I can’t get the weather forecast card to display in Lovelace, I can only see the edit bar in ‘configure UI’ mode but nothing at all in normal view (it displays OK in the states UI). The configuration looks to be correct and don’t see anything in the log files. Tried it in all versions 0.90.x and 0.91.x but get the same result. Below is an extract from my configuration file:
Did you resolve this? I had this working and realized the card disappeared. It was in a stack but I pulled it out and put it explicitly by itself on a separate tab and it is not appearing at all.
Where does one look for errors?
I checked the dark sky site and am under my quota and my account is still good.
I haven’t got a resolution to this issue yet, nothing I’ve done has made any difference. I’ve even tried reinstalling Hassio from scratch with just the weather forecast card in the UI but to no avail. My dark sky subscription is Ok, the configuration is all OK and I don’t see any errors, it just doesn’t work!
