Update:
I changed the code to:
esphome:
friendly_name: ${device_name}
area: ${device_area}
platformio_options:
build_flags: "-DBOARD_HAS_PSRAM"
board_build.arduino.memory_type: qio_opi
board_build.flash_mode: dio
# board_upload.flash_size: "8MB"
board_upload.maximum_ram_size: 524288
board_upload.maximum_size: 8388608
on_boot:
then:
- delay: 5s
- lvgl.widget.hide: boot_screen
esp32:
board: esp32-s3-devkitc-1
variant: esp32s3
framework:
type: esp-idf
version: latest
sdkconfig_options:
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
COMPILER_OPTIMIZATION_SIZE: "y"
CONFIG_SPIRAM_FETCH_INSTRUCTIONS: "y"
CONFIG_ESPTOOLPY_FLASHSIZE_8MB: "y"
CONFIG_ESPTOOLPY_FLASHSIZE: "8MB"
# CONFIG_IDF_EXPERIMENTAL_FEATURES: y
CONFIG_SPIRAM_RODATA: "y"
# Enable Home Assistant API
So it now sees the Flash as 8MB.
But, I still get the same error.
I’m wondering if this is related to this: How to increase partition size (to use 16MB of flash instead of 4MB)
