Neither Firefox nor Chrome can open the HAR file here… What browser did you use?
I don’t mean i have problem with the Zip file but the HAR file inside seems corrupt…
Did you rerecord it or send the same file again?
Could you load the HAR file in your browser successfully?
Errors found when processing the HAR file:
Unable to process the HAR file: SyntaxError: JSON.parse: end of data while reading object contents at line 14808 column 13 of the JSON data
I used Chrome. I sent the same file. When recoording, how long do i have to stay on each screen? Could that be the problem? EasyCon takes several seconds for updateing … I’ll record a new one. I followed the steps in the tutorial … Sorry for the cirumstances …
You only need to wait for it to finish loading.
I actually manually opened the file and you can see that it just stops mid request.
So for some reason it wasn’t saved completely, maybe the page was still loading… idk
We are getting there, but unfortunately by deleting the protocol after each page you removed all the interesting data
I need to see the responses as well.
Also I understand now what you mean by page was still loading. Its polling there for a long time but that is not important.
As soon as you can see the values in the browser it is good enough.
I suggest to start in an incognito window and then do as follow:
Login
Go to all the pages , when data is visible and the page appears to be complete take a screen shot.
repeat for all 3 mixing circuites
log out and press stop in the browser to stop all background activity
This should create a full recording.
You can validate by loading the HAR fiel again and check a few of the entries in the beginning and end and make sure the have response data (you can see text or html rendering there).
Hello again. I really struggled with the har file. Either it couldn’t be opened or there were no response data in chrome. Now i used Firefox and eg. in tags with stauts 200 i could see response data, after importing the file to firefox. The har file took very long to open. I hope this is what we need.
I’m really not sure what your computer is doing
It took ages in firefox and crashed after a few minutes, Chrome flatout refused to load it.
But I managed to use some google tools to load it and it seems to have the data in there i need. I’ll try to find some time this week to add it.
While adding more values I came across the Monthly Energy usage screen.
I found that the Heatpump it storing the value for each month separately and you can get them at any time.
However it would be 7*12 Tags to query and I think its not necessary to refresh them all the time. I’m thinking of adding a service that could query those on demand.
Any opinions on this?
Hello everyone! I have an issue with the integration. I have an Ecotouch Ai1 5009.5 heat pump with the 2.4.1 Easycon version, and when trying to log in, it says “Username/Password is wrong.” I can access it without any problem through the mobile app and via the browser. I’ve tried both the master version and version 0.11, and I always encounter the same problem. Do you know the solution? THANK YOU VERY MUCH.
Did you set the correct password? I think by default all of them use “waterkotte”/“waterkotte” but you can change it…
If you create a HAR file of the login in your browser I can have a look if there is something different…
Also make sure you use the correct method (EasyCon/EasyTouch)
I released version 0.1.00.
It contains the mixing circles although I couldn’t really test them.
There are also 2 services to query energy consumption data.
Make sure you do not have the any other connections open, e.G. close the app in the browser and/or mobile and let the integration retry. It might take a couple of minutes for the old connections to expire as the apps don’t do a logout.
