Weather Forecast Card (Button Card)
I’m really particular/ocd/anal (whatever you want to call it) about about being able to control every aspect of a card style.
And sometimes, not even Card Mod can help, or I don’t feel like spending any more time trying to make it work.
I didn’t love any of the existing Weather Forecast cards out there, so I made my own only using Button Cards.
Anyone have any thoughts or feedback on what I could do to improve it?
I do have a separate card for current weather. This one is just for the 5 day forecast.
EDIT: Below is the code if anyone wants to use it. Sorry it’s not very user friendly.
It uses:
  • Button Card (does most of the work)
  • Decluttering Card (although it doesn’t have to)
  • Card Mod (although could do this all with inline CSS)
  • Horizontal Stack (1 column per day)
The [[[forecast_index]]] code has to be replaced with whatever code/value your weather integration uses to denote the day/date of the week.
Then use a horizontal stack card with 5 columns, with this code in each column, modifying the [[[forecast_index]]] code in each column as mentioned above.
      type: custom:button-card
      layout: vertical
      show_icon: false
      show_state: false
      show_name: false
      custom_fields:
        day: |
            const forecastEntity = states['sensor.pirate_weather_daily'];
            if (forecastEntity && forecastEntity.attributes && forecastEntity.attributes.forecast) {
              const forecastDate = new Date(forecastEntity.attributes.forecast[[[forecast_index]]].datetime);
              const options = { weekday: 'short' };
              return forecastDate.toLocaleDateString(undefined, options);
            return 'N/A';
        icon: |
              const forecast = forecastEntity.attributes.forecast[[[forecast_index]]];
              const condition = forecast.condition.toLowerCase();
              const iconMapping = {
                'sunny': 'mdi:white-balance-sunny',
                'cloudy': 'mdi:weather-cloudy',
                'rainy': 'mdi:weather-rainy',
                // Add more mappings as needed
              return `<ha-icon icon="${iconMapping[condition] || 'mdi:weather-partly-cloudy'}"></ha-icon>`;
            return 'N/A';
        condition: |
            return forecastEntity && forecastEntity.attributes && forecastEntity.attributes.forecast
              ? `${forecastEntity.attributes.forecast[[[forecast_index]]].condition}`
              : 'N/A';
        high_temp: |
              const high = forecastEntity.attributes.forecast[[[forecast_index]]].temperature;
              return `<div>${high}<span class="symbol">°F</span></div><div class="label-large">High Temp</div>`;
            return 'N/A';
        low_temp: |
              const low = forecastEntity.attributes.forecast[[[forecast_index]]].templow;
              return `<div>${low}<span class="symbol">°F</span></div><div class="label-large">Low Temp</div>`;
            return 'N/A';
        humidity: |
              ? `<div class="label-small">Humidity</div><div>${forecastEntity.attributes.forecast[[[forecast_index]]].humidity}%</div>`
              : 'N/A';
        precipitation: |
              ? `</div><div class="label-small">Rain</div><div>${forecastEntity.attributes.forecast[[[forecast_index]]].precipitation}"`
              : 'N/A';
        precipitation_probability: |
              ? `<div class="label-small">Rain Chance</div><div>${forecastEntity.attributes.forecast[[[forecast_index]]].precipitation_probability}%</div>`
              : 'N/A';
        wind_speed: |
              ? `<div class="label-small">Wind Speed</div><div>${Math.round(forecastEntity.attributes.forecast[[[forecast_index]]].wind_speed)} mph</div>`
              : 'N/A';
        wind_gust_speed: |
              ? `<div class="label-small">Wind Gusts</div><div>${Math.round(forecastEntity.attributes.forecast[[[forecast_index]]].wind_gust_speed)} mph</div>`
              : 'N/A';
      styles:
        card:
          - font-family: Roboto
          - color: var(--theme-black)
          - text-align: center
          - padding: 0
          - border: 1px solid var(--theme-grey-400)
          - border-radius: 100px !important
          - box-shadow: none
        grid:
          - grid-template-areas: >-
              "icon" "day" "condition" "high_temp" "low_temp" "humidity"
              "precipitation" "precipitation_probability" "wind_speed"
              "wind_gust_speed"
          - grid-template-columns: 1fr
          - grid-template-rows: auto
        custom_fields:
          day:
            - grid-area: day
            - color: var(--theme-white)
            - background-color: var(--theme-blue-400)
            - font-size: 18px
            - font-weight: 600
            - padding: 0 0 0 0
            - margin: 10px 5px 0 5px
          icon:
            - grid-area: icon
            - width: 40px
            - height: 40px
            - margin: 10px 0 0 0
            - padding: 10px
            - color: white
            - background-color: var(--theme-orange-300)
            - align-self: center
            - justify-self: center
          condition:
            - grid-area: condition
            - font-size: 14px
            - font-weight: 600
            - text-transform: capitalize
            - padding: 10px 0 5px 0
            - margin: 0 0 0 0
          high_temp:
            - grid-area: high_temp
            - font-size: 24px
            - font-weight: 600
            - color: var(--theme-red-800)
            - background-color: var(--theme-white)
            - border-bottom: 1px solid grey
            - padding: 0 0 8px 0
            - margin: 0 10px 0 10px
          low_temp:
            - grid-area: low_temp
            - font-size: 24px
            - font-weight: 600
            - color: var(--theme-blue-800)
            - padding: 4px 0 6px 0
            - margin: 0 0 10px 0
          humidity:
            - grid-area: humidity
            - font-size: 14px
            - font-weight: 400
            - color: var(--theme-grey-600)
            - background-color: var(--theme-grey-100)
            - padding: 7px 0 7px 0
          precipitation:
            - grid-area: precipitation
            - font-size: 14px
            - font-weight: 400
            - background-color: var(--theme-grey-200)
            - margin: 0 0 0 0
            - grid-area: precipitation_probability
            - font-size: 14px
            - font-weight: 400
          wind_speed:
            - grid-area: wind_speed
            - font-size: 13px
            - font-weight: 400
            - padding: 6px 0 6px 0
          wind_gust_speed:
            - grid-area: wind_gust_speed
            - font-size: 13px
            - font-weight: 400
            - padding: 7px 0 10px 0
      card_mod:
        style: |
          .label-large {
            font-family: Roboto;
            font-size: 10px;
            font-weight: 400;
            color: var(--theme-grey-500);
          .label-medium {
            font-size: 10px;
            font-weight: 400;
          .label-small {
            font-size: 12px;
            font-weight: 600;
            color: var(--theme-grey-800);
            padding: 0 0 3px 0;
          .symbol {
            font-size: 14px;
          .separator {
            color: var(--theme-dark-grey);
            font-weight: 100;
            display: inline-block;
            padding: 0 10px;
Use proper SI / metric units
Just kidding. :slight_smile: Nice card.
I was a fan of this one but it got abandoned. GitHub - mlamberts78/weather-chart-card: Custom weather card with charts.
EDIT: actually maybe development has started again.
Other than agreeing with @tom_l re SI units (also kidding …or am I? :rofl:) it’s really good!
Hahahaha! I wish! Dumb American government :frowning:
Thanks!
I did see that one, but it was a little more complicated that I was looking for. Wanted one that would be simple to look at for a high wife approval factor.
I 100% agree. I am a fan of SI, America likes doing things the hard way because “money”…
Thanks!
Got a little bit of styling to clean up, but it’s pretty close!
Should work with any weather info, but would require some modifications I think.
I think you could share this as a HACS card (if you know how to do that - I sure* don’t).
How much of it is card-mod (I try to avoid card-mod if I can)?
[edit: typo]
No idea how to do that LOL.
It does use 4 HACS resources though, so not sure if that would prevent it from being able to upload it as a HACS card?
It uses:
It only uses 5 custom CSS classes in Card Mod.
But those classes could be converted to inline CSS styles relatively easy. Just makes it a bit of extra effort to update styles since you would then have to do it for each piece of content.
I’ll edit my first post with the code so everyone can see/use it if they want to.
i personally like the great htlm-template-card.
With that you can control everything using html (for structure/placement/organisation), css(for design), jinja(for value manipulation, conditions & co) …
good luck
Maybe you are using a template for the button card?
I tried to use your card, but i am getting this error:
ButtonCardJSTemplateError: ReferenceError: forecast_index is not defined in 'const forecastEntity = states['sensor.weather_avezzano_daily_forecast']; if (forecastEntity && f...'
Can you help me to trace that error?
