Weather forecast for Australia using BOM website
You can limit the output of the scraping to 255 by using a truncate filter in the value_template for your sensor. It’s not the best option, but at least the filter will put an ellipsis ("…") at the end of the text so it’s obvious that the value has been truncated.
For example, this should work:
- platform: scrape
    resource: http://www.bom.gov.au/vic/forecasts/melbourne.shtml
    select: 'p:nth-of-type(4)'
    value_template: '{{ value | truncate(255) }}'
sorry…its off topic
is it possible to get “departing in” from this page using scrape sensor
https://www.ptv.vic.gov.au/next5/diva/10012066/line/10395/2/
If you have a look at my post above you can get the selector. From your webpage I followed it and got:
#Next5Tables > table > tbody > tr:nth-child(1) > td:nth-child(1) > div
Otherwise is looks quite well defined with the class=“DepartingIn” which you could select based on that.
thanks perrin7 for your reply.
i already look at your post above
followed your instructions.
i use select: ‘.DepartingIn’
error:
rror on device update!
File “/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py”, line 217, in async_add_entity
yield from entity.async_device_update(warning=False)
File “/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity.py”, line 306, in async_device_update
yield from self.hass.async_add_job(self.update)
File “/usr/local/lib/python3.6/asyncio/futures.py”, line 331, in iter
yield self # This tells Task to wait for completion.
File “/usr/local/lib/python3.6/asyncio/tasks.py”, line 244, in _wakeup
future.result()
File “/usr/local/lib/python3.6/asyncio/futures.py”, line 244, in result
raise self._exception
File “/usr/local/lib/python3.6/concurrent/futures/thread.py”, line 55, in run
File “/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/sensor/scrape.py”, line 120, in update
value = raw_data.select(self._select)[0].text
IndexError: list index out of range
2017-12-29 15:23:07 WARNING (MainThread) [homeassis
i use this code in my yaml file
I tried to get it working for myself - but I think that website doesn’t work with the simple scraper. It has dynamic loading with updating every minute, so might be too complex for the simple scraper built into hass. If you do get it working please post here! I’d like to use it as well :slight_smile:
I got it working. You need ptv dev id and key to get departure time and other info.
Running Hass.io 0.62.1 on a RPi3.
I am trying to get the Melbourne maximum forecast temp to use in some automations using the following config
- platform: scrape
  select: '.max'
  unit_of_measurement: 'Max °C'
I am getting constant errors in my log:-
2018-02-10 22:48:03 ERROR (SyncWorker_19) [homeassistant.components.sensor.rest] Error fetching data: <PreparedRequest [GET]>
2018-02-10 22:48:03 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.melbourne_maximum fails
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 201, in async_update_ha_state
    yield from self.async_device_update()
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 308, in async_device_update
  File "/usr/lib/python3.6/asyncio/futures.py", line 332, in __iter__
  File "/usr/lib/python3.6/asyncio/tasks.py", line 250, in _wakeup
    future.result()
  File "/usr/lib/python3.6/asyncio/futures.py", line 245, in result
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/lib/python3.6/site-packages/homeassistant/components/sensor/scrape.py", line 115, in update
    raw_data = BeautifulSoup(self.rest.data, 'html.parser')
  File "/usr/lib/python3.6/site-packages/bs4/__init__.py", line 192, in __init__
    elif len(markup) <= 256 and (
TypeError: object of type 'NoneType' has no len()
Odd thing is, that it appears as though the sensor is actually working and I am getting the forecasted maximum temp … perhaps it is my OCD … the constant error in the logs bugs me!
Anyone got any ideas on this?
I use the Dark Sky component for Min/Max Temps as well as cloud cover in Melbourne and find it to be just as accurate as BOM, and much easier to set up than scraping.
I might give Dark Sky a go then. I was steering clear of it, as I had heard that it is not that accurate for Melbourne weather, but if you say you are actually using it, and it is OK, then it will cost me nothing to give it a go.
I would still be interested to know why this error is occurring though, as I am bound to use the scrape sensor for other stuff over my home automation journey.
Just wait an hour or so and any forecast is right for Melbourne lol.
its working with PTV API
Thanks @icaman004 … looks like Dark Sky has gotten me what I need. Still not sure why I was getting the weird errors with the scrape sensor, but I will concentrate on other things for now and worry about scraping when I need to worry about it.
Can you share your code?
I’m thinking of writing a 7 day summary that uses mdi icons and the publicly available BoM FTP forecast data. It’s a lot easier to parse than the HTML. E.g.
<forecast-period index="3" start-time-local="2018-03-02T00:00:00+11:00" end-time-local="2018-03-03T00:00:00+11:00" start-time-utc="2018-03-01T13:00:00Z" end-time-utc="2018-03-02T13:00:00Z"><element type="forecast_icon_code">3</element><element type="air_temperature_minimum" units="Celsius">13</element><element type="air_temperature_maximum" units="Celsius">22</element><text type="precis">Partly cloudy.</text><text type="probability_of_precipitation">20%</text></forecast-period>
You can look up your city here: http://reg.bom.gov.au/catalogue/anon-ftp.shtml
Very interested if you do this!
It’s still on my list of things to do but don’t hold your breath. It’s a bit of a low priority compared to the many other projects I have on the go at the moment. I expect it will be a few months before I get to it.
Instead of a custom component, I’m using a handful of commandline sensors to download XML forecasts from the BoM FTP site and parse out forecast info. Perhaps it might be of use? Another take on Australian weather forecasts using BoM feeds
I’ve just requested an API key.
Do you have a layman guide for setting this up?
Presuming you mean public transport and not BOM weather try here Transport NSW / Sydney Bus, Ferry and Train schedule
Thanks. I’m after PTV (Victoria) though, wich requires a dev id, api key and getting a session key. My python skills are rubbish!
