So I’ve been using Waze Travel Time integration to let my family know when I’m due back from work. It worked really really well, everything was perfect until I got a new phone.
All I did when I got a new phone was to change the device tracker for my user.
The Waze integration is simply setup as it’s origin to be username.tracker and the destination the long/lat of home.
Nowadays, while it works it gives me totally random times it seems. The further from home I am, the more random it seems to be. As I get closer it re-calculates and gets the time right on the last poll (5 minute)
I’ve tried re-installing the Waze Integration and this did not help.
Furthermore, this evening I wanted to test to see what happens. I set the origin as home and the destination as a different long/lat about 15 minute away and I couldn’t even setup the integration because it stated “failed to connect” which could indeed be why my travel time is so out - but the logs don’t seem to show anything
No I didn’t really investigate it. Since Covid I’m only at the office once per week so the intergrations doesn’t gets used as much as before. I just tought this was a one time thing maybe, untill I read your post. So I am not completly sure if we have the same problem or not, I shall monitor it the next time.
Seems that all of a sudden I am getting “Error: required key not provided @ data[‘name’]”
I’ve googled it and nada! No idea what it means. Well I mean, I guess it’s because there’s no required key but I don’t know what that means (i.e. what key?!)
I have tried to add waze over “device and services”.
It worked one time but I had to delete it because the address was wrong. Than I tied to add it again and now I get always
I have written the address in “Startort” and “Zieleort” and clicked on submit. After that I get this error.
Found the reason.
I had “Deutschland” in the address instead of “Germany” like
Street Housnr PostalCode Deutschland
instead of
Street Housnr PostalCode Germany
