I’ve previously bandaid-fixed an issue with a dimmer switch (Inovelli red) causing a ceiling light to flash when turned off; the workaround is an automation that turns it “on” to minimum brightness whenever it’s turned off. Unfortunately this means that toggle no longer works with the switch; the light bulb on Lovelace is always yellow and considered on, and the toggle for the whole room fails as well; it’s always considered “on,” because of that one light. Is there any way to trick Lovelace into thinking that the light is just off when it’s actually dimmed to minimum?
