Waveshare 4.3 inch ESP32 with RPI_DPI_RGB driver no display
Ok, I found an example on this thread from @Jon_2232 :
I couldn’t get it to compile initially. The item that seem to give a display was:
psram:
  mode: octal
  speed: 80MHz
But I had a lot of corruption and the synch didnt seem to be quite right. I think the corruption was probably due to where ever memory was being used wasnt a great place.
I used my timing settings and then folded in Jon’s code and got it to compile and it is displaying his clock demo.
This is what my code looks like now:
substitutions:
  friendly_name: Control Panel
esphome:
  friendly_name: ${friendly_name}
  min_version: 2024.6.0
  name_add_mac_suffix: false
  platformio_options:
    build_flags: "-DBOARD_HAS_PSRAM"
    board_build.arduino.memory_type: qio_opi
    board_build.flash_mode: dio
    board_upload.maximum_ram_size: 524288
  project:
    version: dev
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: esp-idf
    sdkconfig_options:
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: y
      CONFIG_ESP32S3_DATA_CACHE_64KB: y
      CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
      CONFIG_SPIRAM_RODATA: y
psram:
  mode: octal
  speed: 80MHz
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
- platform: esphome
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
  # Set up a wifi access point
  ap: {}
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
dashboard_import:
  package_import_url: github://esphome/firmware/esphome-web/esp32s3.yaml@main
  import_full_config: true
# Sets up Bluetooth LE (Only on ESP32) to allow the user
# to provision wifi credentials to the device.
esp32_improv:
  authorizer: none
# To have a "next url" for improv serial
web_server:
i2c:
  sda: GPIO08
  scl: GPIO09
  scan: True
display:
  - platform: rpi_dpi_rgb
    auto_clear_enabled: false
    color_order: RGB
    update_interval: never
    pclk_frequency: 16MHz
    dimensions:
      width: 800
      height: 480
    de_pin:
      number: 5
    hsync_pin:
      number: 46
      ignore_strapping_warning: true
    vsync_pin:
      number: 3
    pclk_pin: 7
    pclk_inverted: true
    hsync_back_porch: 40 #30
    hsync_front_porch: 20 #210
    hsync_pulse_width: 1 #30
    vsync_back_porch: 8 #4
    vsync_front_porch: 4 #4
    vsync_pulse_width: 1 #4
    data_pins:
      red:
        - 1         #r3
        - 2         #r4
        - 42        #r5
        - 41        #r6
        - 40        #r7
      blue:
        - 14        #b3
        - 38        #b4
        - 18        #b5
        - 17        #b6
        - 10        #b7
      green:
        - 39        #g2
        - 0         #g3
        - 45        #g4
        - 48        #g5
        - 47        #g6
        - 21        #g7
font:
  - file: "gfonts://Roboto"
touchscreen:
  platform: gt911
  interrupt_pin: GPIO4
  on_touch:
    - lambda: |-
          ESP_LOGI("cal", "x=%d, y=%d, x_raw=%d, y_raw=%0d",
              touch.x,
              touch.y,
              touch.x_raw,
              touch.y_raw
external_components:
  - source: github://pr#6363
    refresh: 0min
    components: [lvgl]
lvgl:
  displays:
    - display_id: my_display
  buffer_size: 25%
  pages:
    - id: clock_page
      widgets:
        - obj: # Clock container
            height: size_content
            width: 800 #240
            align: CENTER
            pad_all: 0
            border_width: 0
            bg_color: 0xFFFFFF
            widgets:
              - meter: # Clock face
                  height: 400 #220
                  width: 400 #220
                  align: center
                  bg_opa: TRANSP
                  text_color: 0x000000
                  scales:
                    - ticks: # minutes scale
                        width: 1
                        count: 61
                        length: 10
                        color: 0x000000
                      range_from: 0
                      range_to: 60
                      angle_range: 360
                      rotation: 270
                      indicators:
                        - line:
                            width: 3
                            color: 0xa6a6a6
                            r_mod: -4
                            value: 0
                    - ticks: # hours scale
                        width: 1
                        count: 12
                        length: 1
                        major:
                          stride: 1
                          width: 4
                          length: 8
                          color: 0xC0C0C0
                          label_gap: 12
                      angle_range: 330
                      rotation: 300
                      range_from: 1
                      range_to: 12
                    - indicators:
                        - line:
                            width: 5
                            color: 0xa6a6a6
                            r_mod: -30
                            value: 0
                      angle_range: 360
                      rotation: 270
                      range_from: 0
                      range_to: 720
time:
  - platform: homeassistant
interval:
  - interval: 30s
    then:
      if:
          time.has_time:
        then:
          - script.execute: time_update
script:
  - id: time_update
    then:
      - lvgl.indicator.update:
          value: !lambda |-
            return id(time_comp).now().minute;
          value: !lambda |-
            auto now = id(time_comp).now();
            return std::fmod(now.hour, 12) * 60 + now.minute;
It’s basically Jon’s code, I dont know if I return the timings to his it would be any different. Anyhow, I consider this solved.
