Waze travel time - Destination zone !== current zone
Hey all, I believe the waze sensors are still trying to update even if the destination zone is the same as the current zone from that device_tracker. Maybe it’s an idea to add an option if you want that? Seems like it’s not worth it to calculate that traveltime on the same zone? I get a lot of errors like this:
Logger: homeassistant.components.waze_travel_time.sensor
Source: components/waze_travel_time/sensor.py:336
Integration: waze_travel_time ([documentation](https://www.home-assistant.io/integrations/waze_travel_time), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+waze_travel_time%22))
First occurred: 13:23:02 (1 occurrences)
Last logged: 13:23:02
Error on retrieving data: empty response
