Using the weather card and open weather map, two questions:
- Why is every day in the five day forecast labelled “Sun”? Based on the docs it should be “Mon”, “Tue” etc.
- How do you get the low temp to show up under the high temp forecast?
have you subscribed to the 3-hourly version of OpenWeatherMap?
No - I guess I assumed this was a 5-day forcast, not hourly.
OK solved - had to switch the service “mode” to daily not hourly in the integration setup. Thanks!
