Way to know if an integration is used in some dashboards?
Hi there,
I see HACS a lot of stuff I have installed, without being sure this is finally used in my dashboards.
(I probably installed som HACS stuff to “test”, then not use it)
Is there a way to know if an integration is really used in sole dashboards or not, so that I can clean and delete them from HACS ?
For example in HAS currently I see this :
Many Thanks !!
I might be wrong, but off the top of my head:
Hit edit on your dashboard.
Click the 3 dots in the top right > raw configuration editor.
Ctrl+F & search for each integration listed. Repeat for each dashboard
Keep a note of the ones showing up in the search results, then disable (don’t uninstall for now) the rest.
Monitor for dashboard stability for a couple of days, then uninstall the disabled ones.
I just copy/paste the repository link somewhere and remove it from HA. If it breaks a dashboard, pretty obvious and then I can add it back easily enough.
