Watermeterkit no water usage measuring
I bought the watermeterkit and initially everything worked fine. But at some point the actual water usage was not measured anymore. It seemed the watermeter sensor does not function anymore. If I try to trigger it manual with a magnet nothing happens and no red light is blinking.
I got a replacement unit which worked initially fine, but I am now experiencing the same problem.
All other sensors of the watermeterkit are working fine. In homeassistant it is integrated without errors. The ESPhome is upgraded towards the latest firmware.
Anybody has an idea what could be wrong. Is it a hardware or software failure?
well, it looks like its not sending data/updates. Assuming this is a semi commercial product? You are probably best contacting the people that sold it. I have built my own using an ESP board and troubleshooting devices can be tricky because they don’t have a lot of memory to save an logs or crash / dump files.
