Hi, I have a watermeter pulse counter which I created a while ago. Now when I restart the ESP I have to manually (re)set the measured value. It goes back to the initial value which it was set to before and looses the counted values during last runtime. This is the relevant config.
how can I get the counted value also after reset or power failure (I take the risk of loosing pulses during power failures since I can manually call the service after that.
Via HA: # HA - Developer Tools - Services - ESPHome: meter_water - set value with point
api:
services:
- service: meter_water
variables:
meter_value: float
then:
- globals.set:
value: !lambda "return ( meter_value ) ;"
globals:
- id: totalWaterUsage
type: float
restore_value: yes
#------------------------# Watermeter #------------------------#
name: "Water Consumption Now"
accuracy_decimals: 1
unit_of_measurement: "L/min"
icon: "mdi:water"
lambda: return (id(watermeter_pulse).state);
update_interval: 2s
# watermeter pulses #
- platform: pulse_meter
pin:
number: GPIO21
inverted: true
mode:
input: true
pullup: true
state_class: measurement
internal: true
internal_filter_mode: PULSE
timeout: 10s
# WaterMeter Total - m3 #
total:
name: "Watermeter Total (since start ESP)"
icon: "mdi:cube-outline"
state_class: "total_increasing"
unit_of_measurement: "m3"
accuracy_decimals: 3
filters:
- multiply: 0.001
internal: true
update_interval: 1s
lambda:
return id(totalWaterUsage) + id(sensor_pulse_meter_total).state;
time:
- platform: homeassistant
