My Home Assistant OS 8.1 is not booting, instead is doing an infinite boot loop. Details are in the bugs dockerd level=error msg="failed to load container" · Issue #1970 · home-assistant/operating-system · GitHub and [WARN] Home Assistant CLI not starting! Jump into emergency console · Issue #1969 · home-assistant/operating-system · GitHub
Jun 09 12:13:55 homeassistant audit[421]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="docker-default" pid=421 comm="apparmor_parser"
Jun 09 12:13:55 homeassistant audit[421]: SYSCALL arch=c000003e syscall=1 success=yes exit=7945 a0=4 a1=5624d33534c0 a2=1f09 a3=0 items=0 ppid=420 pid=421 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/sbin/apparmor_parser" subj==unconfined key=(null)
Jun 09 12:13:55 homeassistant audit: PROCTITLE proctitle=61707061726D6F725F706172736572002D4B72002F6D6E742F646174612F646F636B65722F746D702F646F636B65722D64656661756C7431393937333033343235
Jun 09 12:13:55 homeassistant kernel: audit: type=1400 audit(1654766035.062:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="docker-default" pid=421 comm="apparmor_parser"
Jun 09 12:13:55 homeassistant kernel: audit: type=1300 audit(1654766035.062:11): arch=c000003e syscall=1 success=yes exit=7945 a0=4 a1=5624d33534c0 a2=1f09 a3=0 items=0 ppid=420 pid=421 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/sbin/apparmor_parser" subj==unconfined key=(null)
Jun 09 12:13:55 homeassistant kernel: audit: type=1327 audit(1654766035.062:11): proctitle=61707061726D6F725F706172736572002D4B72002F6D6E742F646174612F646F636B65722F746D702F646F636B65722D64656661756C7431393937333033343235
Jun 09 12:13:55 homeassistant dockerd[396]: time="2022-06-09T09:13:55.069618724Z" level=info msg="parsed scheme: \"unix\"" module=grpc
Jun 09 12:13:55 homeassistant dockerd[396]: time="2022-06-09T09:13:55.069704556Z" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Jun 09 12:13:55 homeassistant dockerd[396]: time="2022-06-09T09:13:55.069769564Z" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///var/run/docker/containerd/containerd.sock <nil> 0 <nil>}] <nil> <nil>}" module=grpc
Jun 09 12:13:55 homeassistant dockerd[396]: time="2022-06-09T09:13:55.069793659Z" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Jun 09 12:13:55 homeassistant dockerd[396]: time="2022-06-09T09:13:55.072804679Z" level=info msg="parsed scheme: \"unix\"" module=grpc
Jun 09 12:13:55 homeassistant dockerd[396]: time="2022-06-09T09:13:55.072852521Z" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Jun 09 12:13:55 homeassistant dockerd[396]: time="2022-06-09T09:13:55.072909422Z" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///var/run/docker/containerd/containerd.sock <nil> 0 <nil>}] <nil> <nil>}" module=grpc
Jun 09 12:13:55 homeassistant dockerd[396]: time="2022-06-09T09:13:55.072932761Z" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Jun 09 12:13:55 homeassistant dockerd[396]: time="2022-06-09T09:13:55.510719007Z" level=warning msg="Your kernel does not support cgroup blkio weight"
Jun 09 12:13:55 homeassistant dockerd[396]: time="2022-06-09T09:13:55.510790367Z" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Jun 09 12:13:55 homeassistant dockerd[396]: time="2022-06-09T09:13:55.511137197Z" level=info msg="Loading containers: start."
Jun 09 12:13:55 homeassistant dockerd[396]: time="2022-06-09T09:13:55.520600103Z" level=error msg="failed to load container" container=93edabb4dd7472b9e229887f1127446d6bb375331811bdd4cf8207c630ed0fb0 error="Container 17f7ed101a68e40f1d345d3bb00b9ff81554071536ec1dea7693d9d2f88fa10f is stored at 93edabb4dd7472b9e229887f1127446d6bb375331811bdd4cf8207c630ed0fb0"
Jun 09 12:13:55 homeassistant dockerd[396]: time="2022-06-09T09:13:55.536707477Z" level=error msg="failed to load container" container=cdfd3091a149481cc16d19f18ade1efb643f1b02612c75b0048e66c4d2d1a2fe error="invalid character 'a' looking for beginning of value"
Jun 09 12:13:55 homeassistant audit[429]: NETFILTER_CFG table=nat family=2 entries=0 op=xt_register pid=429 subj==unconfined comm="iptables"
Jun 09 12:13:55 homeassistant audit[429]: SYSCALL arch=c000003e syscall=55 success=yes exit=0 a0=4 a1=0 a2=40 a3=7ffeb2eee900 items=0 ppid=396 pid=429 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-legacy-multi" subj==unconfined key=(null)
Jun 09 12:13:55 homeassistant audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4C002D6E
Jun 09 12:13:55 homeassistant audit[430]: NETFILTER_CFG table=filter family=2 entries=0 op=xt_register pid=430 subj==unconfined comm="iptables"
Jun 09 12:13:55 homeassistant audit[430]: SYSCALL arch=c000003e syscall=55 success=yes exit=0 a0=4 a1=0 a2=40 a3=7ffdf0814070 items=0 ppid=396 pid=430 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-legacy-multi" subj==unconfined key=(null)
Jun 09 12:13:55 homeassistant audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4C002D6E
Jun 09 12:13:55 homeassistant audit[449]: NETFILTER_CFG table=nat family=2 entries=5 op=xt_replace pid=449 subj==unconfined comm="iptables"
Jun 09 12:13:55 homeassistant audit[449]: SYSCALL arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=55ec8dbd1a60 items=0 ppid=396 pid=449 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-legacy-multi" subj==unconfined key=(null)
Jun 09 12:13:55 homeassistant audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4E00444F434B4552
Jun 09 12:13:55 homeassistant audit[451]: NETFILTER_CFG table=filter family=2 entries=4 op=xt_replace pid=451 subj==unconfined comm="iptables"
Jun 09 12:13:55 homeassistant audit[451]: SYSCALL arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=563c4e5fd940 items=0 ppid=396 pid=451 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-legacy-multi" subj==unconfined key=(null)
Jun 09 12:13:55 homeassistant audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D740066696C746572002D4E00444F434B4552
Jun 09 12:13:55 homeassistant audit[453]: NETFILTER_CFG table=filter family=2 entries=6 op=xt_replace pid=453 subj==unconfined comm="iptables"
Jun 09 12:13:55 homeassistant audit[453]: SYSCALL arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=55f11bf0cb10 items=0 ppid=396 pid=453 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-legacy-multi" subj==unconfined key=(null)
Jun 09 12:13:55 homeassistant audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D740066696C746572002D4E00444F434B45522D49534F4C4154494F4E2D53544147452D31
Jun 09 12:13:55 homeassistant audit[455]: NETFILTER_CFG table=filter family=2 entries=8 op=xt_replace pid=455 subj==unconfined comm="iptables"
Jun 09 12:13:55 homeassistant audit[455]: SYSCALL arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=55f59b6e8cf0 items=0 ppid=396 pid=455 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-legacy-multi" subj==unconfined key=(null)
Jun 09 12:13:55 homeassistant audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D740066696C746572002D4E00444F434B45522D49534F4C4154494F4E2D53544147452D32
Jun 09 12:13:55 homeassistant audit[457]: NETFILTER_CFG table=filter family=2 entries=10 op=xt_replace pid=457 subj==unconfined comm="iptables"
Jun 09 12:13:55 homeassistant audit[457]: SYSCALL arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=558bb52d65a0 items=0 ppid=396 pid=457 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-legacy-multi" subj==unconfined key=(null)
Jun 09 12:13:55 homeassistant audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4100444F434B45522D49534F4C4154494F4E2D53544147452D31002D6A0052455455524E
Jun 09 12:13:55 homeassistant audit[459]: NETFILTER_CFG table=filter family=2 entries=11 op=xt_replace pid=459 subj==unconfined comm="iptables"
Jun 09 12:13:55 homeassistant audit[459]: SYSCALL arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=55d581ae0720 items=0 ppid=396 pid=459 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-legacy-multi" subj==unconfined key=(null)
Jun 09 12:13:55 homeassistant audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4100444F434B45522D49534F4C4154494F4E2D53544147452D32002D6A0052455455524E
Jun 09 12:13:55 homeassistant audit[460]: NETFILTER_CFG table=filter family=2 entries=12 op=xt_replace pid=460 subj==unconfined comm="iptables"
Jun 09 12:13:55 homeassistant audit[460]: SYSCALL arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=5572d0f94120 items=0 ppid=396 pid=460 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-legacy-multi" subj==unconfined key=(null)
Jun 09 12:13:55 homeassistant audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D740066696C746572002D5000464F52574152440044524F50
Jun 09 12:13:55 homeassistant dockerd[396]: time="2022-06-09T09:13:55.808607469Z" level=info msg="stopping event stream following graceful shutdown" error="context canceled" module=libcontainerd namespace=plugins.moby
Jun 09 12:13:55 homeassistant dockerd[396]: time="2022-06-09T09:13:55.808775250Z" level=info msg="stopping event stream following graceful shutdown" error="context canceled" module=libcontainerd namespace=moby
Jun 09 12:13:55 homeassistant dockerd[396]: time="2022-06-09T09:13:55.808782852Z" level=info msg="stopping healthcheck following graceful shutdown" module=libcontainerd
Jun 09 12:13:56 homeassistant dockerd[396]: time="2022-06-09T09:13:56.811308228Z" level=warning msg="grpc: addrConn.createTransport failed to connect to {unix:///var/run/docker/containerd/containerd.sock <nil> 0 <nil>}. Err :connection error: desc = \"transport: Error while dialing dial unix:///var/run/docker/containerd/containerd.sock: timeout\". Reconnecting..." module=grpc
Jun 09 12:13:56 homeassistant dockerd[396]: time="2022-06-09T09:13:56.811497346Z" level=warning msg="grpc: addrConn.createTransport failed to connect to {unix:///var/run/docker/containerd/containerd.sock <nil> 0 <nil>}. Err :connection error: desc = \"transport: Error while dialing dial unix:///var/run/docker/containerd/containerd.sock: timeout\". Reconnecting..." module=grpc
It seems the error is Docker related
Jun 09 12:13:56 homeassistant dockerd[396]: panic: page 8 already freed
Jun 09 12:13:56 homeassistant dockerd[396]: goroutine 1 [running]:
Jun 09 12:13:56 homeassistant dockerd[396]: go.etcd.io/bbolt.(*freelist).free(0xc0000c4e00, 0x4528, 0x7fa85c5c0000)
Jun 09 12:13:56 homeassistant dockerd[396]: go.etcd.io/bbolt/freelist.go:175 +0x2c8
Jun 09 12:13:56 homeassistant dockerd[396]: go.etcd.io/bbolt.(*node).spill(0xc000a29340)
Jun 09 12:13:56 homeassistant dockerd[396]: go.etcd.io/bbolt/node.go:359 +0x213
Jun 09 12:13:56 homeassistant dockerd[396]: go.etcd.io/bbolt.(*node).spill(0xc000a29260)
Jun 09 12:13:56 homeassistant dockerd[396]: go.etcd.io/bbolt/node.go:346 +0xaa
Jun 09 12:13:56 homeassistant dockerd[396]: go.etcd.io/bbolt.(*node).spill(0xc000a29110)
Jun 09 12:13:56 homeassistant dockerd[396]: go.etcd.io/bbolt.(*Bucket).spill(0xc000cca540)
Jun 09 12:13:56 homeassistant dockerd[396]: go.etcd.io/bbolt/bucket.go:570 +0x32f
Jun 09 12:13:56 homeassistant dockerd[396]: go.etcd.io/bbolt.(*Bucket).spill(0xc000ae67f8)
Jun 09 12:13:56 homeassistant dockerd[396]: go.etcd.io/bbolt/bucket.go:537 +0xea
Jun 09 12:13:56 homeassistant dockerd[396]: go.etcd.io/bbolt.(*Tx).Commit(0xc000ae67e0)
Jun 09 12:13:56 homeassistant dockerd[396]: go.etcd.io/bbolt/tx.go:160 +0xe7
Jun 09 12:13:56 homeassistant dockerd[396]: go.etcd.io/bbolt.(*DB).Update(0xc0007d1130, 0xc000f3e580)
Jun 09 12:13:56 homeassistant dockerd[396]: go.etcd.io/bbolt/db.go:701 +0xe5
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/libkv/store/boltdb.(*BoltDB).AtomicDelete(0xc0007d1130, {0xc0007cc1c0, 0x65}, 0xc000b6f9e0)
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/libkv/store/boltdb/boltdb.go:329 +0x19b
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/libnetwork/datastore.(*datastore).DeleteObjectAtomic(0xc000cca180, {0x2ddea48, 0xc000e705a0})
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/libnetwork/datastore/datastore.go:623 +0x3b4
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/libnetwork/drivers/bridge.(*driver).storeDelete(0xc000d52b00, {0x2ddea48, 0xc000e705a0})
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/libnetwork/drivers/bridge/bridge_store.go:120 +0x1e2
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/libnetwork/drivers/bridge.(*driver).populateEndpoints(0xc000d52b00)
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/libnetwork/drivers/bridge/bridge_store.go:87 +0x510
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/libnetwork/drivers/bridge.(*driver).initStore(0xc000d52b00, 0x29f6c6c)
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/libnetwork/drivers/bridge/bridge_store.go:40 +0x1de
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/libnetwork/drivers/bridge.(*driver).configure(0xc000d52b00, 0x26eaf80)
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/libnetwork/drivers/bridge/bridge.go:439 +0x66b
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/libnetwork/drivers/bridge.Init({0x2d78de8, 0xc000145b80}, 0x6)
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/libnetwork/drivers/bridge/bridge.go:169 +0x98
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/libnetwork/drvregistry.(*DrvRegistry).AddDriver(...)
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/libnetwork/drvregistry/drvregistry.go:72
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/libnetwork.New({0xc000d52a80, 0x9, 0x10})
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/libnetwork/controller.go:221 +0x61c
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/docker/daemon.(*Daemon).initNetworkController(0xc00000c1e0, 0xc0001beb00, 0xc000ca9d70)
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/docker/daemon/daemon_unix.go:855 +0x65
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/docker/daemon.(*Daemon).restore(0xc00000c1e0)
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/docker/daemon/daemon.go:490 +0x532
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/docker/daemon.NewDaemon({0x2db5e38, 0xc000829100}, 0xc0001beb00, 0xc0000d0120)
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/docker/daemon/daemon.go:1150 +0x3037
Jun 09 12:13:56 homeassistant dockerd[396]: main.(*DaemonCli).start(0xc0000b4b70, 0xc00012b800)
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/docker/cmd/dockerd/daemon.go:195 +0xa36
Jun 09 12:13:56 homeassistant dockerd[396]: main.runDaemon(...)
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/docker/cmd/dockerd/docker_unix.go:13
Jun 09 12:13:56 homeassistant dockerd[396]: main.newDaemonCommand.func1(0xc00050cdc0, {0xc000050ab0, 0x9, 0x9})
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/docker/cmd/dockerd/docker.go:34 +0x5c
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/spf13/cobra.(*Command).execute(0xc00050cdc0, {0xc00012c010, 0x9, 0x9})
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/spf13/cobra/command.go:850 +0x60e
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/spf13/cobra.(*Command).ExecuteC(0xc00050cdc0)
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/spf13/cobra/command.go:958 +0x3ad
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/spf13/cobra.(*Command).Execute(...)
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/spf13/cobra/command.go:895
Jun 09 12:13:56 homeassistant dockerd[396]: main.main()
Jun 09 12:13:56 homeassistant dockerd[396]: github.com/docker/docker/cmd/dockerd/docker.go:97 +0x15d
Jun 09 12:13:56 homeassistant systemd[1]: docker.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Jun 09 12:13:56 homeassistant systemd[1]: docker.service: Failed with result 'exit-code'.
Jun 09 12:13:56 homeassistant systemd[1]: Failed to start Docker Application Container Engine.
Jun 09 12:13:56 homeassistant systemd[1]: Dependency failed for HassOS supervisor.
Jun 09 12:13:56 homeassistant systemd[1]: hassos-supervisor.service: Job hassos-supervisor.service/start failed with result 'dependency'.
Jun 09 12:13:56 homeassistant systemd[1]: Dependency failed for Dropbear SSH daemon.
Jun 09 12:13:56 homeassistant systemd[1]: dropbear.service: Job dropbear.service/start failed with result 'dependency'.
I would like to stop the automatic reboot if the Docker service is not starting correctly so that I can access the CLI of Home Assistant OS
Please advise how to do that.
Thanks!
