Waveshare 4 Inch Display
Hello everyone,
i have recently bought the WaveShare ESP32 S3 4 Inch Touch Display and i just cant get it to work… i have tried different codes and all.
Here I found infos about the pins (gotta click expand to see the table etc) :
This is my latest code I tried from someone else :
esphome:
  friendly_name: Waveshare Display 1
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "DzYwkknAlg2sntfxjwSfeUal0DE8o/15bfHEQhSVYUc="
ota:
  - platform: esphome
    password: "30d1750551d86d2bde7d5961989c1718"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Waveshare-Display-1"
    password: "Lr9o4FyIcvbR"
captive_portal:
i2c:
  - sda: GPIO15
    scl: GPIO07
    scan: True
display:
  - platform: rpi_dpi_rgb
    auto_clear_enabled: false
    color_order: RGB
    dimensions:
      width: 480
      height: 480
    reset_pin:
      pca9554: pca9554a_device
      number: 3
    de_pin: GPIO40
    hsync_pin: GPIO38
    vsync_pin: GPIO39
    pclk_pin: GPIO41
    # Replace XX with the correct pin number
    data_pins:
      red:
        - 46        #r1
        - 03        #r2
        - 08        #r3
        - 18        #r4
        - 17        #r5
      green:
        - 14        #g0
        - 13        #g1
        - 12        #g2
        - 11        #g3
        - 10        #g4
        - 09        #g5
      blue:
        - 05        #b1
        - 45        #b2
        - 48        #b3
        - 47        #b4
        - 21        #b5
font:
  - file: "gfonts://Roboto"
touchscreen:
  - platform: gt911
    display: display1
psram:
  mode: octal
  speed: 80MHz
pca9554:
  - id: 'pca9554a_device'
    i2c_id: bus_a
    address: 0x20
lvgl:
  buffer_size: 25%
  pages:
    - id: clock_page
      widgets:
        - obj: # Clock container
            height: size_content
            width: 800 #240
            align: CENTER
            pad_all: 0
            border_width: 0
            bg_color: 0xFFFFFF
            widgets:
              - meter: # Clock face
                  height: 400 #220
                  width: 400 #220
                  align: center
                  bg_opa: TRANSP
                  text_color: 0x000000
                  scales:
                    - ticks: # minutes scale
                        width: 1
                        count: 61
                        length: 10
                        color: 0x000000
                      range_from: 0
                      range_to: 60
                      angle_range: 360
                      rotation: 270
                      indicators:
                        - line:
                            width: 3
                            color: 0xa6a6a6
                            r_mod: -4
                            value: 0
                    - ticks: # hours scale
                        width: 1
                        count: 12
                        length: 1
                        major:
                          stride: 1
                          width: 4
                          length: 8
                          color: 0xC0C0C0
                          label_gap: 12
                      angle_range: 330
                      rotation: 300
                      range_from: 1
                      range_to: 12
                    - indicators:
                        - line:
                            width: 5
                            color: 0xa6a6a6
                            r_mod: -30
                            value: 0
                      angle_range: 360
                      rotation: 270
                      range_from: 0
                      range_to: 720
time:
  - platform: homeassistant
interval:
  - interval: 30s
    then:
      if:
        condition:
          time.has_time:
        then:
          - script.execute: time_update
script:
  - id: time_update
    then:
      - lvgl.indicator.update:
          value: !lambda |-
            return id(time_comp).now().minute;
          value: !lambda |-
            auto now = id(time_comp).now();
            return std::fmod(now.hour, 12) * 60 + now.minute;
It’s a bad hardware design. Remove the pca9554 definition and the display reset pin. You won’t be able to control the backlight or buzzer without a hardware mod. There is a long thread in the Discord about it.
Okay, how can I access this discussion? Or what do i have to do to make it work?
Discord
If you haven’t already joined the server, you may need to use the link under “Need Help?” above for an invite.
What is the server? Cant follow your short instruction sadly.
The server ID from your Link and the server ID of Home Assistant are different.
Oh, yeah, you want the ESPHome server. See ESPHome.io for the server invite.
ESPHome
For anyone working with the ESP32-S3 AMOLED boards, I’ve put together a complete ESPHome YAML for the ESP32-S3 Touch AMOLED 1.75", including display, touch, audio, and a local Home Assistant voice assistant setup.
GitHub repo here:
:point_right: https://github.com/abramosphere/Home-Assistant-Voice-for-ESP32-S3-Touch-AMOLED-1.75
It’s hardware-specific but fully working, and might be useful as a reference (or starting point) for similar Waveshare / AMOLED S3 boards.
Why post that in a thread about a completely different board? Start a new thread if there isn’t already a suitable one.
The discord thread seems to be offline.
Is there any way to interact with the backlight and buzzer using ESPHome?
