have anyone else had problem whit the Apple TV not showing in HA.?
I have discovery: in my config file
Me too. I have appletv 4 and discovery enable in config file. I also use the apple_tv beta custom components as well.
did you read the documentation for that custom integration
specifically
As Home Assistant does not support zeroconf for custom components, auto-discovery will not work with this component. You will have to manually add your device via the Integrations page.
I have read that and tried to manually
add but how do I obtain the login id when I do not see apple_tv_scan
under state in development?
Read that you just add apple_tv:
in config file to obtain the login id. Tried that as well, but configuration validation does not work when try to valid yaml. It just spins and not produce any errors.
Note: I manually at the add-on into my custom_components folder. I didn’t use HACS to install apple_tv beta.
log issue with the dev of the customintegration
regarding hacs or manually installing, there is no difference.
