🌦 Weather forecast access for LLM (eg ChatGPT or Gemini)
:rotating_light: Update :rotating_light:
I created a new post for all my voice related blueprints
Updates will be placed there
You will need to reimport the blueprint and create a new script in order to get updates.
Original Post
Introduction
Since some time Large Language Models like OpenAI/ChatGPT or Gemini can be used for voice commands, they can even control your house now. 2024.12 will even bring an option to prefer local processing of the command first, so the LLM will act as a fallback. This opens a whole new world of possibilities.
If you expose a script to Assist, a LLM can access and use that script. Using fields you can guide the LLM how to use the script. Using this I created a script which gathers weather forecast data from a weather entity (using the weather.get_forecasts action) and then feeds that data to the LLM, so it will give a nice summary.
How to use it
  1. Use the button to import the blueprint Open your Home Assistant instance and show the blueprint import dialog with a specific blueprint pre-filled.eekend is requested, this means Saturday and Sunday`
  2. : IMPORTANT: Expose the script to Assist
That’s it, you can now ask an LLM voice agent for the weather forecast, and it it will tell you the forecast (provided the data is available in your weather entity).
Updates
20250128
  • Fix check for end date of period
20250127 :rotating_light: Backwards incompatible change :rotating_light:
  • Link to new repository
  • New version name (date of last update)
  • :rotating_light: New blueprint name (you’ll need to create a new script if you import this blueprint)
v2.3 2025-01-27
  • avoid template errors in case daily forecast only uses date strings, and not a full datetime string
v2.2 2025-02-25
  • Add toggle to set it multiple hours/days of forecasts should be sent as an average, or as multiple items
  • Additional checks if the data provided by the LLM is in the right format and of the right type.
v2.1 2025-01-24
  • Check if all fields are set correctly by the LLM before continuing with fetching the forecast
v2.0 2025-01-24
  • reworked how the LLM determines the start and end of the period. It now sets a date and time separately, and then the time period (e.g. 1 day, or 6 hours)
  • Added all the descriptions of the fields used in the script to the blueprint settings, to allow you to change these when setting up the blueprint
  • use a datetime comparison instead of a string comparison when grabbing the right items out of the total forecast, to avoid taking the wrong period when the forecast datetimes are in UTC
v1.3: 2025-01-09
  • Make end of period optional, in case it is not provided a day will be added to the start of the period in case the start time is 00:00 (midnight), otherwise an hour will be added
v1.2: 2025-01-06
  • Resolve issue in case the start of period and end of period are set to the exact same date and time
Thanks to:
@jenova70 for providing the groundwork for the calendar script on which this script is also based
I removed the LLM instructions I initially added. Changed the setup so the data which sent to LLM will now be an average over the entire requested period.
Thanks for this. Works great!
Hi! Cool automation. I seem to have an odd issue when I try to use this.
The script was configured as described and I used the same description and weather provider. I checked and it seems to return the correct output when I use it in the developer menu. However when I ask gemini what the weather is for this weekend or an upcoming day, I get the following errors:
This corresponds to the following error in my logs:
This suggests it might not be filling out both inputs:
Hmm, yes indeed, I can build something in for that.
Let me think about it.
I’ve updated the blueprint :slight_smile:
@TheFes I just tried it out and so far pretty good!
When I requested “what’s the weather this weekend” (good catch specifying the weekend days by the way) it returned this:
The weather forecast for this weekend (December 21-22, 2024) is as follows:
- **Condition:** Cloudy
- **Temperature:** High of 14°F, Low of -2°F
- **Wind Speed:** 12 mph
- **Wind Bearing:** 138°
- **Humidity:** 84%
- **UV Index:** 2
- **Precipitation:** 0 (no expected precipitation)
So Assist actaully ready out the asterisks. Do you handle that in your own conversation agent initial prompt?
Yes, I changed the prompt of the LLM integration itself and told it to avoid special characters
Oh nice. Can you share your modifications? I tried this but it still included special characters and once told me the measurements in Metric (though I’m in the USA and it is Imperial)
This is the end of my the default OpenAI Conversation Agent initial prompt:
Answer the user’s questions about the world truthfully. You are in the United States. Assume all units of measure are Imperial. When responding do not include asterisk or other punctuation (besides comma and period) as this will be read out loud to the user.
This is what I use
You are a voice assistant for Home Assistant.
Imagine you’re in a good mood. Respond honestly, short and to the point. Queries will be mostly in Dutch.
Do not use emoji in the response, prevent usage of special characters like “*” in responses as the responses are used in voice responses.
for me the llm keeps saying “i’ve no access to weather information”
Did you expose the script to Assist?
yes i do, i also put in the description. but for me it doesn’t work
Is the script triggered when you ask the LLM for the weather, and if so, and errors in the trace?
the script is not triggered if i ask for weather information
if i run the script manual this errors shows up.
i also tried diffrent weather services like:
  • buienradar
  • accuweather
  • met.no
Did you provide the start (and optionally end) of the forecast period when running it manually?
yes i did,
if i run from developer tools and give it a start and end time then i get a rsponse
Do you use Gemini as LLM? I also have some issues then.
It does use the script, but it doesn’t use the proper input for the selectors.
yes i use gemini
Are you using the default recommended settings in the config?
I tried with some different models, and it really differs per model if it uses the script or or not.
With the recommended settings it works for me. I did add some additional instructions to the selector description which hopefully makes it use the right input for the selectors. So you might want to update the blueprint as well.
