I get these errors when trying to add the 800 series with the dev branch
This error originated from a custom integration.
Logger: homeassistant.setup
Source: custom_components/wattbox/__init__.py:105
Integration: WattBox (documentation, issues)
First occurred: 7:51:23 PM (1 occurrences)
Last logged: 7:51:23 PM
Error during setup of component wattbox
File "/usr/local/lib/python3.10/asyncio/selector_events.py", line 862, in _read_ready__data_received
data = self._sock.recv(self.max_size)
ConnectionResetError: [Errno 104] Connection reset by peer
File "/usr/local/lib/python3.10/site-packages/httpcore/_exceptions.py", line 10, in map_exceptions
yield
File "/usr/local/lib/python3.10/site-packages/httpcore/backends/asyncio.py", line 34, in read
return await self._stream.receive(max_bytes=max_bytes)
File "/usr/local/lib/python3.10/site-packages/anyio/_backends/_asyncio.py", line 1274, in receive
raise self._protocol.exception
anyio.BrokenResourceError
File "/usr/local/lib/python3.10/site-packages/httpx/_transports/default.py", line 60, in map_httpcore_exceptions
yield
File "/usr/local/lib/python3.10/site-packages/httpx/_transports/default.py", line 353, in handle_async_request
resp = await self._pool.handle_async_request(req)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection_pool.py", line 253, in handle_async_request
raise exc
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection_pool.py", line 237, in handle_async_request
response = await connection.handle_async_request(request)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection.py", line 90, in handle_async_request
return await self._connection.handle_async_request(request)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/http11.py", line 112, in handle_async_request
raise exc
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/http11.py", line 91, in handle_async_request
) = await self._receive_response_headers(**kwargs)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/http11.py", line 155, in _receive_response_headers
event = await self._receive_event(timeout=timeout)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/http11.py", line 191, in _receive_event
data = await self._network_stream.read(
File "/usr/local/lib/python3.10/site-packages/httpcore/backends/asyncio.py", line 31, in read
with map_exceptions(exc_map):
File "/usr/local/lib/python3.10/contextlib.py", line 153, in __exit__
self.gen.throw(typ, value, traceback)
File "/usr/local/lib/python3.10/site-packages/httpcore/_exceptions.py", line 14, in map_exceptions
raise to_exc(exc)
httpcore.ReadError
File "/usr/src/homeassistant/homeassistant/setup.py", line 256, in _async_setup_component
result = await task
File "/config/custom_components/wattbox/__init__.py", line 105, in async_setup
hass.data[DOMAIN_DATA][name] = await async_create_http_wattbox(
File "/usr/local/lib/python3.10/site-packages/pywattbox/http_wattbox.py", line 239, in async_create_http_wattbox
return await _async_create_wattbox(
File "/usr/local/lib/python3.10/site-packages/pywattbox/base.py", line 115, in _async_create_wattbox
await wattbox.async_get_initial()
File "/usr/local/lib/python3.10/site-packages/pywattbox/http_wattbox.py", line 38, in async_get_initial
response = await client.get(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1757, in get
return await self.request(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1533, in request
return await self.send(request, auth=auth, follow_redirects=follow_redirects)
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1620, in send
response = await self._send_handling_auth(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1648, in _send_handling_auth
response = await self._send_handling_redirects(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1685, in _send_handling_redirects
response = await self._send_single_request(request)
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1722, in _send_single_request
response = await transport.handle_async_request(request)
File "/usr/local/lib/python3.10/site-packages/httpx/_transports/default.py", line 352, in handle_async_request
with map_httpcore_exceptions():
File "/usr/local/lib/python3.10/site-packages/httpx/_transports/default.py", line 77, in map_httpcore_exceptions
raise mapped_exc(message) from exc
httpx.ReadError
Source: setup.py:363
First occurred: 7:51:23 PM (3 occurrences)
Unable to prepare setup for platform wattbox.binary_sensor: Unable to set up component.
Unable to prepare setup for platform wattbox.sensor: Unable to set up component.
Unable to prepare setup for platform wattbox.switch: Unable to set up component.
