I am looking for a helper to say ‘inside’ or ‘outside’. Currently using a toggle.
I could setup a specific sensor i guess and put in a friendly name but wondering if there’s a better way?
Hi @atv
I think you’ll need to create a template sensor.
Let me know if you need help. If you do, let me know how ‘inside’ or ‘outside’ is determined and which entities are involved.
Input select helper. Drop down with multiple states.
If you need to display it differently there are many techniques
This card:
Is basically one button card with a bunch of other buttons embedded. Each one has service : input_select.select_option xxx as it’s action.
So I’m storing the value as an input select but representing it on the dashboard as buttons.
Totally agree with Nathan: Input Select is designed for exactly this kind of thing. To create: Settings → Devices & Services → Helpers → Create Helper → Dropdown. Give it a name (eg “Location”), and add options for your desired states (eg “Inside” and “Outside”), then Create.
Thanks guys. Once i create the dropdown entities how does one set them ? I did not see a input_select set entry under services (must have missed it!).
Use the SELECT OPTION service
Thanks! Much obliged.
