my system is failing to get “Waze Travel Time” integration being working.
I’ve tried methods with creating sensors in config file - no result, sensors are not created / not working.
I’ve tried to create the integration - no result.
System WAZE integration UI provides a status: “Unknown error occurred”
I’ve tried to use position input in both these formats:
NN.NNNNNNNNNNNNNN, NN.NNNNNNNNNNNNNN
NN.NNNNN, NN.NNNNN
where N is a number… both are not working.
HA version: 2022.11.4
Is there anything I could do with it?
Here is what I’ve found in the log:
Error handling request
9:34:16 AM – (ERROR) components/waze_travel_time/helpers.py - message first occurred at 9:33:47 AM and shows up 2 times
Log Details (ERROR)
Logger: aiohttp.server
Source: components/waze_travel_time/helpers.py:16
First occurred: 9:33:47 AM (2 occurrences)
Last logged: 9:34:16 AM
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 82, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 136, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 180, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 73, in wrapper
result = await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 280, in async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 367, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/waze_travel_time/config_flow.py", line 120, in async_step_user
if await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/waze_travel_time/helpers.py", line 16, in is_valid_config_entry
WazeRouteCalculator(origin, destination, region).calc_all_routes_info()
File "/usr/local/lib/python3.10/site-packages/WazeRouteCalculator/WazeRouteCalculator.py", line 209, in calc_all_routes_info
results = {"%s-%s" % (route['routeType'][0], route['shortRouteName']): self._add_up_route(route['results' if 'results' in route else 'result'], real_time=real_time, stop_at_bounds=stop_at_bounds) for route in routes}
File "/usr/local/lib/python3.10/site-packages/WazeRouteCalculator/WazeRouteCalculator.py", line 209, in <dictcomp>
IndexError: list index out of range
