Hi guys,
I am trying to connect my Ticwatch Pro 3 Ultra to HA. When I try to connect, it says “watch could not be registered”.
I found some posts with the same issue, but really do not quite understand what I have to do to solve my particular issue. Clearly the problem is a networking issue somehow. I read somewhere I should try and connect without Bluetooth, but then I cant even get the process started, as I need to continue on my phone (which doesnt seem to find the watch and vice versa via Wifi.
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: Watch was unable to register: java.net.SocketTimeoutException: failed to connect to /192.168.178.93 (port 8123) from /192.168.167.239 (port 50516) after 10000ms
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at libcore.io.IoBridge.connectErrno(IoBridge.java:185)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at libcore.io.IoBridge.connect(IoBridge.java:129)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at java.net.PlainSocketImpl.socketConnect(PlainSocketImpl.java:137)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:390)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:230)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:212)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:436)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at java.net.Socket.connect(Socket.java:621)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at okhttp3.internal.platform.AndroidPlatform.connectSocket(AndroidPlatform.kt:63)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.kt:295)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at okhttp3.internal.connection.RealConnection.connect(RealConnection.kt:207)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at okhttp3.internal.connection.ExchangeFinder.findConnection(ExchangeFinder.kt:226)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at okhttp3.internal.connection.ExchangeFinder.findHealthyConnection(ExchangeFinder.kt:106)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at okhttp3.internal.connection.ExchangeFinder.find(ExchangeFinder.kt:74)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at okhttp3.internal.connection.RealCall.initExchange$okhttp(RealCall.kt:255)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.kt:32)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.kt:109)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.kt:95)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.kt:83)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.kt:76)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at okhttp3.internal.connection.RealCall.getResponseWithInterceptorChain$okhttp(RealCall.kt:201)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at okhttp3.internal.connection.RealCall$AsyncCall.run(RealCall.kt:517)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
10-19 11:11:51.963 30235 30235 E SettingsWearViewModel: at java.lang.Thread.run(Thread.java:764)
10-19 11:11:51.965 30235 30235 D SettingsWearViewModel: onDataChanged 1
10-19 11:11:51.965 30235 4968 D WearOnboardingListener: onMessageReceived: MessageEventParcelable[16599,/request_home_assistant_instance, size=0]
10-19 11:11:51.966 30235 4968 D WearOnboardingListener: sendHomeAssistantInstance: ed4f15eb
10-19 11:11:51.967 30235 4968 D ServerConnectionInfo: Using external URL
10-19 11:11:51.975 30235 30235 D WearOnboardingListener: sendHomeAssistantInstance: success
10-19 11:11:55.086 30235 30235 D IntegrationRepository: isAppLocked(): false. (LockEnabled: false, appActive: false, expireMillis: 1697706513958, currentMillis: 1697706715086)
10-19 11:11:55.099 30235 30272 E OpenGLRenderer: Unable to match the desired swap behavior.
10-19 11:11:55.142 30235 30235 D IntegrationRepository: isAppLocked(): false. (LockEnabled: false, appActive: false, expireMillis: 1697706513958, currentMillis: 1697706715142)
10-19 11:11:55.143 30235 30235 D IntegrationRepository: setAppActive(): true
10-19 11:11:58.610 30235 30272 W Parcel : Expecting binder but got null!
10-19 11:11:58.638 30235 30272 E OpenGLRenderer: Unable to match the desired swap behavior.
10-19 11:11:58.712 30235 30272 E OpenGLRenderer: Unable to match the desired swap behavior.
10-19 11:12:00.067 30235 30235 D IntegrationRepository: isAppLocked(): false. (LockEnabled: false, appActive: true, expireMillis: 1697706513958, currentMillis: 1697706720067)
10-19 11:12:00.067 30235 30235 D IntegrationRepository: setAppActive(): true
Any ideas?
