fabkins
(Fabkins)
September 2, 2024, 10:57am
1
I cannot seem to get the Waveshare 4.3 ESP32 touch display to display anything. I am using the RPI_DPI_RGB driver using the provided settings for Waveshare. I have this display working fine under VS Code and have double checked the pin configuration for that and they are identical as that in ESPHome YAML.
I originally had LVGL and the touch configured but for diagnostics stripped it down to bare minimum. So the code above the “display” section is vanilla config with the exception I changed the platform type from arduino to esp-idf. It uploads, i can visit the device’s web page. It just doesn’t seem to do anything with the display.
I assume the Lambda function would display something after display setup. I’m really new to ESPHome so I could be doing something silly. I’ve attached the YAML I used.
Help ?
substitutions:
friendly_name: Control Panel
esphome:
friendly_name: ${friendly_name}
min_version: 2024.6.0
name_add_mac_suffix: false
platformio_options:
board_build.flash_mode: dio
project:
version: dev
esp32:
board: esp32-s3-devkitc-1
framework:
type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
- platform: esphome
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
# Set up a wifi access point
ap: {}
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
dashboard_import:
package_import_url: github://esphome/firmware/esphome-web/esp32s3.yaml@main
import_full_config: true
# Sets up Bluetooth LE (Only on ESP32) to allow the user
# to provision wifi credentials to the device.
esp32_improv:
authorizer: none
# To have a "next url" for improv serial
web_server:
display:
- platform: rpi_dpi_rgb
auto_clear_enabled: false
color_order: RGB
pclk_frequency: 16MHz
dimensions:
width: 800
height: 480
de_pin:
number: 5
hsync_pin:
number: 46
ignore_strapping_warning: true
vsync_pin:
number: 3
pclk_pin: 7
hsync_back_porch: 30
hsync_front_porch: 210
hsync_pulse_width: 30
vsync_back_porch: 4
vsync_front_porch: 4
vsync_pulse_width: 4
data_pins:
red:
- 1 #r3
- 2 #r4
- 42 #r5
- 41 #r6
- 40 #r7
blue:
- 14 #b3
- 38 #b4
- 18 #b5
- 17 #b6
- 10 #b7
green:
- 39 #g2
- 0 #g3
- 45 #g4
- 48 #g5
- 47 #g6
- 21 #g7
lambda: |-
auto black = Color(0, 0, 0);
auto red = Color(255, 0, 0);
auto green = Color(0, 255, 0);
auto blue = Color(0, 0, 255);
auto white = Color(255, 255, 255);
it.filled_circle(20, 32, 15, black);
it.filled_circle(40, 32, 15, red);
it.filled_circle(60, 32, 15, green);
it.filled_circle(80, 32, 15, blue);
it.filled_circle(100, 32, 15, white);
fabkins
(Fabkins)
September 2, 2024, 4:14pm
2
Ok, I found an example on this thread from @Jon_2232 :
After a few flashes/toying with settings I was able to get it to stop flickering too, at least with the RGB BW fill in Real.Problems post.
Tried adding image or graph display components and maybe I missed having to add an include or something for it?
Linking .pioenvs/waveshare44/firmware.elf
/data/cache/platformio/packages/[email protected] +2021r2-patch5/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld: .pioenvs/waveshare44/src/esphome/components/disp…
I couldn’t get it to compile initially. The item that seem to give a display was:
psram:
mode: octal
speed: 80MHz
But I had a lot of corruption and the synch didnt seem to be quite right. I think the corruption was probably due to where ever memory was being used wasnt a great place.
I used my timing settings and then folded in Jon’s code and got it to compile and it is displaying his clock demo.
This is what my code looks like now:
substitutions:
esphome:
platformio_options:
build_flags: "-DBOARD_HAS_PSRAM"
board_build.arduino.memory_type: qio_opi
board_upload.maximum_ram_size: 524288
project:
version: dev
esp32:
framework:
type: esp-idf
sdkconfig_options:
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: y
CONFIG_ESP32S3_DATA_CACHE_64KB: y
CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
CONFIG_SPIRAM_RODATA: y
psram:
mode: octal
speed: 80MHz
# Enable logging
logger:
api:
ota:
- platform: esphome
improv_serial:
wifi:
ap: {}
captive_portal:
dashboard_import:
esp32_improv:
authorizer: none
web_server:
i2c:
sda: GPIO08
scl: GPIO09
scan: True
display:
color_order: RGB
update_interval: never
dimensions:
width: 800
height: 480
de_pin:
number: 5
hsync_pin:
number: 46
vsync_pin:
number: 3
pclk_pin: 7
pclk_inverted: true
hsync_back_porch: 40 #30
hsync_front_porch: 20 #210
hsync_pulse_width: 1 #30
vsync_back_porch: 8 #4
vsync_front_porch: 4 #4
vsync_pulse_width: 1 #4
data_pins:
red:
- 1 #r3
- 2 #r4
- 42 #r5
- 41 #r6
- 40 #r7
blue:
- 14 #b3
- 38 #b4
- 18 #b5
- 17 #b6
- 10 #b7
green:
- 39 #g2
- 0 #g3
- 45 #g4
- 48 #g5
- 47 #g6
- 21 #g7
font:
- file: "gfonts://Roboto"
touchscreen:
platform: gt911
interrupt_pin: GPIO4
on_touch:
- lambda: |-
ESP_LOGI("cal", "x=%d, y=%d, x_raw=%d, y_raw=%0d",
touch.x,
touch.y,
touch.x_raw,
touch.y_raw
external_components:
- source: github://pr#6363
refresh: 0min
components: [lvgl]
lvgl:
displays:
- display_id: my_display
buffer_size: 25%
pages:
- id: clock_page
widgets:
- obj: # Clock container
height: size_content
width: 800 #240
align: CENTER
pad_all: 0
border_width: 0
bg_color: 0xFFFFFF
widgets:
- meter: # Clock face
height: 400 #220
width: 400 #220
align: center
bg_opa: TRANSP
text_color: 0x000000
scales:
- ticks: # minutes scale
width: 1
count: 61
length: 10
color: 0x000000
range_from: 0
range_to: 60
angle_range: 360
rotation: 270
indicators:
- line:
width: 3
color: 0xa6a6a6
r_mod: -4
value: 0
- ticks: # hours scale
width: 1
count: 12
length: 1
major:
stride: 1
width: 4
length: 8
color: 0xC0C0C0
label_gap: 12
angle_range: 330
rotation: 300
range_from: 1
range_to: 12
- indicators:
- line:
width: 5
color: 0xa6a6a6
r_mod: -30
value: 0
angle_range: 360
rotation: 270
range_from: 0
range_to: 720
time:
- platform: homeassistant
interval:
- interval: 30s
then:
if:
condition:
time.has_time:
then:
- script.execute: time_update
script:
- id: time_update
then:
- lvgl.indicator.update:
value: !lambda |-
return id(time_comp).now().minute;
value: !lambda |-
auto now = id(time_comp).now();
return std::fmod(now.hour, 12) * 60 + now.minute;
It’s basically Jon’s code, I dont know if I return the timings to his it would be any different. Anyhow, I consider this solved.
andrew_NH
(Andrew)
September 3, 2024, 2:30am
3
Here are a few other compiler options you can try to speed up the psram
esp32:
variant: esp32s3
flash_size: 16MB
framework:
type: esp-idf
sdkconfig_options:
COMPILER_OPTIMIZATION_SIZE: y
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
psram:
mode: octal
speed: 80MHz
fabkins
(Fabkins)
September 3, 2024, 11:36am
4
Thanks Andrew, I’ve added those settings in.
Out of interest do you have issues with doing wifi updates? It seems really slow, so slow that it disconnects, or its really fast. I often have to do reboot it just before I’m about to upload.
I’ve even had to resort to putting the board back to initial settings. It’s as if when running it cant process the connection.
andrew_NH
(Andrew)
September 3, 2024, 3:30pm
5
I don’t have one of those screens. But I do have the a similar screen (sunton-esp32-8048s070) and I don’t have issues with upgrades.
zaidor
(osmani)
September 20, 2024, 2:49pm
6
Hi @fabkins
Thank you for your post. I have the very same screen and I’ve been struggling to make it show something for a few months now. Your code make it work!
I am having the same issue where wifi updates are really slow and fail due to time out. Did you find out a solution to that problem? If not, what is exactly that you mean by “putting the board back to initial settings”?
andrew_NH
(Andrew)
September 22, 2024, 4:11am
7
I have heard of some of these screens sharing the Wi-Fi pin with other hardware. This causes lot’s of issues with Wi-Fi updates. In this case you may have to update via USB.
You may want to look into using a different screen.
clydebarrow
(Clyde Stubbs)
September 22, 2024, 9:04pm
8
Using ESP-IDF 5.3 will fix that. There is new code in ESPHome to take advantage of a better display driver - it’s in the dev branch, not sure if it made it into the latest release.
esp32:
framework:
type: esp-idf
platform_version: 6.8.1
version: 5.3.0
sdkconfig_options:
danastasia
(Douglas Anastasia)
December 18, 2024, 1:32pm
9
Just updated to 2024.12.0. and the same config now shows as too big for the board. this what I’m seeing during the build.
Here is the resulting error.
Here’s My device config.
esphome:
friendly_name: ${device_name}
area: ${device_area}
platformio_options:
# board_upload.maximum_size: 8388608
on_boot:
then:
- delay: 5s
- lvgl.widget.hide: boot_screen
esp32:
variant: esp32s3
framework:
type: esp-idf
sdkconfig_options:
COMPILER_OPTIMIZATION_SIZE: "y"
CONFIG_SPIRAM_FETCH_INSTRUCTIONS: "y"
# CONFIG_IDF_EXPERIMENTAL_FEATURES: y
CONFIG_SPIRAM_RODATA: "y"
# captive_portal:
psram:
mode: octal
speed: 80MHz
# Enable logging
logger:
level: INFO
i2c:
sda: GPIO08
scl: GPIO09
scan: True
ch422g:
# Toggles backlight of Waveshare ESP32-S3-Touch-LCD-4.3
switch:
- platform: gpio
pin:
ch422g: io_ex
number: 2
mode:
output: true
inverted: False
restore_mode: ALWAYS_ON
display:
color_order: RGB
dimensions:
width: 800
height: 480
de_pin:
number: 5
hsync_pin:
number: 46
vsync_pin:
number: 3
pclk_pin:
number: 7
pclk_inverted: false
hsync_back_porch: 10 #30
hsync_pulse_width: 10 #30
vsync_back_porch: 10 #4
vsync_front_porch: 10 #4
vsync_pulse_width: 10 #4
data_pins:
red:
- 1 #r3
- 2 #r4
- 42 #r5
- 41 #r6
- 40 #r7
blue:
- 14 #b3
- 38 #b4
- 18 #b5
- 17 #b6
- 10 #b7
green:
- 39 #g2
- 0 #g3
- 45 #g4
- 48 #g5
- 47 #g6
- 21 #g7
touchscreen:
platform: gt911
display: my_display
reset_pin:
ch422g: io_ex
number: 1
mode: output
on_touch:
- lambda: |-
ESP_LOGD("cal", "x=%d, y=%d, x_raw=%d, y_raw=%0d",
touch.x,
touch.y,
touch.x_raw,
touch.y_raw
on_release:
- if:
condition: lvgl.is_paused
then:
- logger.log: "LVGL resuming"
- lvgl.resume:
- lvgl.widget.redraw:
# - light.turn_on: display_backlight
Any help is appreciated.
danastasia
(Douglas Anastasia)
December 18, 2024, 2:33pm
10
Update:
I changed the code to:
esphome:
platformio_options:
# board_upload.flash_size: "8MB"
on_boot:
then:
- delay: 5s
esp32:
variant: esp32s3
framework:
type: esp-idf
version: latest
sdkconfig_options:
CONFIG_ESPTOOLPY_FLASHSIZE_8MB: "y"
CONFIG_ESPTOOLPY_FLASHSIZE: "8MB"
So it now sees the Flash as 8MB.
But, I still get the same error.
I’m wondering if this is related to this: How to increase partition size (to use 16MB of flash instead of 4MB)
danastasia
(Douglas Anastasia)
December 19, 2024, 12:36pm
12
Thanks! Flashed no problem (other than plugging it in to a USB port)
For everyone else. Here is the config I have
esphome:
platformio_options:
on_boot:
then:
- delay: 5s
esp32:
variant: esp32s3
flash_size: 8MB
framework:
type: esp-idf
version: latest
sdkconfig_options:
CONFIG_IDF_TARGET: "esp32s3"
CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ_240: y
CONFIG_ESPTOOLPY_FLASHMODE_QIO: y
CONFIG_ESPTOOLPY_FLASHFREQ_80M: y
CONFIG_ESPTOOLPY_FLASHSIZE_8MB: y
CONFIG_SPIRAM: y
CONFIG_SPIRAM_MODE_OCT: y
CONFIG_SPIRAM_SPEED_80M: y
CONFIG_FREERTOS_HZ: "1000"
CONFIG_ESP32S3_DATA_CACHE_LINE_64B: y
# captive_portal:
psram:
mode: octal
speed: 80MHz
# Enable logging
logger:
level: INFO
i2c:
sda: GPIO08
scl: GPIO09
scan: True
ch422g:
switch:
- platform: gpio
pin:
ch422g: io_ex
number: 2
mode:
output: true
inverted: False
display:
color_order: RGB
dimensions:
width: 800
height: 480
de_pin:
number: 5
hsync_pin:
number: 46
vsync_pin:
number: 3
pclk_pin:
number: 7
data_pins:
red:
- 1 #r3
- 2 #r4
- 42 #r5
- 41 #r6
- 40 #r7
blue:
- 14 #b3
- 38 #b4
- 18 #b5
- 17 #b6
- 10 #b7
green:
- 39 #g2
- 0 #g3
- 45 #g4
- 48 #g5
- 47 #g6
- 21 #g7
touchscreen:
platform: gt911
display: my_display
reset_pin:
ch422g: io_ex
number: 1
mode: output
on_touch:
- lambda: |-
touch.x,
touch.y,
touch.x_raw,
touch.y_raw
on_release:
- if:
then:
- lvgl.resume:
Any idea why my ESPHome gets the error :
“String value cannot be dictionary or list”
clydebarrow
(Clyde Stubbs)
December 22, 2024, 7:31pm
14
That’s not the correct syntax (refer to the docs) but unless you have multiple displays, you don’t need the displays: key at all.
MarcDJ
(Marc)
January 8, 2026, 10:52pm
15
Hi All,
I bought this display:
https://www.waveshare.com/wiki/ESP32-S3-Touch-LCD-4.3B from Amazon.nl
I was able to control the backgroud to turn it on and off using ESPHome. Below is the code:
substitutions:
esphome:
platformio_options:
project:
version: dev
esp32:
framework:
type: esp-idf
sdkconfig_options:
psram:
mode: octal
speed: 80MHz
# Enable logging
logger:
api:
encryption:
key: "xrwXLQY88CdK1ytjIK4+6CFcvBBbEXwuXOGcAncfUt4="
ota:
- platform: esphome
improv_serial:
wifi:
networks:
- ssid: !secret wifi_ssid
captive_portal:
dashboard_import:
esp32_improv:
authorizer: none
web_server:
i2c:
sda: GPIO08
scl: GPIO09
scan: True
display:
color_order: RGB
dimensions:
width: 800
height: 480
de_pin:
number: 5
hsync_pin:
number: 46
vsync_pin:
number: 3
pclk_pin: 7
pclk_inverted: true
data_pins:
red:
- 1 #r3
- 2 #r4
- 42 #r5
- 41 #r6
- 40 #r7
blue:
- 14 #b3
- 38 #b4
- 18 #b5
- 17 #b6
- 10 #b7
green:
- 39 #g2
- 0 #g3
- 45 #g4
- 48 #g5
- 47 #g6
- 21 #g7
font:
touchscreen:
platform: gt911
on_touch:
- lambda: |-
touch.x,
touch.y,
touch.x_raw,
touch.y_raw
refresh: 0min
components: [lvgl]
lvgl:
displays:
buffer_size: 25%
pages:
- id: clock_page
widgets:
width: 800 #240
align: CENTER
pad_all: 0
border_width: 0
bg_color: 0xFFFFFF
widgets:
height: 400 #220
width: 400 #220
align: center
bg_opa: TRANSP
scales:
width: 1
count: 61
length: 10
color: 0x000000
range_from: 0
range_to: 60
angle_range: 360
rotation: 270
indicators:
- line:
width: 3
color: 0xa6a6a6
r_mod: -4
value: 0
width: 1
count: 12
length: 1
major:
stride: 1
width: 4
length: 8
color: 0xC0C0C0
label_gap: 12
angle_range: 330
rotation: 300
range_from: 1
range_to: 12
- indicators:
- line:
width: 5
color: 0xa6a6a6
r_mod: -30
value: 0
angle_range: 360
rotation: 270
range_from: 0
range_to: 720
time:
interval:
- interval: 30s
then:
if:
condition:
time.has_time:
then:
script:
- id: time_update
then:
value: !lambda |-
value: !lambda |-
