Wear os app cannot select entity to show as complication
I dont see an error here, the logs are also 3 seconds long so they may not be long enough
Sorry for the long logcat i dont have android studio and i have to work with adb. For some reason the switch for the light works now but not all lights are showing…ONly half of the ones i have
09-18 00:41:26.430 29114 29186 D bt_btm  : BTM_GetHCIConnHandle
09-18 00:41:26.430 29114 29186 D bt_btm  : btm_handle_to_acl_index
09-18 00:41:26.430 29114 29186 D bt_btm  : btm_pm_proc_mode_change switched from UNKNOWN to SNIFF.
09-18 00:41:26.430 29114 29186 D bt_btm  : btm mode change to active; check l2c_link for outgoing packets
09-18 00:41:26.430 29114 29186 D bt_btm  : btm_sco_disc_chk_pend_for_modechange: hci_handle 0x000b, p->state 0x01
09-18 00:41:26.430 29114 29186 D bt_btm  : btm_cont_rswitch
09-18 00:41:26.503   564   699 D InputReader: Btn_touch(2): value=0 when=164847.152473
09-18 00:41:26.503   564   699 I InputReader: Touch event's action is 0x1 (id=5, t=0) [pCnt=1, s=] when=164847.152473
09-18 00:41:26.510  5277  5277 I ViewRootImpl@d5de6dc[HomeActivity]: ViewPostIme pointer 1
09-18 00:41:26.512   564   698 I InputDispatcher: Delivering touch to (5277): action: 0x1, f=0x0, d=0, '56f573c', t=1
09-18 00:41:26.514   308   308 I io_stats: !@ 179,0 r 5233039 77554174 w 1479662 22401724 d 52719 6218316 f 2088514 772049 iot 5586068 0 th 51200 51200 48136 pt 36 inp 0 0 164847.164
09-18 00:41:26.781   564   691 D SSRM:Temperature: SIOP:: AP : 343 CP : -999 BLK : 335 BAT : 328
09-18 00:41:26.842  5277 10113 I mpanion.androi: Background young concurrent copying GC freed 66635(2078KB) AllocSpace objects, 3(64KB) LOS objects, 13% free, 14MB/16MB, paused 236us total 135.881ms
09-18 00:41:27.043   564   699 D InputReader: Btn_touch(2): value=1 when=164847.691577
09-18 00:41:27.043   564   699 I InputReader: Touch event's action is 0x0 (id=5, t=0) [pCnt=1, s=0.2909 ] when=164847.691577
09-18 00:41:27.045  5277  5277 I ViewRootImpl@d5de6dc[HomeActivity]: ViewPostIme pointer 0
09-18 00:41:27.045   564   698 I InputDispatcher: Delivering touch to (5277): action: 0x0, f=0x0, d=0, '56f573c', t=1
09-18 00:41:27.049   969   969 D SYSTEM_UI: QuickpanelInputMonitor$3.onInputEvent(102): touch down position Y: 243.0, isLocked=false
09-18 00:41:27.165   564   699 D InputReader: Btn_touch(2): value=0 when=164847.814463
09-18 00:41:27.165   564   699 I InputReader: Touch event's action is 0x1 (id=5, t=0) [pCnt=1, s=] when=164847.814463
09-18 00:41:27.167  5277  5277 I ViewRootImpl@d5de6dc[HomeActivity]: ViewPostIme pointer 1
09-18 00:41:27.171   564   698 I InputDispatcher: Delivering touch to (5277): action: 0x1, f=0x0, d=0, '56f573c', t=1
09-18 00:41:27.201  5277  5277 I EdgeEffect: EdgeEffect const: mIsDeviceDefault=false
09-18 00:41:27.930   564   699 D InputReader: Btn_touch(2): value=1 when=164848.578478
09-18 00:41:27.930   564   699 I InputReader: Touch event's action is 0x0 (id=5, t=0) [pCnt=1, s=0.2910 ] when=164848.578478
09-18 00:41:27.931   564   698 I InputDispatcher: Delivering touch to (5277): action: 0x0, f=0x0, d=0, '56f573c', t=1
09-18 00:41:27.932  5277  5277 I ViewRootImpl@d5de6dc[HomeActivity]: ViewPostIme pointer 0
09-18 00:41:27.936   969   969 D SYSTEM_UI: QuickpanelInputMonitor$3.onInputEvent(102): touch down position Y: 335.0, isLocked=false
09-18 00:41:28.130   564   699 D InputReader: Btn_touch(2): value=0 when=164848.778795
09-18 00:41:28.130   564   699 I InputReader: Touch event's action is 0x1 (id=5, t=0) [pCnt=1, s=] when=164848.778795
09-18 00:41:28.130   564   698 I InputDispatcher: Delivering touch to (5277): action: 0x1, f=0x0, d=0, '56f573c', t=1
09-18 00:41:28.134  5277  5277 I ViewRootImpl@d5de6dc[HomeActivity]: ViewPostIme pointer 1
09-18 00:41:28.493 29114 29186 D bt_btm  : btm_pm_snd_md_req switching from SNIFF to ACTIVE.
09-18 00:41:28.497  5277 31530 D WebSocketRepository: Websocket: onMessage (text)
09-18 00:41:28.503  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:28.504  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:28.979 29114 29186 D bt_btm  : BTM_GetHCIConnHandle
09-18 00:41:28.981 29114 29186 D bt_btm  : btm_bda_to_acl found
09-18 00:41:28.981 29114 29186 D bt_btm  : BTM_GetHCIConnHandle
09-18 00:41:28.981 29114 29186 D bt_btm  : btm_handle_to_acl_index
09-18 00:41:28.981 29114 29186 D bt_btm  : btm_pm_proc_mode_change switched from UNKNOWN to ACTIVE.
09-18 00:41:28.982 29114 29186 D bt_btm  : btm mode change to active; check l2c_link for outgoing packets
09-18 00:41:28.983 29114 29186 D bt_btm  : btm_sco_disc_chk_pend_for_modechange: hci_handle 0x000b, p->state 0x01
09-18 00:41:28.983 29114 29186 D bt_btm  : btm_cont_rswitch
09-18 00:41:29.985 29114 29186 D bt_btm  : btm_pm_snd_md_req switching from ACTIVE to SNIFF.
09-18 00:41:30.015 29114 29186 D bt_btm  : BTM_GetHCIConnHandle
09-18 00:41:30.016 29114 29186 D bt_btm  : btm_bda_to_acl found
09-18 00:41:30.016 29114 29186 D bt_btm  : BTM_GetHCIConnHandle
09-18 00:41:30.016 29114 29186 D bt_btm  : btm_handle_to_acl_index
09-18 00:41:30.017 29114 29186 D bt_btm  : btm_pm_proc_mode_change switched from UNKNOWN to SNIFF.
09-18 00:41:30.017 29114 29186 D bt_btm  : btm mode change to active; check l2c_link for outgoing packets
09-18 00:41:30.017 29114 29186 D bt_btm  : btm_sco_disc_chk_pend_for_modechange: hci_handle 0x000b, p->state 0x01
09-18 00:41:30.017 29114 29186 D bt_btm  : btm_cont_rswitch
09-18 00:41:30.019  1180  1180 I ImsResolver: there is no ImsMtelFeature interface, try to get again
09-18 00:41:31.022  1180  1180 D ImsResolver: maybeAddedImsService, packageName: null
09-18 00:41:31.027  1180  1180 I ImsResolver: Updating features in cached ImsService: ComponentInfo{com.android.phone/com.android.internal.telephony.ims.ImsResolver}
09-18 00:41:31.028  1180  1180 D ImsResolver: Updating features - Old features: [ImsServiceInfo] name=ComponentInfo{com.android.phone/com.android.internal.telephony.ims.ImsResolver}, featureFromMetadata=true, features: [{0,EMERGENCY_MMTEL}{0,MMTEL}{0,RCS}] new features: [ImsServiceInfo] name=ComponentInfo{com.android.phone/com.android.internal.telephony.ims.ImsResolver}, featureFromMetadata=true, features: [{0,EMERGENCY_MMTEL}{0,MMTEL}{0,RCS}]
09-18 00:41:31.028  1180  1180 I ImsResolver: ImsService connection exists for ComponentInfo{com.android.phone/com.android.internal.telephony.ims.ImsResolver}, updating features [{s=0, f=EMERGENCY_MMTEL}, {s=0, f=MMTEL}, {s=0, f=RCS}]
09-18 00:41:31.134   564   662 D PowerManagerService: UserActivityStateListenerState: 0
09-18 00:41:31.938   377   399 D BatteryDump: wait_for_battery_event : occured : change@/devices/platform/battery/power_supply/battery
09-18 00:41:31.941   377   399 E BatteryDump: !@new_battery_dump : 3816,-36,2000,168,48,330,0,DisChg,None,Good,NONE,0,Normal,0,0,12600,149,0,0x1d,0x7a,0x0f,0x5e,0x01,0x34,0x00,0x01,0,3,4650,3850,0,0
09-18 00:41:33.122   564   647 D BaseRestrictionMgr: callerPkgName:android calleePackage:android action:com.android.server.action.NETWORK_STATS_UPDATED for type:broadcast
09-18 00:41:33.320   564   646 I AppOps  : updateUidProcState uid: 10024 procState: 0 capability:7
09-18 00:41:33.322   564   647 D BaseRestrictionMgr: callerPkgName:android calleePackage:android action:android.os.action.POWER_SAVE_TEMP_WHITELIST_CHANGED for type:broadcast
09-18 00:41:33.326   564   646 I AppOps  : updateUidProcState uid: 1000 procState: 0 capability:7
09-18 00:41:33.331   564   647 D BaseRestrictionMgr: callerPkgName:android calleePackage:android action:android.os.action.POWER_SAVE_TEMP_WHITELIST_CHANGED for type:broadcast
09-18 00:41:33.342   564   647 D BaseRestrictionMgr: callerPkgName:android calleePackage:android action:android.os.action.POWER_SAVE_TEMP_WHITELIST_CHANGED for type:broadcast
09-18 00:41:36.000   564   647 D BaseRestrictionMgr: callerPkgName:android calleePackage:android action:com.android.server.action.NETWORK_STATS_UPDATED for type:broadcast
09-18 00:41:36.651 29114 29186 D bt_btm  : btm_pm_snd_md_req switching from SNIFF to ACTIVE.
09-18 00:41:36.654  5277 31530 D WebSocketRepository: Websocket: onMessage (text)
09-18 00:41:36.658  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:36.855   564   691 D SSRM:Temperature: SIOP:: AP : 363 CP : -999 BLK : 336 BAT : 330
09-18 00:41:37.139 29114 29186 D bt_btm  : BTM_GetHCIConnHandle
09-18 00:41:37.139 29114 29186 D bt_btm  : btm_bda_to_acl found
09-18 00:41:37.140 29114 29186 D bt_btm  : BTM_GetHCIConnHandle
09-18 00:41:37.140 29114 29186 D bt_btm  : btm_handle_to_acl_index
09-18 00:41:37.140 29114 29186 D bt_btm  : btm_pm_proc_mode_change switched from UNKNOWN to ACTIVE.
09-18 00:41:37.140 29114 29186 D bt_btm  : btm mode change to active; check l2c_link for outgoing packets
09-18 00:41:37.140 29114 29186 D bt_btm  : btm_sco_disc_chk_pend_for_modechange: hci_handle 0x000b, p->state 0x01
09-18 00:41:37.140 29114 29186 D bt_btm  : btm_cont_rswitch
09-18 00:41:38.144 29114 29186 D bt_btm  : btm_pm_snd_md_req switching from ACTIVE to SNIFF.
09-18 00:41:38.176 29114 29186 D bt_btm  : BTM_GetHCIConnHandle
09-18 00:41:38.176 29114 29186 D bt_btm  : btm_bda_to_acl found
09-18 00:41:38.177 29114 29186 D bt_btm  : BTM_GetHCIConnHandle
09-18 00:41:38.177 29114 29186 D bt_btm  : btm_handle_to_acl_index
09-18 00:41:38.177 29114 29186 D bt_btm  : btm_pm_proc_mode_change switched from UNKNOWN to SNIFF.
09-18 00:41:38.177 29114 29186 D bt_btm  : btm mode change to active; check l2c_link for outgoing packets
09-18 00:41:38.177 29114 29186 D bt_btm  : btm_sco_disc_chk_pend_for_modechange: hci_handle 0x000b, p->state 0x01
09-18 00:41:38.177 29114 29186 D bt_btm  : btm_cont_rswitch
09-18 00:41:39.925   564   699 D InputReader: Btn_touch(2): value=1 when=164860.571684
09-18 00:41:39.925   564   699 I InputReader: Touch event's action is 0x0 (id=5, t=0) [pCnt=1, s=0.2911 ] when=164860.571684
09-18 00:41:39.926   564   698 I InputDispatcher: Delivering touch to (5277): action: 0x0, f=0x0, d=0, '56f573c', t=1
09-18 00:41:39.926  5277  5277 I ViewRootImpl@d5de6dc[HomeActivity]: ViewPostIme pointer 0
09-18 00:41:39.929   564   698 D PowerManagerService: UserActivityStateListenerState: 1
09-18 00:41:39.934   969   969 D SYSTEM_UI: QuickpanelInputMonitor$3.onInputEvent(102): touch down position Y: 232.0, isLocked=false
09-18 00:41:40.030   564   699 D InputReader: Btn_touch(2): value=0 when=164860.679974
09-18 00:41:40.030   564   699 I InputReader: Touch event's action is 0x1 (id=5, t=0) [pCnt=1, s=] when=164860.679974
09-18 00:41:40.032   564   698 I InputDispatcher: Delivering touch to (5277): action: 0x1, f=0x0, d=0, '56f573c', t=1
09-18 00:41:40.040  5277  5277 I ViewRootImpl@d5de6dc[HomeActivity]: ViewPostIme pointer 1
09-18 00:41:40.046  5277  5277 D UrlRepository: localUrl is: false and usesInternalSsid is: false
09-18 00:41:40.051   564  2220 D PhoneWindowManagerExt: f.b. a=false id=0 callingPackage=io.homeassistant.companion.android hapticsEnabled=true touchBezelEnabled=true bezelHapticsEnabled=true Caller=com.android.server.policy.PhoneWindowManager.performHapticFeedback:6709 com.android.server.wm.Session.performHapticFeedback:291 android.view.IWindowSession$Stub.onTransact:1050 com.android.server.wm.Session.onTransact:144 android.os.Binder.execTransactInternal:1154
09-18 00:41:40.052   564  2220 D Vibrator: binder call to service pkg=android, effect=SemHaptic{mType=50038, mRepeat=-1, mMagnitude=-1, mMagnitudeType=TYPE_TOUCH}
09-18 00:41:40.052   564  2220 V VibratorService: vibrate - package: android, token: android.os.Binder@439fdd6, usage: 0, effect: SemHaptic{mType=50038, mRepeat=-1, mMagnitude=-1, mMagnitudeType=TYPE_TOUCH}, mag: 10000, TYPE_TOUCH
09-18 00:41:40.052   564  2220 V VibratorService: semColorfulVibrate - package: android, reason: null, repeat: -1, token: android.os.Binder@439fdd6, usageHint : 0, flags: 0, mag: 10000, TYPE_TOUCH
09-18 00:41:40.052   564  2220 D VibratorService: Turning vibrator off.
09-18 00:41:40.053   418   418 E SecVibrator-HAL-AIDL-CORE: V_1_0: Vibrator off
09-18 00:41:40.054   418   418 E SecVibrator-HAL-AIDL-CORE: HW_API: >> writeNode node:/timed_output/vibrator/enable val:0
09-18 00:41:40.056   418   418 E SecVibrator-HAL-AIDL-CORE: HW_API: << writeNode node OK : 2
09-18 00:41:40.057   564  2220 D VibratorService: vibratorOn() : 20ms, mag :10000, type : 50038
09-18 00:41:40.057   564  2220 I VibratorService: [VIB JNI] vibratorPerformHapticEngine()
09-18 00:41:40.058   278   278 I servicemanager: Found android.hardware.vibrator.IVibrator/default in device VINTF manifest.
09-18 00:41:40.060   564  2220 E VibratorService: [VIB JNI] getInterfaceVersion aidl remote_ver  (2).
09-18 00:41:40.061   564  2220 I VibratorService: [VIB JNI] vibratorSupportsHybridHapticEngine()
09-18 00:41:40.061   278   278 I servicemanager: Found android.hardware.vibrator.IVibrator/default in device VINTF manifest.
09-18 00:41:40.064 29114 29186 D bt_btm  : btm_pm_snd_md_req switching from SNIFF to ACTIVE.
09-18 00:41:40.068   564  2220 E VibratorService: [VIB JNI] getInterfaceVersion aidl vendor command (2).
09-18 00:41:40.071   418   418 E SecVibrator-HAL-AIDL-EXT: V_2_0: supportsHybridHapticEngine
09-18 00:41:40.071   418   418 E SecVibrator-HAL-AIDL-CORE: HW_API: isNodeExist node:/timed_output/vibrator/hybrid_haptic_engine
09-18 00:41:40.072   418   418 E SecVibrator-HAL-AIDL-CORE: HW_API: true
09-18 00:41:40.073   564  2220 W VibratorService: [VIB JNI] supportsHybridHapticEngine aidl vendor : true
09-18 00:41:40.073   564  2220 I VibratorService: [VIB JNI] performHybridHapticEngine duration (20).
09-18 00:41:40.073   564  2220 I VibratorService: [VIB JNI] performHybridHapticEngine amplitude (10000).
09-18 00:41:40.073   564  2220 I VibratorService: [VIB JNI] performHybridHapticEngine type (1).
09-18 00:41:40.073   564  2220 I VibratorService: [VIB JNI] performHybridHapticEngine data (9).
09-18 00:41:40.073   564  2220 I VibratorService: [VIB JNI] performHybridHapticEngine overdriving (0).
09-18 00:41:40.075   418   418 E SecVibrator-HAL-AIDL-EXT: V_2_0: performHybridHapticEngine
09-18 00:41:40.075   418   418 E SecVibrator-HAL-AIDL-EXT: V_2_0: performHybridHapticEngine amplitude : 10000
09-18 00:41:40.076   418   418 E SecVibrator-HAL-AIDL-EXT: V_2_0: performHybridHapticEngine packet_cnt : 1
09-18 00:41:40.076   418   418 E SecVibrator-HAL-AIDL-EXT: V_2_0: performHybridHapticEngine total_size : 4
09-18 00:41:40.076   418   418 E SecVibrator-HAL-AIDL-EXT: V_2_0: performHybridHapticEngine : 4 20 10000 #9 0
09-18 00:41:40.078   418   418 E SecVibrator-HAL-AIDL-CORE: HW_API: do_on for timeoutMs: 1
09-18 00:41:40.078   418   418 E SecVibrator-HAL-AIDL-CORE: HW_API: >> writeNode node:/timed_output/vibrator/enable val:1
09-18 00:41:40.079   418   418 E SecVibrator-HAL-AIDL-CORE: HW_API: << writeNode node OK : 2
09-18 00:41:40.079   418   418 E SecVibrator-HAL-AIDL-EXT: V_2_0: performHybridHapticEngine OK
09-18 00:41:40.079   564  2220 W VibratorService: [VIB JNI] performHybridHapticEngine aidl vendor : OK
09-18 00:41:40.111   564   564 E VibratorService: Vibration finished, cleaning up
09-18 00:41:40.112   564   564 D VibratorService: Turning vibrator off.
09-18 00:41:40.114   418   418 E SecVibrator-HAL-AIDL-CORE: V_1_0: Vibrator off
09-18 00:41:40.114   418   418 E SecVibrator-HAL-AIDL-CORE: HW_API: >> writeNode node:/timed_output/vibrator/enable val:0
09-18 00:41:40.115   418   418 E SecVibrator-HAL-AIDL-CORE: HW_API: << writeNode node OK : 2
09-18 00:41:40.492 29114 29186 D bt_btm  : BTM_SetPowerMode: btm_pm state stored:0
09-18 00:41:40.496  5277 31530 D WebSocketRepository: Websocket: onMessage (text)
09-18 00:41:40.497  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:40.499 29114 29186 D bt_btm  : BTM_GetHCIConnHandle
09-18 00:41:40.499 29114 29186 D bt_btm  : btm_bda_to_acl found
09-18 00:41:40.499 29114 29186 D bt_btm  : btm_handle_to_acl_index
09-18 00:41:40.499 29114 29186 D bt_btm  : btm_pm_proc_mode_change switched from UNKNOWN to ACTIVE.
09-18 00:41:40.499 29114 29186 D bt_btm  : btm mode change to active; check l2c_link for outgoing packets
09-18 00:41:40.499 29114 29186 D bt_btm  : btm_sco_disc_chk_pend_for_modechange: hci_handle 0x000b, p->state 0x01
09-18 00:41:40.499 29114 29186 D bt_btm  : btm_cont_rswitch
09-18 00:41:40.736  5277 31530 D WebSocketRepository: Websocket: onMessage (text)
09-18 00:41:40.755  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:40.759  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:40.913  5277 10113 I mpanion.androi: Background young concurrent copying GC freed 45352(1690KB) AllocSpace objects, 0(0B) LOS objects, 9% free, 15MB/16MB, paused 2.078ms total 135.808ms
09-18 00:41:41.732 29114 29186 D bt_btm  : btm_pm_snd_md_req switching from ACTIVE to SNIFF.
09-18 00:41:41.776 29114 29186 D bt_btm  : BTM_GetHCIConnHandle
09-18 00:41:41.776 29114 29186 D bt_btm  : btm_bda_to_acl found
09-18 00:41:41.777 29114 29186 D bt_btm  : BTM_GetHCIConnHandle
09-18 00:41:41.778 29114 29186 D bt_btm  : BTM_GetHCIConnHandle
09-18 00:41:41.778 29114 29186 D bt_btm  : btm_handle_to_acl_index
09-18 00:41:41.778 29114 29186 D bt_btm  : btm_pm_proc_mode_change switched from UNKNOWN to SNIFF.
09-18 00:41:41.778 29114 29186 D bt_btm  : btm mode change to active; check l2c_link for outgoing packets
09-18 00:41:41.779 29114 29186 D bt_btm  : btm_sco_disc_chk_pend_for_modechange: hci_handle 0x000b, p->state 0x01
09-18 00:41:41.779 29114 29186 D bt_btm  : btm_cont_rswitch
09-18 00:41:42.619   308   308 I io_stats: !@ 179,0 r 5233045 77554198 w 1479677 22401924 d 52719 6218316 f 2088520 772055 iot 5586072 0 th 51200 51200 48136 pt 36 inp 0 0 164863.265
09-18 00:41:42.904 29114 29186 D bt_btm  : btm_pm_snd_md_req switching from SNIFF to ACTIVE.
09-18 00:41:42.920  5277 31530 D WebSocketRepository: Websocket: onMessage (text)
09-18 00:41:42.932  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:42.939  5277 31530 D WebSocketRepository: Websocket: onMessage (text)
09-18 00:41:42.944  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:42.954  5277 31530 D WebSocketRepository: Websocket: onMessage (text)
09-18 00:41:42.960  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:42.961  5277 31530 D WebSocketRepository: Websocket: onMessage (text)
09-18 00:41:42.963  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:42.971  5277 31530 D WebSocketRepository: Websocket: onMessage (text)
09-18 00:41:42.973  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:43.035   564   662 D PowerManagerService: UserActivityStateListenerState: 0
09-18 00:41:43.381 29114 29186 D bt_btm  : BTM_SetPowerMode: btm_pm state stored:0
09-18 00:41:43.383 29114 29186 D bt_btm  : BTM_GetHCIConnHandle
09-18 00:41:43.383 29114 29186 D bt_btm  : btm_bda_to_acl found
09-18 00:41:43.384 29114 29186 D bt_btm  : BTM_GetHCIConnHandle
09-18 00:41:43.384 29114 29186 D bt_btm  : btm_handle_to_acl_index
09-18 00:41:43.384 29114 29186 D bt_btm  : btm_pm_proc_mode_change switched from UNKNOWN to ACTIVE.
09-18 00:41:43.384 29114 29186 D bt_btm  : btm mode change to active; check l2c_link for outgoing packets
09-18 00:41:43.384 29114 29186 D bt_btm  : btm_sco_disc_chk_pend_for_modechange: hci_handle 0x000b, p->state 0x01
09-18 00:41:43.384 29114 29186 D bt_btm  : btm_cont_rswitch
09-18 00:41:43.402  5277 31530 D WebSocketRepository: Websocket: onMessage (text)
09-18 00:41:43.404  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:43.405  5277 31530 D WebSocketRepository: Websocket: onMessage (text)
09-18 00:41:43.416  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:43.431  5277 31530 D WebSocketRepository: Websocket: onMessage (text)
09-18 00:41:43.433  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:43.441  5277 31530 D WebSocketRepository: Websocket: onMessage (text)
09-18 00:41:43.444  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:43.445  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:43.825  5277 31530 D WebSocketRepository: Websocket: onMessage (text)
09-18 00:41:43.836  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:43.844  5277 31530 D WebSocketRepository: Websocket: onMessage (text)
09-18 00:41:43.852  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:43.861  5277 31530 D WebSocketRepository: Websocket: onMessage (text)
09-18 00:41:43.863  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:43.884  5277 31530 D WebSocketRepository: Websocket: onMessage (text)
09-18 00:41:43.887  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:43.952  5277 10113 I mpanion.androi: Background young concurrent copying GC freed 45259(1574KB) AllocSpace objects, 0(0B) LOS objects, 8% free, 15MB/16MB, paused 505us total 116.766ms
09-18 00:41:44.026  5277 31530 D WebSocketRepository: Websocket: onMessage (text)
09-18 00:41:44.033  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:44.039  5277 31530 D WebSocketRepository: Websocket: onMessage (text)
09-18 00:41:44.042  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:45.029 29114 29186 D bt_btm  : btm_pm_snd_md_req switching from ACTIVE to SNIFF.
09-18 00:41:45.075 29114 29186 D bt_btm  : BTM_GetHCIConnHandle
09-18 00:41:45.076 29114 29186 D bt_btm  : btm_bda_to_acl found
09-18 00:41:45.076 29114 29186 D bt_btm  : BTM_GetHCIConnHandle
09-18 00:41:45.077 29114 29186 D bt_btm  : btm_handle_to_acl_index
09-18 00:41:45.077 29114 29186 D bt_btm  : btm_pm_proc_mode_change switched from UNKNOWN to SNIFF.
09-18 00:41:45.077 29114 29186 D bt_btm  : btm mode change to active; check l2c_link for outgoing packets
09-18 00:41:45.077 29114 29186 D bt_btm  : btm_sco_disc_chk_pend_for_modechange: hci_handle 0x000b, p->state 0x01
09-18 00:41:45.077 29114 29186 D bt_btm  : btm_cont_rswitch
09-18 00:41:45.437  2117  2180 D CountryDetectorWrapper: getCurrentCountryIso GR
09-18 00:41:45.444  2117  2180 I ContactsProvider_EventLog: contents_sample_state: [CONTACT contacts(1197) data(2844) accounts({vnd.sec.contact.phone (1)=1704}) accounts deleted({}) calls([sec_logtype:100 cnt:153, sec_logtype:1150 cnt:47]) countryIso(GR) userId(0)  ]
09-18 00:41:45.444  2117  2180 I ContactsProvider_EventLog: contents_sample_state: [ agr({[1 ,1]=503, [1]=692, [1 ,1 ,1]=2})  ]
09-18 00:41:45.444  2117  2180 I ContactsProvider_EventLog: contents_sample_state: [ actCnt({android.process.acore(2117)=1})  ]
09-18 00:41:45.444  2117  2180 I ContactsProvider_EventLog: contents_sample_state: [PROFILE contacts(1) data(2) accounts({vnd.sec.contact.phone (1)=1})  ] [SAPROFILE contacts(0) data(0) accounts({})  ]
09-18 00:41:45.444  2117  2180 I ContactsProvider_EventLog: contents_sample_state: [STORAGE Contacts(CE) Profile(CE) SAProfile(CE) CallLog(CE)  ]
09-18 00:41:45.448  2117  2180 I ContactsProvider_EventLog: Flush buffer to file cnt : 1 size : 1Kb duration : 3ms lastUpdatedAfter : 61751 ms mFlush_time_threasold : 2000 mCurrentSize : 616
09-18 00:41:46.682   308   308 I io_stats: !@ 179,0 r 5233046 77554202 w 1479679 22401932 d 52719 6218316 f 2088520 772055 iot 5586076 0 th 51200 51200 48136 pt 36 inp 0 0 164867.330
09-18 00:41:46.930   564   691 D SSRM:Temperature: SIOP:: AP : 343 CP : -999 BLK : 337 BAT : 330
09-18 00:41:47.216 29114 29186 D bt_btm  : btm_pm_snd_md_req switching from SNIFF to ACTIVE.
09-18 00:41:47.231  5277 31530 D WebSocketRepository: Websocket: onMessage (text)
09-18 00:41:47.237  5277 31530 D WebSocketRepository: Message number 60 received
09-18 00:41:47.699 29114 29186 D bt_btm  : BTM_GetHCIConnHandle
09-18 00:41:47.700 29114 29186 D bt_btm  : btm_bda_to_acl found
09-18 00:41:47.700 29114 29186 D bt_btm  : BTM_GetHCIConnHandle
09-18 00:41:47.701 29114 29186 D bt_btm  : btm_handle_to_acl_index
09-18 00:41:47.701 29114 29186 D bt_btm  : btm_pm_proc_mode_change switched from UNKNOWN to ACTIVE.
09-18 00:41:47.701 29114 29186 D bt_btm  : btm mode change to active; check l2c_link for outgoing packets
09-18 00:41:47.701 29114 29186 D bt_btm  : btm_sco_disc_chk_pend_for_modechange: hci_handle 0x000b, p->state 0x01
09-18 00:41:47.701 29114 29186 D bt_btm  : btm_cont_rswitch
09-18 00:41:48.704 29114 29186 D bt_btm  : btm_pm_snd_md_req switching from ACTIVE to SNIFF.
09-18 00:41:48.728 29114 29186 D bt_btm  : BTM_GetHCIConnHandle
09-18 00:41:48.728 29114 29186 D bt_btm  : btm_bda_to_acl found
09-18 00:41:48.729 29114 29186 D bt_btm  : BTM_GetHCIConnHandle
09-18 00:41:48.729 29114 29186 D bt_btm  : btm_handle_to_acl_index
09-18 00:41:48.729 29114 29186 D bt_btm  : btm_pm_proc_mode_change switched from UNKNOWN to SNIFF.
09-18 00:41:48.729 29114 29186 D bt_btm  : btm mode change to active; check l2c_link for outgoing packets
09-18 00:41:48.729 29114 29186 D bt_btm  : btm_sco_disc_chk_pend_for_modechange: hci_handle 0x000b, p->state 0x01
09-18 00:41:48.729 29114 29186 D bt_btm  : btm_cont_rswitch
^C
C:\Program Files (x86)\Minimal ADB and Fastboot
No worries, I still don’t see an error. Thats very strange. What device is this happening on? I do indeed see websocket communication so that part is working.
One thing you can try to do is enable debug logging for the mobile_app integration
using the logger.set_level service: https://www.home-assistant.io/integrations/logger/#services
set homeassistant.components.mobile_app: debug then perform the toggle again and in your HA core logs you should see debug statements printing for each taken. Lets see if the service call is coming in.
I’m not able to select an entity for the “Entity state” complication either.
I’m using the Galaxy Wearable app on my OnePlus 8 Pro to control my Samsung Galaxy Watch 5. As far as I can tell, nothing happens when I tap on the complication after adding the “Entity state” complication. I looked through the logs from both the watch and the phone too, but I cannot find a single log row related to Home Assistant when tapping the complication on the watch preview on the phone.
