Waveshare 8CH POE relais
I’m trying to include an 8-channel relais in my setup.
I have already several ELFIN EW11’s connected to do modbus over tcp and they all work nicely.
Now I’m trying to implement this Waveshare device but I get no response on the device, the relais do not trigger. I have the following setting:
modbus:
  - name: "Waveshare 8CH relais 1"
    type: tcp
    host: 192.168.1.201
    port: 9991
    delay: 3
    # timeout: 5
    binary_sensors:
      - name: my_relay
        address: 0
        input_type: coil
        scan_interval: 15
        slave: 1
        slave_count: 8
        unique_id: my_relay
    lights:
      - name: "Light_1"
        address: 0
        write_type: coil
        slave: 1
      - name: "Light_2"
        address: 1
        write_type: coil
        slave: 1
      - name: "Light_3"
        address: 2
        write_type: coil
        slave: 1
      - name: "Light_4"
        address: 3
        write_type: coil
        slave: 1
      - name: "Light_5"
        address: 4
        write_type: coil
        slave: 1
      - name: "Light_6"
        address: 5
        write_type: coil
        slave: 1
      - name: "Light_7"
        address: 6
        write_type: coil
        slave: 1
      - name: "Light_8"
        address: 7
        write_type: coil
        slave: 1
I can flip them on and of in Home asistant:
But the relais itself does noting>
When I look into the terminal log I see this:
What does this error mean ?
hi i hve the same issuse.
i will config yaml.
i see all entities and the device is silent.
can someone help.
I think the relais was not compatible with my Odroid setup, I sended it back and ordered one from Aliexpress to program via ESPHome, that works like a charm !
