Hi
Did someone succeeded to figure out the exact wiring of that controler ? I get different informations between the board schema and the user manual supplied for it by Waveshare
or I read them wrong
Vincèn
Hi
Vincèn
No one on this ? Thanks
Vincèn
Have you managed to connect it? After couple hours of reading datasheets I managed to wire 4.2in one - using waveshare provided esp8266 driver board. Pins have different names of course…
For 4.2in:
spi:
clk_pin: 14
mosi_pin: 13
- platform: waveshare_epaper
cs_pin: 15
dc_pin: 4
busy_pin: 16
reset_pin: 5
model: 4.20in
Oups thanks for reminder and yep I succeeded to get it to work
Here is my code with some text I display on it
Had not time yet to display icons or stuffs like that !
spi:
clk_pin: GPIO13
mosi_pin: GPIO14
font:
- file: "Comic_Sans_MS.ttf"
- platform: homeassistant
entity_id: sensor.outside_temperature_weather_service
internal: true
entity_id: sensor.living_room_temperature_2
internal: true
entity_id: sensor.living_room_humidity_2
internal: true
entity_id: sensor.plex_lausanne
internal: true
text_sensor:
entity_id: sensor.next_departure_sallaz
internal: true
entity_id: sensor.second_next_departure_sallaz
internal: true
display:
cs_pin: GPIO15
dc_pin: GPIO27
busy_pin: GPIO25
reset_pin: GPIO26
model: 7.50in
update_interval: 10s
lambda: |-
it.printf(0, 0, id(my_font), TextAlign::TOP_LEFT , "Next Bus: %2.2s", id(next_departure).state);
it.printf(0, 30, id(my_font), TextAlign::TOP_LEFT , "Second Next Bus: %2.2s", id(second_next_departure).state);
it.printf(0, 60, id(my_font), TextAlign::TOP_LEFT , "Outside Temperature: %.2f°C", id(outside_temperature).state);
it.printf(0, 90, id(my_font), TextAlign::TOP_LEFT , "Flat Temperature: %.2f°C", id(flat_temperature).state);
it.printf(0, 120, id(my_font), TextAlign::TOP_LEFT , "Flat Humidity: %.2f%%", id(flat_humidity).state);
it.printf(0, 150, id(my_font), TextAlign::TOP_LEFT , "Plex Users: %.0f", id(plex_users).state);
// it.line(0, 0, 100, 50);
// it.rectangle(50, 60, 30, 42);
// it.filled_rectangle(50, 60, 30, 42);
// it.circle(25, 25, 10);
// it.filled_circle(25, 25, 10);
may I ask which board type you have chosen when flashing ESPHome? thanks
The list is here https://docs.platformio.org/en/latest/platforms/espressif32.html#boards but it is hard to say from the description given - Waveshare ESP32-WROOM-32.
Based on this https://www.waveshare.com/w/upload/4/4a/E-Paper_ESP32_Driver_Board_user_manual_en.pdf (page 9) I would choose Espressif ESP32 Dev Module (ie esp32dev)
thanks, that would also have been my first idea.
but maybe @vincen is so kind and tells us what he used to succeed
Sure here is full copy of my yaml file for it
esphome:
platform: esp32
board: esp-wrover-kit
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_passwd
fast_connect: true
manual_ip:
static_ip: !secret ip_esp_e_ink
gateway: 192.168.1.1
subnet: 255.255.252.0
ap:
ssid: "E-Ink Display"
ap_timeout: 3min
api:
logger:
ota:
web_server:
spi:
clk_pin: GPIO13
mosi_pin: GPIO14
font:
internal: true
internal: true
internal: true
internal: true
text_sensor:
internal: true
internal: true
display:
cs_pin: GPIO15
dc_pin: GPIO27
busy_pin: GPIO25
reset_pin: GPIO26
model: 7.50in
lambda: |-
Thanks a lot!
Esp32dev also works and was today confirmed by waveshares support.
Looking forward to play with this.
Have fun, just don’t expect great refresh as ESPHome doesn’t really implement it well for now unhappy but it still works well for displaying infos not updating all time like time, weather, temperature…
Thanks.
Well yes got that from the YouTube videos I watched. It should show some sensor data, weather forecast and upcoming google calendar entries. Refreshed whenever some value changes, which is not that often.
And if it annoys me too much I can also implement something on my own
Hello, I have the 7.5inch V2 epaper from Waveshare and i cant get it to work. I see that Vincen’s code helped many people but not to me. I am new in Home Assistant and epaper too so please keep that in mind. Here is my really simplyfied code to just display anything. The display works with example code for arduino IDE but i can’t get it to work through esphome. I use ESP32-WROOM32 DEVKIT V1. Can someone tell me what am i doing wrong please?
Did you ever get this working @Mangee ? I picked up a 7.5inV2, and I can get it working fine with Raspberry Pi examples, but have yet to get it going with ESP32. I’ve tried many pinout combos (including verbatim what is shown in this thread) but no joy.
Sadly, I didn’t get it to work. I spent many hours on it and still don’t know where is the problem. But would love to have it working.
I’ve been trying to figure this out as well. No joy getting the 7.5v2 working with ESPHome either. My 4.2" works just fine…
I’ve been messing with the 7.50inV2 some time ago. This was my latest abomination that worked: https://pastebin.com/5DShVCGT
I just checked, last time the eink display was on was on 4.4.2021. Perks of e-ink displays, it shows when I last worked on the project
I know I had problems with finding correct pins to use for specific “jobs”. After figuring them out, display started working with no problems.
The last compiled version that I have was made with ESPHome 1.16.2.
Unfortunately I never finished the project as… Life happened
Hope this helps someone
@nejccc - thank you for another reference point on a configuration that used to work. I used all of your settings with my ESP32 and it still didn’t work. This one seems hard to track down… either something changed in the HAT/hardware - or the driver software. I’ll do the work to get this to work with the demo software that doesn’t use ESPHome and validate that the hardware works. I did grab some July 2020 ESPHome wavepaper files to see if that helped.
But it didn’t - which is why I’m leaning more towards something changing in the hardware recently…
buenas noches
alguien me puede decir como obtengo el cs y dc?
gracias
I’ll translate
can someone tell me how to get the cs and dc
English next time please.
Has anybody had any luck getting the v3 of the e-ink display working with ESPHome using the Waveshare ESP32 board?
I’ve tried every combination of display type and dip switches etc to no avail - display works fine with the RPi hat
substitutions:
esp_name: "waveshare-eink"
ip_address: 192.168.1.201
ip_gw: 192.168.1.1
ip_netmask: 255.255.255.0
esphome:
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
wifi:
manual_ip:
static_ip: ${ip_address}
gateway: ${ip_gw}
subnet: ${ip_netmask}
ap:
ssid: "Esphome-Web-Dd96F4"
password: "glu23pmoBYMF"
captive_portal:
web_server:
port: 80
include_internal: true
time:
timezone: Australia/Sydney
on_time_sync:
- component.update: uptime_timestamp
switch:
- platform: restart
text_sensor:
- platform: wifi_info
ip_address:
name: "${esp_name} IP Address"
icon: mdi:wifi
entity_category: diagnostic
ssid:
name: "${esp_name} Connected SSID"
icon: mdi:wifi-strength-2
bssid:
name: "${esp_name} Connected BSSID"
icon: mdi:clock-start
- platform: version
name: "${esp_name} ESPHome Version"
- platform: uptime
name: "${esp_name} Uptime Sec"
internal: true
- platform: wifi_signal
name: "${esp_name} WiFi Signal"
update_interval: 60s
device_class: "timestamp"
accuracy_decimals: 0
update_interval: never
lambda: |-
static float timestamp = (
id(current_time).utcnow().timestamp - id(uptime_sec).state
return timestamp;
font:
- file: "fonts/GoogleSans-Medium.ttf"
glyphs: |-
!"%()+=,-_.:°/|0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnopqrstuvwxyz'
spi:
clk_pin: GPIO13
mosi_pin: GPIO14
display:
cs_pin: GPIO15
dc_pin: GPIO27
busy_pin: GPIO25
reset_pin: GPIO26
model: 7.50inV2
update_interval: 1min
rotation: 90°
lambda: |-
it.fill(COLOR_OFF);
it.print(0,0,id(main_sensor_unit), "Hello, World!");
