Water temperature tube sensor
I have a sensor in my garage running ESPHome. It has the normal DHT22. I installed it to the outside of a copper pipe to measure the temperature of the watter running through my hose. The copper pipe was put inbetween the hose to beter measure the temperature.
It works but it is to slow. Does anyone know of a sensor I can put inbetween a hose in direct contact with the water and works with ESPHome?
thanks!
Greetings,
Aaron
I’d look for a waterproof version of 1-wire sensor DS18B20. They are cheap and pretty accurate.
Hi @der-optimist ,
Thanks for the reply. So one of these would work? 10Pcs Plr DS18B20 Temperatuur Sensor Module Kit Waterdichte 100Cm Digitale Sensor Kabel Roestvrij Stalen Sonde Terminal Adapter|Sensors| - AliExpress
greetings,
Aaron
Yes that’s the one. Though that link is for 10 of them.
Hi @tom_l
Then I will have some spare ones :rofl:
Thanks,
Aaron
