1 - Esp and sensors powered by USB and close to the router.
Are all the sensors sending the readings (looking in the logs)?
Does esp reconnect to HA? Even if it takes a longer time for that to happen.
Everything is OK? Next step…
At this stage dallas (x3) sensors have been removed although without issues after (each) reboot. I had readings for the temperature and updats regularly.
Wifi coverage is fine all around the house (Ubiquiti AP) except the “engine room” space where is the underground tank and the hot water tank along with machinery.
ESP board is conned to ESPHome, from there I can see the readings and the logs (until today that realized that I can see the same from ESP flasher). After all this adventure and trials of today, most of the times (after reboot) I have readings in the board’s page. If not then turning on the logger of ESP flasher (if connected to this pc) and resuming the operation (or removing and reinserting any of the TX/Rx pins).
My observations are 1) sensor board flashing blue immediately after reboot despite f having or not having reading, something that wasn’t happening before 2) accuracy with these settings are slightly worst than before. Just now measuring 82.6 cm in an actual distance of 85 cm (not big deal) 3)I have seen messages of “safe boot” mode after reaching a number of reboots, as well
2 - Connect the esp and sensors using the power supply that you will use in the final project, but close to the router.
No? Change the power supply. I use jumper wires, but they also give a lot of problems.
Results are not different with the other source of power or USB. The random stall/delay is there.
3 - Everything ok, but when you take the project to the final destination, it doesn’t work.
Probably the network signal is not good.
Not even the smallest chance this issue related to the wifi coverage, could be anything else but not this as the wifi is very powerful in my home lab where Im here.
Could you help me how to add a “sensor” where the “Distance” will be translated into “Liters” (capacity). Its an underground tank of water with dimensions 2,35 x 1,43 x 2,29 mtrs?
This
