I want to add a second z-wave controller away from my main house controller (for Long Range).
The Home Assistant Z-Wave integration supports multiple “hubs” so that doesn’t seem like much of a problem. But I need another instance of zwave-js-ui to manage the controller.
One option is to run zwave-js-ui in Docker on it’s own server (e.g. Raspberry Pi) and then add a hub with a url like: ws://my-remote-zwave-js-server.local:3000. I’m not sure how concerned to be about that security-wise.
Here’s my add-on question:
I’m considering using a serial-over-ethernet Z-wave controller (like the TubesZB kit), so I don’t really need another machine to run zwave-js-ui. I don’t think there’s way to run a 2nd copy of an add-on, but is there any reason the second copy couldn’t be run as a local add-on?
For example, could I bring in the zwave-js-ui add-on code as a local add-on and modify the slug in the add-on’s config.yaml to make the supervisor start the container with a different hostname?
Or are there other things that would need to be changed to allow the add-on to run? That is, something to make the add-on seem unique to the supervisor as a different add-on?
Thanks,
