Waterkotte Heatpump Integration
This is for the Remote Box, in the screen only appears the ip and the password for the heatpump
I have had Waterkotte integration for a year, before everything worked OK. Unfortunately, after the update it stopped working. I turned on cebug logging and got the following results:
024-01-04 11:49:14.456 DEBUG (MainThread) [custom_components.waterkotte_heatpump] read_values: tags: ['I32', 'I30', 'A10', 'I1252', 'D420', 'A38', 'I1256', 'A11', 'I137', 'I1253', 'I135', 'I138', 'A1', 'I139', 'I1251', 'I1257', 'A6', 'A7', 'A3', 'A12', 'I1259', 'I1255', 'I51', 'A16', 'A2', 'I1258', 'A19', 'A14', 'I1254', 'A109', 'I31', 'A4', 'I1250', 'I263', 'A5']
2024-01-04 11:49:14.456 DEBUG (MainThread) [custom_components.waterkotte_heatpump] read_values: values: {'I32': '1', 'I30': '1', 'A10': '334.0', 'I1252': '29', 'D420': '0', 'A38': '500.0', 'I1256': '1', 'A11': '327.0', 'I137': '1', 'I1253': '1', 'I135': '0', 'I138': '4', 'A1': '71.0', 'I139': '0', 'I1251': '59', 'I1257': '31', 'A6': '0.0', 'A7': '0.0', 'A3': '67.0', 'A12': '356.0', 'I1259': '23', 'I1255': '20', 'I51': '14', 'A16': '338.0', 'A2': '71.0', 'I1258': '1', 'A19': '452.0', 'A14': '368.0', 'I1254': '23', 'A109': '200.0', 'I31': '1', 'A4': '60.0', 'I1250': '0', 'I263': '7', 'A5': '0.0'}
Unfortunately, the state of the entity is still unknown. How to fix the problem?
Unfortunately that doesn’t give me much as there is no error.
What exactly is not working?
From which version did you update?
Can you try to remove and add the integration again fresh?
Still everything works! Wonderful! Just one little detail is missing …
Do you see a change to find the values for
Waterkotte Heatpump Temperature Mixing1
Waterkotte Heatpump Temperature Mixing2
Waterkotte Heatpump Temperature Mixing3
its still status ā€œunknownā€.
Can you run with debug log enabled and reload the component?
I have looked at those values a few times now and it should work but I can’t get them on mine to test…
Also just to make sure there is nothing weird going on with the configuration, can you first remove the integration, restart and then read it?
I hope this’ll help. Thanks a lot in advance!!!
I’m busy with life at the moment but also couldn’t really see anything wrong.
I think the only way forward would be if you could let me login to your system remotely to debug. PM me if you are open for this.
Hi, since update to HA Core 2025.5. i“ve got the following error message:
  • HomeAssistantType was used from waterkotte_heatpump, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.HomeAssistant instead, please report it to the author of the ā€˜waterkotte_heatpump’ custom integration
  • HomeAssistantType was used from waterkotte_heatpump, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.HomeAssistant instead, please create a bug report at https://github.com/pattisonmichael/waterkotte-heatpump/issues
Any Solution?
I’m no longer maintaining this integration. Somebody else forked it. Please use that version.
ok, thank you!
