Hi Marcel,
How is your S0PCM implementation in HA holding up? I’m in the process of switching from Domoticz to HA but this S0PCM is holding me down. I use 4 of the 5 channels (Water, 2x PV, EV-charger).
Hi Marcel,
Is the topicstarter in am using the S0pcm over some time without any issues. I am using the docker which is working completely stable.
But;
My readings are most of the times way to high. In a normal day using 500-1000 liter of water, it does not seems to be correct. How does this compare to you guys ? And how do I change it?
Sorry I missed your question. I am using the S0PCM5 for almost a year now. I do miss pulses now and then, so I made a habit of checking the readings on a regular basis. Sometimes the values are in sync for weeks, and suddenly I miss (quite) a few kWh…
Therefore I made a dashboard to correct the meter values easily from my phone. I used the HACS frontend card ‘Numberbox card’, where you can increase (and decrease) a value by pressing a button. The step-size I have put in a helper, because sometimes you want to correct with 0.1, and sometimes with 0.01
I tried the standard input method, but the keypad covers all readings on the phone screen, making the adjustment a big fuzz. With this card you can do it with one hand (in the other i have a flashlight to be able to read the meter values)
If you are interested. let me know and I’ll share all the info
Marcel
PS. Still haven’t water readings added. I need to 3D-print a sensor mount for the water meter, as the induction sensor doesn’t work with my water meter. I’m reverting to a LED/sensor to detect the passing of the mirror. But I have so many other things to do, too…
