Hi Michael,
as promised i’ve tried to install your integration through HACS. Installation was without any problems, but adding it through integration and + afterwards, the integration assistant always seem to be stuck for me with the following screen:
“Please wait, the configurationassistant for Waterkotte Heatpump will be started” with a loading circle
I’ve restarted Homeassistant several times but to no avail.
Do you got any idea, what might be wrong here?
Edit: My fault, i’ve restarted HA again and this time it worked. Thanks a lot!
How is your experience with the connection to the waterkotte itself? Very often i get unavailable status but after some time some values again. I get the feeling that the Waterkotte WebUI is not very stable and responsive and might be the culprit here.
Thanks in advance
