I want to create a Waze Time Distance from a google calendar location event. It seems to accept the entity person.lambo as the GPS location fine and calendar.jetstar with no issues. But when I connect the calendar API from google into the waze location it gives me a rather bizarre and very incorrect distance. It shouldn’t be any more than 3km and about 7 mins. How do I fix this?
Calendar:
calendar.jetstar
JQ
State: off
message: DPS -
all_day: false
start_time: 2023-03-16 05:25:00
end_time: 2023-03-16 12:50:00
location: Adelaide Airport Long Term Car Parking, Sir Richard Williams Ave, Adelaide Airport SA 5950, Australia
description: JQ1
offset_reached: false
friendly_name: Jetstar
supported_features: 3
Waze Distance:
sensor.jetstar_shift
Jetstar Shift
State: 469
state_class: measurement
duration: 469.3666666666667
distance: 724.507
route: Best-M8 - Western Fwy
origin: **MY LOCATION**
destination: calendar.jetstar
unit_of_measurement: min
attribution: Powered by Waze
device_class: duration
icon: mdi:car
friendly_name: Jetstar Shift
Using Calendar as the origin or destination for waze is currently not supported.
It’s on my todo list. I cannot give an eta yet.
To explain what is happening here:
Waze can work with a lot of entities. Some of them like a device_tracker or a zone have attributes for the GPS coordinates. For all other entities it uses the current state. This only works if this state is are comma separated latitude and longitude or an address.
So if it takes the current state of your calendar entity, which is off it will try to find any location on the world with the name “off”, take the first result and calculate a route to it.
You can do something like this to create a sensor entity with the location of the next upcoming calendar event, then use this as the destination for Waze:
When we get service response values working for waze, we’ll have more approaches we can use for this, but this works pretty good right now.
@allenporter Can you give more details on how to implement this please. Because I don’t really know whether to create an automation or a script or both.
Hi, this is a template entity. You create this either in configuration.yaml or a file included from it and then it will register this entity that is occasionally updated based on the trigger criteria. The reason this is a little confusing is that it does in fact look similar to how you’d be build an automation that gets the same data, but the difference is that it has the sensor field for creating the entity rather than taking some other action like an automation might.
I’m trying to build off the snippet from Allen Porter, but running into a snag. I get the following two errors in my logs, and my sensors show nothing, or “unknown”.
log errors
Logger: homeassistant.components.sensor.helpers
Source: components/sensor/helpers.py:23
integration: Sensor (documentation, issues)
First occurred: 22:41:47 (1 occurrences)
Last logged: 22:41:47
sensor.next_location_start rendered invalid timestamp:
Logger: homeassistant.helpers.template
Source: helpers/template.py:2748
First occurred: 22:41:47 (3 occurrences)
Last logged: 22:41:48
Template variable warning: 'dict object' has no attribute 'events' when rendering '{{ agenda.events | rejectattr('location', 'undefined') | list }}'
Template variable warning: 'schedule_set' is undefined when rendering '{{ schedule_set }}'
Problem Info
I did make two changes to the sensor;
service > action
calendar.list_events > calendar.get_events
Anyone still using this successfully and willing to takes peak? Thanks!
Apologies in advance that I am learning HA having transitioned from Hubitat and having minimal coding experience. Here’s what I want to do:
Publish the location attribute of a Google calendar event (if one is defined) as the destination input to the Waze integration. The starting location would always be my home address. Have Waze calculate the trip duration. Doesn’t matter if multiple routes are calculated, I just need whatever duration value is default or first.
From there, add the duration value from Waze to 30 minutes.
From there, update the time before the calendar event to precondition the batteries in my Tesla.
The idea is to take into account the driving time to the destination as well as the 30 minutes recommended for preconditioning.
For example, the tennis facility is an 11 minute drive, so I’d like preconditioning to start 41 minutes prior to the event start time in my calendar. Another location might be a 45 minute drive, so preconditioning should begin 30 + 45 minutes prior to the event start time.
I have all of the integrations functioning correctly, I’m just struggling with how to put the pieces together.
The best I’ve done thus far is to use the 30 minute offset in an automation prior to the start time in Google calendar but I’d like to make it smarter. Ideally, without having to manually update the Google Calendar event start time to take drive time into account.
I have no idea of how to pass the Google event location to Waze and have it return the duration value.
I’ve been reading other posts and it seems like this might be doable.
