@firstof9 this gives a whole bunch of different errors:
2018-04-14 16:33:44 ERROR (MainThread) [homeassistant.components.sensor] waze_travel_time: Error on device update!
File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/connectionpool.py", line 601, in urlopen
chunked=chunked)
File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/connectionpool.py", line 346, in _make_request
self._validate_conn(conn)
File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/connectionpool.py", line 850, in _validate_conn
conn.connect()
File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/connection.py", line 326, in connect
ssl_context=context)
File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/util/ssl_.py", line 329, in ssl_wrap_socket
return context.wrap_socket(sock, server_hostname=server_hostname)
File "/usr/lib/python3.5/ssl.py", line 385, in wrap_socket
_context=self)
File "/usr/lib/python3.5/ssl.py", line 760, in __init__
self.do_handshake()
File "/usr/lib/python3.5/ssl.py", line 996, in do_handshake
self._sslobj.do_handshake()
File "/usr/lib/python3.5/ssl.py", line 641, in do_handshake
ConnectionResetError: [Errno 104] Connection reset by peer
File "/srv/homeassistant/lib/python3.5/site-packages/requests/adapters.py", line 440, in send
timeout=timeout
File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/connectionpool.py", line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/util/retry.py", line 357, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/packages/six.py", line 685, in reraise
raise value.with_traceback(tb)
chunked=chunked)
conn.connect()
_context=self)
self.do_handshake()
urllib3.exceptions.ProtocolError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 188, in _async_add_entity
await entity.async_device_update(warning=False)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity.py", line 327, in async_device_update
yield from self.hass.async_add_job(self.update)
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/sensor/waze_travel_time.py", line 103, in update
self.waze_data.update()
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/util/__init__.py", line 319, in wrapper
result = method(*args, **kwargs)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/sensor/waze_travel_time.py", line 126, in update
self._origin, self._destination, self._region, None)
File "/srv/homeassistant/lib/python3.5/site-packages/WazeRouteCalculator/WazeRouteCalculator.py", line 35, in __init__
self.start_coords = self.address_to_coords(start_address)
File "/srv/homeassistant/lib/python3.5/site-packages/WazeRouteCalculator/WazeRouteCalculator.py", line 57, in address_to_coords
response = requests.get(self.WAZE_URL + get_cords, params=url_options)
File "/srv/homeassistant/lib/python3.5/site-packages/requests/api.py", line 72, in get
return request('get', url, params=params, **kwargs)
File "/srv/homeassistant/lib/python3.5/site-packages/requests/api.py", line 58, in request
return session.request(method=method, url=url, **kwargs)
File "/srv/homeassistant/lib/python3.5/site-packages/requests/sessions.py", line 508, in request
resp = self.send(prep, **send_kwargs)
File "/srv/homeassistant/lib/python3.5/site-packages/requests/sessions.py", line 618, in send
r = adapter.send(request, **kwargs)
File "/srv/homeassistant/lib/python3.5/site-packages/requests/adapters.py", line 490, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
