What version of Home Assistant Core has the issue?
2024.4.2
What was the last working version of Home Assistant Core?
No response
What type of installation are you running?
Home Assistant OS
Integration causing the issue
modbus
Link to integration documentation on our website
modbus:
– name: licznik
close_comm_on_error: true
type: tcp
host: 192.168.0.230
port: 4196
timeout: 10
sensors:
- name: "Freq"
slave: 1
address: 20
data_type: float32
precision: 2
unit_of_measurement: HZ
- name: "Voltage L1"
slave: 1
address: 14
data_type: float32
precision: 1
unit_of_measurement: V
- name: "Voltage L2"
slave: 1
address: 16
data_type: float32
precision: 1
- name: "Voltage L3"
slave: 1
address: 18
data_type: float32
precision: 1
- name: "Current L1"
slave: 1
address: 22
data_type: float32
precision: 1
unit_of_measurement: A
- name: "Current L2"
slave: 1
address: 24
data_type: float32
precision: 1
- name: "Current L3"
slave: 1
address: 26
data_type: float32
precision: 1
- name: "Active Power Total"
slave: 1
address: 28
data_type: float32
precision: 2
unit_of_measurement: kW
- name: "Active Power L1"
slave: 1
address: 30
data_type: float32
precision: 2
- name: "Active Power L2"
slave: 1
address: 32
data_type: float32
precision: 2
- name: "Active Power L3"
slave: 1
address: 34
data_type: float32
precision: 2
- name: "Active Energy Total"
slave: 1
address: 256
data_type: float32
precision: 2
unit_of_measurement: kWh
state_class: total_increasing
- name: "Active Energy L1"
slave: 1
address: 258
data_type: float32
precision: 2
- name: "Active Energy L2"
slave: 1
address: 260
data_type: float32
precision: 2
- name: "Active Energy L3"
slave: 1
address: 262
data_type: float32
precision: 2
Error loading /config/configuration.yaml: mapping values are not allowed here
in “/config/configuration.yaml”, line 28, column 24
