You disabled automated polling of this entity?
I have again this problem in 2021.11.4 version…
I collected more info:
when I config component at firset time: all works fine!
thena, after an HA reboot, I have “no route found”
what it’s the problem?
Did you ever get this sorted out?
I am experiencing the same probleme : the route is missing and the duration is much higher.
Why ?
Same Issue in with all regions…
Logs say:
Logger: aiohttp.server
Source: components/waze_travel_time/helpers.py:12
First occurred: 00:42:51 (6 occurrences)
Last logged: 00:55:05
Error handling request
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 220, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 79, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 219, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 137, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 164, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 62, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 111, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 252, in async_configure
result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 325, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/waze_travel_time/config_flow.py", line 108, in async_step_user
if await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/src/homeassistant/homeassistant/components/waze_travel_time/helpers.py", line 12, in is_valid_config_entry
WazeRouteCalculator(origin, destination, region).calc_all_routes_info()
File "/usr/local/lib/python3.9/site-packages/WazeRouteCalculator/WazeRouteCalculator.py", line 65, in __init__
if self.already_coords(start_address): # See if we have coordinates or address to resolve
File "/usr/local/lib/python3.9/site-packages/WazeRouteCalculator/WazeRouteCalculator.py", line 79, in already_coords
m = re.search(self.COORD_MATCH, address)
File "/usr/local/lib/python3.9/re.py", line 201, in search
return _compile(pattern, flags).search(string)
TypeError: expected string or bytes-like object
Just a hint to all: for me it also. Didn’t work unless I did it with zones. So just setup the address as a zone and type in the sensor name (zone.yourzonename) and it should work perfectly
This was the only thing that worked for me
Same for me! In the end, the only thing that worked was zones. Origin: person.xxx, destination: zone.xxx
I made a passive zone just for this purpose.
i was just about to give up, you saved us all. Thanx
As someone who started HA 3 months ago with the only programming knowledge being a bit of self taught HTML, working my way through 50 video tutorials and 100 at times confusing github descriptions, it means a lot to me
