I have a leakSMART water sensor that I’d like to use just to detect water, not with an accompanying shut off valve. I have several Xiaomi Aqara water sensors as well. When I pair the leakSMART sensor with HA, all I get is a temperature entity. I would expect that there would be a binary sensor as well that would flag when it detects water. The Xiaomi sensors work this way.
I skimmed through the sensor’s cluster attributes and commands, but didn’t find anything that might tell it to provide a binary sensor. I also searched online and only found one reference to a similar issue on these forums back in 2017, with no follow up.
Has anyone used a leakSMART sensor this way? Is the sensor perhaps not meant to report when it detects water, but merely to command a valve to shut?
TIA!
