Waveshare ESP32 6ch Relay board config yaml
I purchased one of these Waveshare ESP32 6ch relay boards and needed to give myself a crash course in ESPhome as this is my first ESP device. And it certainly will not be my last. I’m late to the ESP world, and this stuff is fantastic!
Anyways, part of my struggle was that the example configuration for this device in the ESPHome documenation was out of date and would no longer validate. After much googling and some help from Claude AI, I came up with this example which validates and adds some additional features.
Any suggestions for improvements welcome!
# Home Assistant ESPHome yaml config file for Waveshare ESP32 S3 6ch relay box
# 04/29/2026
# Your secrets file needs to have these entries:
# wifi_ssid: "SSID"
# wifi_password: "PASS"
# api_encryption_key: 'API_Key'
# API_Key is generated with:  openssl rand -base64 32
esphome:
esp32:
  variant: esp32s3
  flash_size: 8MB
  framework:
    type: arduino
# Enable logging
logger:
  level: DEBUG
api:
  encryption:
    key: !secret api_encryption_key
  actions:
  - action: rtttl_play
    variables:
      song_str: string
    then:
      - rtttl.play:
          rtttl: !lambda 'return song_str;'
ota:
  - platform: esphome
wifi:
  ssid: !secret wifi_ssid
captive_portal:
web_server:
  port: 80
bluetooth_proxy:
  active: true
time:
  - platform: homeassistant
binary_sensor:
  - platform: status
  - platform: gpio
    pin:
      number: 0
      ignore_strapping_warning: true
      mode:
        input: true
      inverted: true
    disabled_by_default: true
    on_press:
      then:
        - button.press: restart_button
  - platform: wifi_signal
    name: "WiFi Signal dB"
    update_interval: 60s
text_sensor:
  - platform: version
  - platform: wifi_info
    ip_address:
      entity_category: diagnostic
    ssid:
    mac_address:
switch:
  - platform: gpio
    pin: GPIO1
  - platform: gpio
    pin: GPIO2
  - platform: gpio
    pin: GPIO41
  - platform: gpio
    pin: GPIO42
  - platform: gpio
    pin:
      number: GPIO45
  - platform: gpio
    pin:
      number: GPIO46
    icon: mdi:volume-high
    turn_on_action:
      - rtttl.play:
          rtttl: 'beep:d=4,o=5,b=100:16e6'
    turn_off_action:
      - rtttl.stop:
uart:
  tx_pin: GPIO17
  rx_pin: GPIO18
  baud_rate: 9600
output:
  - platform: ledc
    pin: GPIO21
rtttl:
  output: buzzer_output
  gain: 40%
light:
  - platform: esp32_rmt_led_strip
    chipset: ws2812
    pin: GPIO38
    num_leds: 1
    rgb_order: RGB
button:
  - platform: restart
    entity_category: config
  - platform: factory_reset
  - platform: safe_mode
    internal: false
To prevent that the valve stays open when not closed by home assistant i have added a safety feature:
switch:
  - platform: gpio
    pin: GPIO1
    # Stellt sicher, dass die Relais beim neustart des ESPs ausgeschaltet sind
    # on esp32 restart keep relay closed
    restore_mode: ALWAYS_OFF
    # Schaltet sicherheitshalber den GPIO-Switch nach 16 Minuten aus. Im Bearfsfall die Dauer anpassen ;)
    # maximum time valve is open
    on_turn_on:
    - delay: 960s
    - switch.turn_off: riego_zone1_valve
Another minor thing that I found handy was using ESPHome packages when duplicating config (e.g for multiple relays).
Mine is slightly different, but I have a 24 relay board so there’s a lot of repeated configuration. So, my main configuration file is just this:
substitutions:
  host_name: esp-24-sprinkler
  friendly_name: 24 Relay Sprinkler Controller
esp8266:
  board: esp01_1m
sn74hc595:
  - id: 'sn74hc595_hub'
    data_pin: GPIO14
    clock_pin: GPIO13
    latch_pin: GPIO12
    oe_pin: GPIO05
    sr_count: 3
packages:
  connect: !include includes/connections.yaml
  station_1: !include  { vars: { station: 1,  pin: 0  }, file: includes/package_sprinkler_switch.yaml }
  station_2: !include  { vars: { station: 2,  pin: 1  }, file: includes/package_sprinkler_switch.yaml }
  station_23: !include { vars: { station: 23, pin: 22  }, file: includes/package_sprinkler_switch.yaml }
  station_24: !include { vars: { station: 24, pin: 23  }, file: includes/package_sprinkler_switch.yaml }
And then the package file is this:
substitutions:
  max_time_on: 2h
switch:
  - platform: gpio
    name: "ESP Station $station"
    pin:
      sn74hc595: sn74hc595_hub
      number: $pin
    on_turn_on:
      - script.execute: on_turn_on_$station
    on_turn_off:
      - script.stop: on_turn_on_$station
script:
  - id: on_turn_on_$station
    mode: restart
    then:
      - logger.log: "$max_time_on timeout started for sprinker $station"
      - delay: $max_time_on
      - logger.log: "Auto-timeout sprinker $station after $max_time_on"
      - switch.turn_off: station_$station
I suppose a single script would do here – or just avoid the script as @juergenjw posted. I’m not aware of a way to, for example, use templating to loop over all those packages, which would be nice.
