Waze - one issue, one bug (maybe)
First the issue:
Is there any way to prevent these Warnings?
I guess they occur because I look up routes to zone.home and I’m already there?
Which led me to wonder if there was a way to stop the integration under certain conditions.
Is there?
I decided to at least confirm my guess at what was causing the warning by using the ‘Disable’ option in the Integration (not ‘Delete’)…
…thinking I could then ‘Enable’ it again later. But it disappears completely.
Never mind, I thought, I’ll just recreate it. But then I get this:
So to summarise,
  1. Is there a way to supress the ‘empty response’ warning?
  2. Is there a way to ‘switch off’ the integration under certain conditions?
  3. Is the ‘Disable’ option working as designed?
  4. How do I reinstate a ‘Disabled’ integration?
I’m surprised this hasn’t elicited any response.
Ok, so ignore the point about the irritating warnings in the log, I can live with that, but surely I should be able to reinstate a route that I ‘Disabled’? (I can even live with the fact that ‘Disable’ doesn’t actually mean disable).
I can’t believe no one has come across this before i.e. disabling an integration and not being able to recreate/reinstate it because it says it already exists.
I’d try removing all my other Waze integrations and see if that works but I don’t really want to lose all of them.
