state 32.30000 cm with 2 decimals of accuracy
[15:46:54][D][sensor:094]: 'Distance': Sending state 32.30000 cm with 2 decimals of accuracy
esphome:
  includes:
    - AJ_SR04M_Sensor.h
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
  #level: VERBOSE #makes uart stream available in esphome logstream
  # baud_rate: 0 #disable logging over uart
api:
  encryption:
    key: "VYTgaWFYVhlT/nvxIEVD5/jBtUSUFoTKlHDX+Ng+6d8="
ota:
  password: "642bd5435ed5fdcbec13e61cf4e1cb00"
wifi:
  ap:
    ssid: "Us-Ha Fallback Hotspot"
    password: "mwASg1rbcEGo"
captive_portal:
web_server:
  port: 80
globals:
  - id: last_state
    type: float
    restore_value: no
    initial_value: '0.0'
uart:
  tx_pin: GPIO22 # echo/RX do SR04M  (verde)
  rx_pin: GPIO21 #trigger/TX do SR04M (amarelo)
  baud_rate: 9600
  stop_bits: 1
  rx_buffer_size: 4
  debug:
  - platform: custom
    lambda: |-
      return {my_sensor};
    sensors:
      accuracy_decimals: 2
Polling with 150 miliseconds:
  public:
    float last_state;
    float old_state;
    AJ_SR04M_Sensor(UARTComponent *parent) : PollingComponent(150), UARTDevice(parent) {}
      old_state = last_state;
      //ESP_LOGD("Start", "Last: %.2f", old_state);
      byte frame[4];
      int pos = 0;
      float value = 0.0;
      write(0x55); // Try this AJ_SR04M
      //write(0xFF); // Try this DYP-A12BNYTW-V1.0
        //ESP_LOGD("Hex", "Hex: %X", frame[pos]);
        //pos++;
        if (pos == 3) {
          //ESP_LOGD("Validation", "pos == 4");
          //if ((frame[0] == 0xFF) && (frame[4] == 0x00) && (((frame[0] + frame[1] + frame[2]) & 0x00ff) == frame[3])){
          if ((frame[0] == 0xFF) && (((frame[0] + frame[1] + frame[2]) & 0x00FF) == frame[3])) {
            //ESP_LOGD("Validation", "SUM");
            last_state = value;
            //ESP_LOGD("Start", "Last: %f", last_state);
          break;
        pos++;
If I filter the distance between 20cm and 2 meters:
  - platform: custom
    lambda: |-
      return {my_sensor};
    sensors:
      filters:
      - lambda: |-
            float MIN_VALUE = 20.0;
            float MAX_VALUE = 200.0;
            if (MIN_VALUE <= x && x <= MAX_VALUE) return x;
            else return {};
I removed a few words because the log was too big
[16:14:50]Sending  31.20000 cm
[16:14:51]Sending  31.20000 cm
[16:14:51]Sending  32.10000 cm
[16:14:52]Sending  32.10000 cm
[16:14:52]Sending  31.60000 cm
[16:14:53]Sending  31.60000 cm
[16:14:54]Sending  31.60000 cm
[16:14:55]Sending  31.60000 cm
[16:14:56]Sending  31.60000 cm
[16:14:57]Sending  31.60000 cm
[16:14:58]Sending  31.60000 cm
[16:14:59]Sending  32.90000 cm
[16:15:00]Sending  32.90000 cm
[16:15:01]Sending  32.90000 cm
[16:15:02]Sending  32.90000 cm
[16:15:03]Sending  32.90000 cm
[16:15:03]Sending  32.50000 cm
[16:15:04]Sending  32.50000 cm
[16:15:05]Sending  32.50000 cm
[16:15:06]Sending  32.50000 cm
[16:15:06]Sending  34.60000 cm
[16:15:07]Sending  34.60000 cm
[16:15:08]Sending  34.60000 cm
[16:15:09]Sending  34.60000 cm
[16:15:10]Sending  34.60000 cm
[16:15:11]Sending  34.60000 cm
[16:15:12]Sending  34.60000 cm
[16:15:13]Sending  34.60000 cm
[16:15:14]Sending  34.60000 cm
[16:15:15]Sending  34.60000 cm
[16:15:16]Sending  34.60000 cm
[16:15:17]Sending  34.60000 cm
[16:15:18]Sending  34.60000 cm
[16:15:19]Sending  34.60000 cm
[16:15:20]Sending  34.60000 cm
[16:15:21]Sending  34.60000 cm
[16:15:22]Sending  34.60000 cm
[16:15:23]Sending  34.60000 cm
[16:15:24]Sending  34.60000 cm
[16:15:25]Sending  34.60000 cm
[16:15:26]Sending  34.60000 cm
[16:15:27]Sending  34.60000 cm
[16:15:28]Sending  34.60000 cm
[16:15:29]Sending  34.60000 cm
[16:15:30]Sending  34.60000 cm
[16:15:31]Sending  34.60000 cm
[16:15:32]Sending  34.60000 cm
[16:15:33]Sending  34.60000 cm
[16:15:34]Sending  34.60000 cm
[16:15:35]Sending  34.60000 cm
[16:15:36]Sending  34.60000 cm
[16:15:37]Sending  34.60000 cm
[16:15:38]Sending  34.60000 cm
[16:15:39]Sending  34.60000 cm
[16:15:40]Sending  34.60000 cm
[16:15:41]Sending  34.60000 cm
[16:15:42]Sending  34.60000 cm
[16:15:43]Sending  34.60000 cm
[16:15:44]Sending  34.60000 cm
[16:15:45]Sending  34.60000 cm
[16:15:46]Sending  34.60000 cm
[16:15:47]Sending  34.60000 cm
[16:15:48]Sending  34.60000 cm
[16:15:49]Sending  34.60000 cm
[16:15:50]Sending  34.60000 cm
[16:15:51]Sending  34.60000 cm
[16:15:52]Sending  34.60000 cm
[16:15:52]Sending  37.80000 cm
[16:15:53]Sending  37.80000 cm
[16:15:54]Sending  37.80000 cm
[16:15:55]Sending  37.80000 cm
[16:15:55]Sending  38.20000 cm
[16:15:56]Sending  38.20000 cm
[16:15:57]Sending  38.20000 cm
[16:15:58]Sending  38.20000 cm
[16:15:59]Sending  38.20000 cm
[16:16:00]Sending  38.20000 cm
[16:16:01]Sending  38.20000 cm
[16:16:02]Sending  38.20000 cm
[16:16:03]Sending  38.20000 cm
[16:16:04]Sending  38.20000 cm
[16:16:05]Sending  38.20000 cm
[16:16:06]Sending  38.20000 cm
[16:16:07]Sending  38.20000 cm
[16:16:08]Sending  38.20000 cm
[16:16:09]Sending  38.20000 cm
[16:16:10]Sending  38.20000 cm
[16:16:10]Sending  38.60000 cm
[16:16:11]Sending  38.60000 cm
[16:16:12]Sending  38.60000 cm
[16:16:13]Sending  38.60000 cm
[16:16:14]Sending  38.60000 cm
[16:16:15]Sending  38.60000 cm
[16:16:16]Sending  38.60000 cm
[16:16:17]Sending  38.60000 cm
[16:16:18]Sending  38.60000 cm
[16:16:19]Sending  38.60000 cm
[16:16:20]Sending  38.60000 cm
[16:16:21]Sending  38.60000 cm
[16:16:22]Sending  38.60000 cm
[16:16:23]Sending  38.60000 cm
[16:16:24]Sending  38.60000 cm
[16:16:25]Sending  38.60000 cm
[16:16:26]Sending  38.60000 cm
[16:16:27]Sending  38.60000 cm
[16:16:27]Sending  40.30000 cm
[16:16:28]Sending  40.30000 cm
[16:16:29]Sending  40.30000 cm
[16:16:30]Sending  40.30000 cm
[16:16:31]Sending  40.30000 cm
[16:16:31]Sending  40.60000 cm
[16:16:32]Sending  40.60000 cm
[16:16:33]Sending  40.60000 cm
[16:16:34]Sending  40.60000 cm
[16:16:35]Sending  40.60000 cm
[16:16:36]Sending  40.60000 cm
[16:16:36]Sending  40.30000 cm
[16:16:37]Sending  40.30000 cm
[16:16:38]Sending  40.30000 cm
[16:16:39]Sending  40.30000 cm
[16:16:40]Sending  40.30000 cm
[16:16:41]Sending  40.30000 cm
[16:16:42]Sending  40.30000 cm
[16:16:43]Sending  40.30000 cm
[16:16:44]Sending  40.30000 cm
[16:16:45]Sending  40.30000 cm
[16:16:46]Sending  40.30000 cm
[16:16:47]Sending  40.30000 cm
[16:16:48]Sending  40.30000 cm
[16:16:49]Sending  40.30000 cm
[16:16:50]Sending  40.30000 cm
[16:16:51]Sending  40.30000 cm
[16:16:52]Sending  40.30000 cm
[16:16:53]Sending  40.30000 cm
[16:16:53]Sending  46.10000 cm
[16:16:54]Sending  46.10000 cm
[16:16:55]Sending  46.10000 cm
[16:16:56]Sending  46.10000 cm
[16:16:57]Sending  46.10000 cm
[16:16:58]Sending  46.10000 cm
[16:16:59]Sending  46.10000 cm
[16:17:00]Sending  46.10000 cm
[16:17:01]Sending  46.10000 cm
[16:17:02]Sending  46.10000 cm
[16:17:03]Sending  46.10000 cm
[16:17:04]Sending  46.10000 cm
[16:17:04]Sending  50.10000 cm
[16:17:05]Sending  50.10000 cm
[16:17:06]Sending  50.10000 cm
[16:17:07]Sending  50.10000 cm
[16:17:08]Sending  50.10000 cm
[16:17:09]Sending  50.10000 cm
First of all, How to get this log outpout? never seen such details in my case! I’ve changed yaml and sensor .h file to yours but not such details.
With ESP-Flasher:
I got those, I’m running the 12.1mb and reverting
Mini D1 has issues with com port driver in win10 and changing back to esp32 ESP32-WROOM-32U
Edit1.
ESP32-WROOM-32U connected to power source with usb cable then powering 5v/GND the sensor.
Using
tx_pin: GPIO32
rx_pin: GPIO33
Made yaml with these GPIO, compiled, saved as .bin files in new and legacy format.
New format is giving error message during installation (missing magic something), finished installation with legacy bin file. After that sensor working fine (as on previous experiments, after compilation/installation is fine)
Reseted using button of the ESP32 and her it is the log file.
[17:25:09]
[17:25:09]rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[17:25:09]configsip: 0, SPIWP:0xee
[17:25:09]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[17:25:09]mode:DIO, clock div:2
[17:25:09]load:0x3fff0030,len:1184
[17:25:09]load:0x40078000,len:12784
[17:25:09]load:0x40080400,len:3032
[17:25:09]entry 0x400805e4
[17:25:10][I][logger:262]: Log initialized
[17:25:10][C][ota:469]: There have been 6 suspected unsuccessful boot attempts.
[17:25:10][D][esp32.preferences:114]: Saving 1 preferences to flash...
[17:25:10][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[17:25:10][I][app:029]: Running through setup()...
[17:25:10][C][uart.arduino_esp32:077]: Setting up UART...
[17:25:10][    55][E][HardwareSerial.cpp:530] setRxBufferSize(): RX Buffer must be higher than 128.
[17:25:10]
[17:25:10][C][wifi:038]: Setting up WiFi...
[17:25:10][C][wifi:048]: Starting WiFi...
[17:25:10][C][wifi:049]:   Local MAC: xxxxxxxxxxxxxxxxxxxxx
[17:25:10][D][wifi:425]: Starting scan...
[17:25:10][D][sensor:094]: 'Distance': Sending state 51.40000 cm with 2 decimals of accuracy
[17:25:10][D][sensor:094]: 'Distance': Sending state 51.00000 cm with 2 decimals of accuracy
[17:25:11][D][sensor:094]: 'Distance': Sending state 51.40000 cm with 2 decimals of accuracy
[17:25:12][D][sensor:094]: 'Distance': Sending state 51.40000 cm with 2 decimals of accuracy
[17:25:13][D][sensor:094]: 'Distance': Sending state 51.40000 cm with 2 decimals of accuracy
[17:25:14][D][sensor:094]: 'Distance': Sending state 51.40000 cm with 2 decimals of accuracy
[17:25:15][D][sensor:094]: 'Distance': Sending state 51.40000 cm with 2 decimals of accuracy
[17:25:16][D][sensor:094]: 'Distance': Sending state 51.40000 cm with 2 decimals of accuracy
[17:25:16][D][wifi:440]: Found networks:
[17:25:16][I][wifi:484]: - 'xxxxxxxxxxxxx' (xxxxxxxxxxxxxxxxxxxxx) ▂▄▆█
[17:25:16][D][wifi:485]:     Channel: 6
[17:25:16][D][wifi:486]:     RSSI: -65 dB
[17:25:16][I][wifi:484]: - 'xxxxxxxxxxxxxxxx' (xxxxxxxxxxxxxxx) ▂▄▆█
[17:25:16][D][wifi:485]:     Channel: 9
[17:25:16][D][wifi:486]:     RSSI: -77 dB
[17:25:16][I][wifi:274]: WiFi Connecting to 'xxxxxxxxxxxxxxxxxx'...
[17:25:17][D][sensor:094]: 'Distance': Sending state 51.40000 cm with 2 decimals of accuracy
[17:25:17][I][wifi:557]: WiFi Connected!
[17:25:17][C][wifi:379]:   Local MAC: xxxxxxxxxxxxx
[17:25:17][C][wifi:380]:   SSID: 'xxxxxxxxxxxxx'
[17:25:17][C][wifi:381]:   IP Address: 192.168.xxx.xxx
[17:25:17][C][wifi:383]:   BSSID: xxxxxxxxxxxxxxxx
[17:25:17][C][wifi:384]:   Hostname: 'esp32-sensors'
[17:25:17][C][wifi:386]:   Signal strength: -63 dB ▂▄▆█
[17:25:17][C][wifi:390]:   Channel: 6
[17:25:17][C][wifi:391]:   Subnet: 255.255.255.0
[17:25:17][C][wifi:392]:   Gateway: 192.168.xxx.xxx
[17:25:17][C][wifi:393]:   DNS1: 192.168.xxx.xxx
[17:25:17][C][wifi:394]:   DNS2: 0.0.0.0
[17:25:17][C][web_server:116]: Setting up web server...
[17:25:17][C][ota:093]: Over-The-Air Updates:
[17:25:17][C][ota:094]:   Address: esp32-sensors.local:3232
[17:25:17][C][ota:097]:   Using Password.
[17:25:17][W][ota:103]: Last Boot was an unhandled reset, will proceed to safe mode in 4 restarts
[17:25:17][C][api:025]: Setting up Home Assistant API server...
[17:25:17][I][app:062]: setup() finished successfully!
[17:25:17][I][app:102]: ESPHome version 2023.6.3 compiled on Jul  4 2023, 17:17:46
[17:25:17][C][wifi:543]: WiFi:
[17:25:17][C][wifi:379]:   Local MAC: xxxxxxxxxxxxxxxx
[17:25:17][C][wifi:381]:   IP Address: 192.168.zzz.zzz
[17:25:17][C][wifi:383]:   BSSID: zzzzzzzzzzzzzzzzzzzz
[17:25:17][C][wifi:392]:   Gateway: 192.168.zzz.zzz
[17:25:17][C][wifi:393]:   DNS1: 192.168.zzz.zzz
[17:25:17][C][logger:301]: Logger:
[17:25:17][C][logger:302]:   Level: DEBUG
[17:25:17][C][logger:303]:   Log Baud Rate: 115200
[17:25:18][C][logger:305]:   Hardware UART: UART0
[17:25:18][D][sensor:094]: 'Distance': Sending state 51.40000 cm with 2 decimals of accuracy
[17:25:18][C][uart.arduino_esp32:124]: UART Bus 1:
[17:25:18][C][uart.arduino_esp32:125]:   TX Pin: GPIO32
[17:25:18][C][uart.arduino_esp32:126]:   RX Pin: GPIO33
[17:25:18][C][uart.arduino_esp32:128]:   RX Buffer Size: 4
[17:25:18][C][uart.arduino_esp32:130]:   Baud Rate: 9600 baud
[17:25:18][C][uart.arduino_esp32:131]:   Data Bits: 8
[17:25:18][C][uart.arduino_esp32:132]:   Parity: NONE
[17:25:18][C][uart.arduino_esp32:133]:   Stop bits: 1
[17:25:18][C][captive_portal:088]: Captive Portal:
[17:25:18][C][web_server:161]: Web Server:
[17:25:18][C][web_server:162]:   Address: esp32-sensors.local:80
[17:25:18][C][mdns:108]: mDNS:
[17:25:18][C][mdns:109]:   Hostname: esp32-sensors
[17:25:18][C][ota:093]: Over-The-Air Updates:
[17:25:18][C][ota:094]:   Address: esp32-sensors.local:3232
[17:25:18][C][ota:097]:   Using Password.
[17:25:18][W][ota:103]: Last Boot was an unhandled reset, will proceed to safe mode in 4 restarts
[17:25:18][C][api:138]: API Server:
[17:25:18][C][api:139]:   Address: esp32-sensors.local:6053
[17:25:18][C][api:141]:   Using noise encryption: YES
[17:25:19][D][sensor:094]: 'Distance': Sending state 51.40000 cm with 2 decimals of accuracy
[17:25:19][D][api:102]: Accepted 192.168.zzz.zzz
[17:25:19][D][api.connection:1030]: Home Assistant 2023.6.3 (192.168.zzz.zzz): Connected successfully
After a power switch off, the board is turning off (of course).
When reconnecting power, the sensor is not reporting anything, only if removing one of the rx/tx pins (or both) then is commencing measurements.
OMG, after 40-50 seconds is starting! let me capture logs
Edit1 The above is triggered when enabling the “view logs” of the ESP flasher!!! only that moment the Home assistant is commencing receiving data and measurements.
In my eyes, it seems that the sensor is working fine, for whatever reason the communication between sensor and ESPHome/Home assistant is broken after a reboot/power outage.
When turning on the logging in ESP flasher is the kick start of communication (or removing the pin tx/rx)
This is the problem!!!
It’s not clear to me what you are doing.
Do not power off the esp, just reset using the button while the esp is connected to the ESP-Flasher and post the log.
If you get readings after the reset the sensor is working and the problem could just be the reconnection between esp(API) and HA.
How did you power the esp?
As advised, by usb cable and the sensor from 5V/GND of the ESPboard.
At these stage I’m sure that is not something related to the sensor but to the communication of the board/ESPHome-Home assistant.
Im insisting on reboot issue, as the place that I want to install it is not easily accessible and frequent interruptions of power were observed.
Could you help me how to add a “sensor” where the “Distance” will be translated into “Liters” (capacity). Its an underground tank of water with dimensions 2,35 x 1,43 x 2,29 mtrs?
Therefore, it is necessary to eliminate some problems:
1 - Esp and sensors powered by USB and close to the router.
Are all the sensors sending the readings (looking in the logs)?
Does esp reconnect to HA? Even if it takes a longer time for that to happen.
Everything is OK? Next step…
2 - Connect the esp and sensors using the power supply that you will use in the final project, but close to the router.
No? Change the power supply. I use jumper wires, but they also give a lot of problems.
3 - Everything ok, but when you take the project to the final destination, it doesn’t work.
Probably the network signal is not good.
